Let me try to explain my issue one more time to see if someone can help. On my mousin around, the line cord comes into the game, goes to the junction box where the black, white and green wires split off. White, green and black go to the small square box inside the larger junction box which I think is the varistor? They further go to the line fuse and service outlet. They then go to the on/off switch.
If I check continuity from the wall.plug prongs to the white, black and green wires, everything checks correctly - when the on/off switch is OFF.
However, when I turn the on/off switch ON, my meter shows continuity between all black and white wires! That cant be correct?
When I leave the switch off, but jumper the black and white wires across it, again I show continuity between black and white at all places inside the game - service outlet, varistor input and output. Both sides of on/off switch, etc. Thoughts??
