(Topic ID: 215113)
Fixing/Replacing Stern Spike & Spooky noisy PS fans (plugnplay shipping now)
By PinMonk
  • 628 posts
  • 125 Pinsiders participating
  • Latest reply 21 days ago by jawjaw
  • Topic is favorited by 157 Pinsiders
    2 key posts have been marked in this topic (Show topic index)
    There are 628 posts in this topic. You are on page 13 of 13.
    #601 11 months ago
    Quoted from D-Gottlieb:
    I am of the constant on theory of fan operation. While the thermally regulated fan is one solution, the up and down temperature swings are not the best for the electronics in the power supply. A consistent temp is better. However, the fan included with the power supply is way too loud for continuous operation. The one that PinMonk provides is fine but I don't know the voltage it is rated for. I took a Noctua 12 volt silent fan and wired it to the accessory connector.
    I added the same fan with the adapter from thingiverse.
    In a quiet room it certainly isn't silent, but you don't hear it while playing.
    It beats the on and off of the very loud thermal controlled fan hands down.
    Found the connector on Mouser. Looks factory.
    3 months later
    #602 8 months ago
    Quoted from torpedo2k:
    Found the connector on Mouser. Looks factory.[quoted image][quoted image]
    Looks so clean! Can you link the connector you found on mouser?
    2 months later
    #604 6 months ago
    I just got my first Stern pin, a GZ, and I can’t believe how loud the fan is! My MMR makes literally no perceptible noise whatsoever, so this came as an unpleasant surprise. At least I know I’m not the only one, and there’s a fix. Very annoying though. Shame on them for not sourcing a better PS. For the price of a NIB Stern pin, this sort of thing is BS. I’d rather pay a bit more if the margins are really that thin.
    #605 6 months ago
    Quoted from CigarPundit:
    The Meanwell power supply itself is actually really good. It just has a ridiculously noisy fan. Meanwell (the manufacturer) has said that they will customize it if asked, but Stern hasn't asked, I assume because it will raise the price of the power supply a little. And Stern's excuse that they need to use a fan with better CFM for edge cases like "a sunny laundromat window where the temps in summer are extreme for a pin" is ridiculous because the EDGE CASES should have to buy the louder fan version, so all the home and air conditioned locations can have the quiet fan. Build a quieter pin for the 99.98% of users and make the laundromat edge cases buy a heavy duty power supply. Don't punish everyone to cover your edge cases. Besides, the power supply has power throttling and a cutoff if the power supply gets to 158F, so failsafes are already built into the power supply. It's just Stern being lazy/cheap. Boo.
    This graph shows the temp range for normal operation and then when it starts throttling, and by how much, and then the failsafe kicking in and cutting off power if the temp reaches 158F.
    #606 6 months ago
    Quoted from PinMonk:
    Edge cases aren’t going to buy anything. They are going to complain to their op/distro/Stern that this pos isn’t working and ask for it to be replaced with something reliable. And Stern doesn’t want that, ops don’t want that and distros don’t want that.
    Until people stop buying due to this issue Stern has no incentive to change it.
    #607 6 months ago
    Quoted from YeOldPinPlayer:
    I honestly don't even believe the edge case Gomez cited as the excuse for keeping the noisy stock higher CFM fan exists as more than a handful of cases, if that. When testing before release, I ran my quieter, lower CFM fans in a bar that was 90F indoors at times in the summer (no ac, they just opened the doors) for almost a year with constant temp monitoring inside both the head and inside the power supply casing (using dual probes) and never got close to even throttling to 80% load. My lower CFM fan turned on at 122F, cooled power supply back to 104F, fan turned off. Stern COULD do it, but I think it's the bean counters that are leaving the status quo and shifting the cost to change to a quieter fan to the end users. Boo.
    Gomez did say another power supply is coming, but that was over 2 years ago, so we'll see.
    1 month later
    #608 5 months ago
    Everyone happy with these? Any failures or issues with game?
    Gameroom gets loud with all the machines on, looking to replace 7-8 fans.
    #609 5 months ago
    Quoted from Psw757:
    I've installed 3 over the years. They work as advertised and take maybe 20 minutes a piece to install. Worked great in a Spooky and worked great in a Stern. 10/10 would recommend IF you don't rotate your pins alot. I seem to just keep upgrading mine for the next guy.
