Hi Walt
I also would like to stick to "ONE problem at a time". See it positive: You are rewarded with an Extraball at the score of 75'000. So lets look at the question "is Walt rewarded at the score of 71'000 - when he has set the adjustment to 71'000" ? Same question with 72'000, 73'000, 74'000, 76'000, 77'000, 78'000, 79'000, 80'000.
When these questions are answered: We proceed to next problem / questions (?).
Do You have a schematics ? From another topic I have an incomplete schematics.
I believe to read: The Plug on wire-color-orange is for the range 71'000, 72'000 ... 80'000. The Plug on wire-color-black is for the range 81'000, 82'000 ... 90'000. The Plug on wire-color-grey is for the range 91'000, 92'000 ... 100'000.
See my JPG - I draw an orange line for "to gain an Extraball at score-75'000". My "dashed green line" is for "to gain an Extraball at score-73'000".
Look here http://www.ipdb.org/showpic.pl?id=2577&picno=24596 in the upper left corner I see 10 sockets - question: Is in Your pin "wire-orange" plugged-in into a socket ? If "YES": Mark the socket as "5". Then unplug the wire-orange and plug-in into ANOTHER Socket and try the pin - question: Do You get an extraball ? At a score in the range of 71'000 to 80'000 ? Mark each socket with the appropriate number "7" or "3" or "2" or "9" or "0" - question: Do You get an Extraball on EACH socket as You plug-in wire-orange into the socket ?
Then You may try wire-black for the range 81'000 to 90'000, then You may try wire-grey for the range 91'000 to 100'000. Please write about these tests, greetings Rolf
P.S.: I have some troubles uploading pictures --- FIRST: NOT shown - I then try a second, third time to upload --- all of a sudden I see the JPG three times --- THIRD problem: I cannot delete ...
