I have a bunch of wire from a parted out Bally Aladdin's Castle and a Stern Pinball EM (both made after the transition to plastic-coated wire). Would there be any major concerns/issues if I were to repurpose parts of those harness in making a new Stern Nine Ball or Dragonfist harness from scratch? Emphasis on only using parts as I have ample wire from other SS games, so it would just be to fill in gaps or pull colors I may not have otherwise. The gauge seems a bit thicker on the EM harness. Is there harm in a lower gauge wire going to switches? Is there a greater fundamental difference in the type of wire used in EM vs SS pins?
I'm not even sure that I NEED to use any of this EM wire, so ultimately I'm asking if I should even bother hanging on to it.