    #610 5 months ago
    Quoted from sataneatscheese:
    I mean for $18 a game seems to be a big improvement if you have several spike games.
    I was just checking to see if anyone has had any failures or overheats.
    They are plug and play now with no cutting correct?
    #611 5 months ago
    Quoted from Psw757:
    Plug and play, no cutting of wires or splicing, but you have to pull/cut some wires out of some glue inside the power supply box. From a technical point of view it's unscrewing screws, unplugging/plugging in a wire, and pulling some wires out of some loose silicone glue. A supervised 8 year old could do it.
    #612 5 months ago
    I would go this route but I like the constant on fan rather than one that runs intermittently. A constant temperature is better than one that cycles up and down. I just tossed the stock internal fan and replaced it with a 40mm Noctua fan wired to the accessory board. Works great and you can't hear it.
    #613 5 months ago
    I forgot to cross link a post I made about Stern recently changing the fans in these power supplies...for the worse. The new fans are cheaper/slightly louder. You can read details about that here:
    https://pinside.com/pinball/forum/topic/stern-finally-has-a-new-fan-in-their-spike2-power-supplies
    The amount/type of silicone in the power supply varies WIDELY. I've personally done dozens of these now and sometimes the fan's wire is barely in the silicone, and other times it's BURIED. It's not hard to get the wire out at all as long as you're careful snipping into the silicone a little at a time, but I don't want to misrepresent that it's always dead simple. Really that's the only part of the install that can take a few minutes by itself if you get one that is BURIED in silicone.
    Here's a comparison pic of two different pins (I've since figured out that you can get either type of silicone mass at any time. Seems to be pot luck, not tied to any particular years of manufacture):
    Quoted from Psw757:
    They are plug and play. I've had one fan failure reported - ever. They're very reliable, and I have the wire length customized at the factory, so it's the correct length with the connector already on.
    There's no overheats possible because the power supply has built-in throttling that takes over if the power exceeds 122F and then cuts power completely if the power supply hits 158F. When I was developing this solution, I had dual probe continuous temp monitors inside the power supply and inside the backbox at a location that was in the 90s ambient temps in summer (bar with no A/C, just some fans) and it never exceeded the 122F where the fans kick on and bring the temp back to 104F or less.
    Here's the temp management graph for the RSP500-48:
    #614 5 months ago
    I'm looking to replace the fan in my Rush Premium. When I made the change in my Iron Maiden I bought this Noctua 40x40x20 (https://a.co/d/ev2U4Gd). If I recall correctly, I figured out how to run it off of 2 wires rather than 3. I have read that these are highly rated fans even though they are a bit pricier. I've had no issues with it at all.
    However, seeing as I may be submitting an order to Digikey for some other parts, I noticed the following is the replacement fan for the Sunon that was listed in the very first post in this thread:
    https://www.digikey.ca/en/products/detail/sunon-fans/HA40201V4-1000U-A99/6198729
    The specs look to be the same as the original one that was listed in this thread and it's about a third of the price of the Noctua, even though that is not the determining factor for purchasing it.
    Do you see any issue using this fan as a replacement in Rush?
    #615 5 months ago
    Quoted from dzorbas:
    As long as you know those digikey fans are bulk pack and have naked wire leads with no connector or protective shrink tubing. So you have to also buy the connector and pins to finish it, or cut it to the right length then splice it, solder it, and shrink tube it onto the lead from the existing fan so you get a connector, that would work.
    You also need to get slightly wider thread-cutting screws as the holes on that fan are larger than the ones in the stock fan, so the two screws on the power supply cannot be used.
    #616 5 months ago
    As long as you know those digikey fans are bulk pack and have naked wire leads with no connector or protective shrink tubing. So you have to also buy the connector and pins to finish it, or cut it to the right length then splice it, solder it, and shrink tube it onto the lead from the existing fan so you get a connector, that would work. You also need to get slightly wider thread-cutting screws as the holes on that fan are larger than the ones in the stock fan, so the two screws on the power supply cannot be used.
