(Topic ID: 105260)
Replacing Line Cords, Plugs & Wall Sockets- Vid's Guide
By vid1900
8 years ago
    22 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
    There are 358 posts in this topic. You are on page 2 of 8.
    #51 8 years ago
    Quoted from practicalsteve:
    So don't do it myself?
    It's the same as installing a regular duplex, with one additional step to protect other, downstream outlets on the same circuit:
    http://www.homedepot.com/c/installing_electrical_outlets_gfci_HT_PG_EL
    #52 8 years ago
    Might also be a place to note that swapping your 2-prog outlet with a 3-prong outlet does not provide you with a ground to earth unless you run one to that receptacle and connect it to the new outlet. Always use the outlet tester to verify before plugging in your pinball machine.
    #53 8 years ago
    Quoted from BrianZ:
    Don't you love it when i add work for you?
    Yeah, that's nice.
    Quoted from BrianZ:
    Vid, since many are importing from Europe back to the US, can we discuss some of the changes that are needed? And what about swapping the MOV?
    That is a big answer as different generations of pins need different procedures. Some you resolder wires to different lugs on the transformers, and others you move jumper pins around on a Molex.
    The MOV is easier.
    For North America replace the MOV with a 130V unit.
    For Europe replace the MOV with a 275V unit.
    The MOV goes across the mains line. Should the MOV see a surge, it will clamp down almost instantly, suppressing the voltage spike. It can do this many times without failing, but each spike probably damages the MOV a little.
    Should it see a huge spike, the MOV will self destruct, often tripping the circuit breaker.
    Once in a while, a MOV will fail open, and although it will not trip the circuit breaker, it is not protecting the circuit either. If you see discoloration of the MOV (like a brown or black dot on it), replace it.
    #54 8 years ago
    On the Mov front, if you have a re-import with 275V MOV. It techincally will still protect from spikes. Any real benefit to change it out for the 130V MOV (Assuming the game is converted to 110V for US)?
    #55 8 years ago
    Quoted from BrianZ:
    Yes, the 130V would be well worth the $1.
    The lower the clamping voltage, the better the protection.
    At my job, when we have MOVs that fail yearly in a certain location, we install a few MOVs in parallel in the same holes of the circuit board.
    This allows them to "share the load".
    Our engineers say that 2 MOV in parallel will survive 5x longer than a single in the same situation. 3 MOVs will last 20x longer....
    #56 8 years ago
    Interesting. I did not think about running mutiple MOV's. I'm going to try exactly that (2 Movs in parallel). Off to Rad Shack I go.....
    #57 8 years ago
    Im going to preface this by saying I am a *tremendous* idiot.
    I got it into my head that I should upgrade my completely functional reimport Hot Shot to a 3 prong plug. First step is to cut the old cord out, so I clip it and hear a pop as the lights go out. I CUT INTO A LIVE WIRE STILL PLUGGED IN. Told you I was an idiot.
    After resetting the breaker I unplug the damn thing and wire in the new cord. Plugged it back in, nothing. OK, well maybe I got the hot/neutral wires backwards. Switch the wires, still nothing. Why did I mess with something that had no problems? See first line.
    So I need help. Is it possible I smoked the PSU? I dont have a DMM but I'm going to go get one tonight. What should my first steps be?
    #58 8 years ago
    Well Ive confirmed with a DMM that the wires are straight now and the 5A sloblow on the main is good. I dont know what else to look for.
    #59 8 years ago
    blame it all on Vid
    #60 8 years ago
    OK! I figured it out. Turns out I had the negative lead in the wrong place. I'm feeling very sheepish and humble but I suppose as a newbie it's all part of learning.
    Thanks Vid for the amazing work you do here and everyone for not making fun of me lol.
    #61 8 years ago
    Did it burn holes through your wire cutters?
    #62 8 years ago
    No, but it scared the daylights out of me.
    #63 8 years ago
    Glad you didn't get hurt or loose a tool. I'm always paranoid working on Black Knight 2000, The game is covered in lightning bolts, It's like a big warning sign.
    #64 8 years ago
    Just never understood that on a polarized plug the hot wasn't the bigger spade. Make sense right, bigger spade means better current capacity.
    #65 8 years ago
    Quoted from nitrojcrawf:
    It's the smaller one so it is harder for kids to stick a safety pin into.
