Quoted from RockfordReplay:Thank you for this. I have some concern about the overall package; the power fan does not exhaust the overall housing. Coupled with the housing's vent locations it's retaining unnecessary heat.
A 2nd issue for those with shaker motors; the housing's loose panel-flaps may vibrate against its cover (this extra sound led me to assume a 2nd fan). Several times I looked under the playfield thinking, something gotta' be loose down here.
I think about obtaining a more efficient supply. I simply want to play the game, but something needs to change.
The Meanwell RSP-750-48 American Pinball chose initially is overkill and crazy expensive, which is likely why they probably did a 180 and went with this no-name piece of crap power supply later that literally costs more than $100 less and SAYS it's 50w more (but that's likely a lie in the real world). Literally. That both shows how crazy the meanwell they chose was and how cheap this one is.
The RSP-750-48 would definitely need quieter fans since it has TWO loud fans (NMB 1608VL-04W-B69) that output up to 38dB when on at max together (and draw a crazy 2.6A when both are on!) vs only 15.8dB for two of the quiet fans from my kit, but the complicating factor is that unlike the other meanwells it has a speed control lead. So it would probably be a situation where you just put in two quiet always-on fans in there and just let then run all the time since you can't hear them. And that would be good anyway because at max, the CFM (air flow) is almost exactly half the two fans at max speed.
Here's a pic of the insides of the robust RSP-750-48. Compare this to the sparse electronics in the piece of crap they went with purely for cost reasons later that you have now:
It would require some more investigation, but you probably can get away with a Meanwell SE-600-48 like is in the Spooky machines and is also kind of overkill. That is, IF it would fit in that enclosure. Those can be had for like $75 and are WAY better than that VELIKA thing. I don't think AP really needs 750 or 800W of power (and the Velika isn't delivering 800 anyway, because its efficiency is crap). I think they were just trying to solve the intermittent drops in coil power by just making the power supply bigger and bigger when their capacitor kit that came later was the answer. So dropping back to a 600W power supply with good efficiency that actually DELIVERS that amount of power consistently is probably ok. But this is uncharted territory and would need some temp and power testing (by you, if you go that route, I don't have any AP machines anymore). It's definitely worth trying...