    Yup, no problem with any of that. I have all of the necessary bits and pieces to make it work. I think I may even have 2 extra thread cutting screws left over from the Noctua. I will see if they fit and if they don't I will find something more suitable.
    Thanks for the quick response!
    #617 4 months ago
    Ordered one to try before I order for all 7 of spike machine I have.
    Just installed in slightly under 15 minutes and most time consuming part was removing all that silicone.
    Wow is it quiet now!
    #618 4 months ago
    Quoted from Psw757:
    You don't want to remove the silicone completely, though. The goal is to get the wire running through the silicone out without removing all the silicone. Basically just carefully nip a line through the silicone following the path where you expect the wire to be and test lift, nip silicone, test lift, nip the silicone, etc until you can free the wire. Like this:
    #619 4 months ago
    What is the actual purpose of the silicone? It looks like it is just holding the wiring in place so it doesn't touch anything else and perhaps melt and cause a short. If your replacement wiring is zip tied to other cable in there and makes it next to impossible for it to move and/or touch anything, shouldn't that be sufficient?
    We did a handful of games over the last week or so and the amount and position of the silicone varied in each power supply.
    #620 4 months ago
    Just a support material. Prevents components with longer leads from getting loose or vibrating and causing noise.
    #621 4 months ago
    Quoted from snakesnsparklers:
    Oh, the irony.
    #622 4 months ago
    It's just to hold the stuff in place and prevent buzz from vibration/movement. Also provides support/stability so components that may expand/contract or vibrate don't break loose over time.
    And yeah, the amount of silicone used is all over the place. Some of the ones I've done have like little dots here and there, while others are giant globby messes.
    #623 4 months ago
    Another reason to toss the fan completely and replace it with 40mm quiet Noctua fan powered from the accessory jack next to the power supply. No reason to connect it to the internal jack, no worries about wires rubbing or interfering and no temperature swings as the fan is on constantly and completely inaudible.
    #624 4 months ago
    Certainly an option, but the reason I made this DIY and then offered an even less work plug and play quiet fan kit is for people that want a factory look. The noctua external bezel idea absolutely works, but doesn't look close to factory and isn't self-contained with the external power requirement. In my experience the majority of people want a clean, factory look for the power supply fan replacement.
    But, both methods are documented in this thread (and the external larger fan with external bezel DIY ideas keyposted for easy location), so whatever way any one person wants to go, the information is here.
    #625 4 months ago
    For me, the factory look doesn't matter much when it's behind the backglass and even less when a functional improvement is made. But that's me.
    2 months later
    #626 50 days ago
    Im a first time owner, just got a Stern James Bond Premium, and the first thing I noticed after a few games was how loud the fan was. Everyone is saying how easy this is, should i be worried about warranty and/or being a first timer and messing up my brand new machine?!? I've never modded or done anything with the internals past the initial setup.
    #627 50 days ago
    Quoted from BW1029:
    The instructions of the kit are very step-by-step. I've sold a lot over more than 3 years and there are zero install failures I'm aware of. There was one bad fan, but that wasn't an install failure.
    If you have a #2 philips screwdriver, 11/32" socket, and some precision cutters (for jewelry or small gauge wires, etc) the instructions will walk you through it carefully.
    Cary Hardy did an install video (even though he skipped the check your work step at the end) of one he bought:
    4 weeks later
    #628 21 days ago
    Quoted from BW1029:
    It really is easy and difficult to mess anything up. Even if you somehow mess up the power supply, you can buy a new one but never heard of anyone having to do that. Technically there really is not much of a warranty to begin with so this makes no difference. Plus, pretty much everyone is installing mods of some sort so it's hardly abnormal.
    The power supply is super easy to access inside the backbox and easy to open up with simple tools. You need an exacto knife or something sharp to cut away at the spray silicon stuff holding the fan wires down. Nothing complicated. Then you just unplug the stock fan and plug new one in. Just pay attention putting things back together. I didn't and ended up pinching some wires bolting everything back in place. Game had some distortion/noises in speakers but once I freed the wires everything was fine.
    This page was printed from https://pinside.com/pinball/forum/topic/replacing-stern-spike-noisy-ps-fans/page/13 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
