I have a clear ramp for my TAF that I want to install. The only issue I really see is resoldering the rear flasher connection. Is there enough wire back there to pull out so that i can reconnect and solder, or is there some other way? Thanks
You have to undo the connectors below the playfield to remove the old ramp anyway, so solder it at your work bench or table.
Quoted from LTG:You have to undo the connectors below the playfield to remove the old ramp anyway, so solder it at your work bench or table.
Thanks...sometimes the obvious isn't always obvious.
This page was printed from https://pinside.com/pinball/forum/topic/replacing-taf-ramp-question and we tried optimising it for printing. Some page elements may have been deliberately hidden.