    #66 8 years ago
    Good thread vid... Info not in schematics so it's good to have reference somewhere. It's kind of a pain in the ass adding a whole new cord and I did my first plug only today... 3 bucks versus maybe 10 for whole cord... I'll take it... Going from dollar menu to a meal deal tomorrow for lunch!!!
    #67 8 years ago
    Strong work vid! Thank you!
    #68 8 years ago
    If you live in an area where there's a Menards store, they have 16-3 20' extension cords on sale for $3.97 until 12/7. They come in green, white, and beige, and they make great replacement cords.
    1 month later
    #69 8 years ago
    I know 16-3 cords would work fine as a replacement pinball machine power cord when wired in 110v service. How about 18-3 cords? I have many of them from computer applications. I read somewhere that 16 gauge wire is rated for 13A and 18 gauge wire is rated for 10A at 110v. A single pinball machine shouldn't pull anywhere near 10A.
    #70 8 years ago
    Quoted from RoyF:
    Usually less than 2.5A
    Quoted from RoyF:
    18 gauge is probably closer to 6A allowable, but even that's plenty for a pinball machine.
    But since a brand new 16g extension cord is $4 at Menards, I gotta just recommend that because the jacket is probably more durable.
    #71 8 years ago
    These questions were probably already answered, but as I have no desire to electrocute myself or burn the house down, I will ask again to make certain:
    I have several 18AWG cords just arrived from GSE that will be going into a DE Simpsons, a Firepower, and an Earthshaker, all of which have had their ground prongs removed; no problem with that gauge, right?
    Here's a pic of the underside of the power box inside the Simpsons cabinet, the new GSE cord is the stripped one at top. Since the colors are the same, I would just run the new wires to where the old wires go, correct? Would it be safe to cut the old wires a few inches down and solder the new ones to them, then cover with heatshrink tubing? I don't trust my soldering skills enough yet to desolder the old wires from the lugs and resolder the new ones along with the auxiliary socket wires, but splicing/soldering them together would be no problem.
    #72 8 years ago
    Quoted from jibmums:
    They should be fine, but next time, get some heavier duty cables for $4.
    #73 8 years ago
    Yes.
    No.
    Splices are frowned upon with power cords.
    Unsolder the old and replace with the new.
    You can't really mess it up like a circuit board, so "tin" your new wires and learn how to solder. You will need to solder stranded wires for every coil that burns out - so now is the time.
    1 month later
    #74 8 years ago
    Here is nice cooked MOV.
    I would have thought post the MOV being burned up (and also disconnected), the machine would not work. But in this case the machine was working.
    Vid, Is this normal? I'm assuming so, since the MOV is just crossing the lugs of the EMI filter.
    The silver disk, assuming this is a thermistor?
    #75 8 years ago
    Quoted from BrianZ:
    The MOV sacrificed itself to save the game from an overvoltage. Right now you are unprotected, so you need to replace it.
    Some hack snipped one leg to allow the game to function again, but should have replaced it.
    Get a new 130v one:
    https://www.greatplainselectronics.com/products.asp?cat=76
    Quoted from BrianZ:
    Yep, it helps control the inrush current when you first turn the game on. Makes the bridge rectifiers last longer.
    #76 8 years ago
    Thanks Vid...
    I was just finishing read PinWiki on this subject, when i saw your post.
    I think i will pickup a few....
    #77 8 years ago
    For installing outlets, a bunch of them, I love the puggrip tool. Makes it a lot easier getting them puppies straight.
    http://www.lowes.com/pd_117894-41813-P-1_0__?productId=1005771
    1 month later
    #78 8 years ago
    Quoted from vid1900:
    Place the copper conductors between the clamp plates and tighten the clamp screws. DO NOT put the wire directly under the screw heads for this style plug.
    Tight means 20 inch pounds if you have a torque wrench- tight means very tight, but don't strip the screw heads for the rest of us.
    Note also that there is no extra bare copper showing above the clamp plates, nor is there any stray strands of copper. If you somehow screw up, just cut all the conductors back and start with a fresh section of cord.
    Screw heads need proper conductor colors:
    GREEN = GROUND
    SILVER = WHITE, NEUTRAL or RIBBED
    BRASS = BLACK OR HOT
    Excellent guide VID - very helpful and informative.
    One little hint:
    At least in germany (maybe in the whole EU) it is forbidden by law regulations, to connect the wires in the way, shown in your photos. You have to use so called "Aderendhülsen". I do not know the english word, maybe end sleeve or ferrule. There are good safety reasons, to do it this way. See attached photo.
    #79 8 years ago
    Yep, we use them at work for those super fine stranded, super flexible, CNC motor wires.
    They give a gas-tight crimp, so the wires don't fray and can be repeatedly inserted into the servodrives, without stripping a new section of wire.
    The term used here in the States is: Wire-End Ferrule
    8 months later
    #80 7 years ago
    Here is another view of the inside wiring with MOV and Thermistor:
    9 months later
    #81 7 years ago
    Do older games need a MOV? I can't see one on my Gottlieb System 80.
    #82 7 years ago
    Quoted from solarvalue:
    Good question. Some older games (e.g. WMS Sys11) have one and others do not (e.g. GTB Sys80).
    The Metal Oxide Varistor (MOV) is there, to protect the game from powerspikes. So it is not necessary, but it does not hurt. Games in the EU use a 275V MOV and in the US a 130V MOV (e.g. this one: https://www.greatplainselectronics.com/proddetail.asp?prod=V130LA20AP)
    I personally have added a MOV to all my games.
    If you are interested, here is an interesting document:
    http://www.littelfuse.com/~/media/electronics/product_catalogs/littelfuse_varistor_catalog.pdf.pdf
    #83 7 years ago
    Just put it on a power strip or "spike cube". Instant MOV.
    #84 7 years ago
    Should the line filter also be replaced on old games?
    #85 7 years ago
    Also what amp. rating do you use?
    #86 7 years ago
    They are usually OK, even when old, but if a game is causing interference on a radio or TV in the house, then the filter may have kicked the bucket.
    #87 7 years ago
    Quoted from joe2012:
    Most pins draw about 2 amps, so it does not have to be too big.
    I keep some 10A ones around, but even 6 is probably plenty.
    #88 7 years ago
    Thank You.
    1 month later
    #89 6 years ago
    NEW POWER CORD FOR EM TYPE MACHINES
    Finally, run a Ground Braid to the metal Legs, Coin Door, Lock Down Bar and Rails of the machine. This will protect the user by making those parts a better path to ground than the player himself is.
    Hi Vid -
    I've got an old ungrounded wood rail EM - wood legs, rails, front door. I read your recommendation to another poster to run the ground wire from a replacement cord to the transformer leg. Fair enough, but how about the ground braid? I assume I can skip installing it because I don't have metal legs, rails, or a lockdown bar. If you still recommend the ground braid, to which component should it be attached?
    Thanks for your help.
    #90 6 years ago
    If there is no metal that a player can touch, then you don't have to worry about grounding anything other than the transformer case.
    #91 6 years ago
    Well, there are metal pieces on the player end of the cabinet. There's a coin drop plate on the wooden front rail, a replay button on the cabinet front, the manual coin return push rod to release coins stuck in the slug rejector, a plate around the coin return, and the ball shooter rod and housing. Would you recommend running a ground braid to any of those?
    Thanks.
    1 month later
    #92 6 years ago
    I switched out the power chord on my Gilligan's Island because it had no ground prong. While I was at it I found there was no thermistor and the MOV had shorted open, so I changed both as well. Finally I removed the auxiliary outlet to make my soldering easier and since I never use it anyway.
    Now the game won't turn on. I've checked the inline fuse (okay) and the AC voltages all the way to the RFI filter and get 123V, but I get nothing out the other end of the filter. Is that enough to confirm the filter needs to be replaced?
    #93 6 years ago
    Vid, Need some help on my re-import WH20. I have just noticed that when i touch the lock down bar and at same time touch another game, I feel a small steady electrical shock.
    After reading your thread, I checked to see if grounding pin is at outlet plug. It is (pics below). I noticed that the ground braid that runs up along the "box" to the coin door and lock down bar receiver was not connected, so I screwed it down to the box through the existing hex screw (pic). But this did not solve the electrical shock.
    I notice my line cord does not have the black insulation inside of the cab, only from the contact point where the cord exits the cab. Could this be the culprit? Have not opened up the little box yet, but assuming that will be next step. Here are pics. Thanks for the help.
    #94 6 years ago
    Update: Decided to open up the box. Here is a pic. Let me know if anything looks out of sorts or needs to be replaced.
    #95 6 years ago
    Quoted from Hammerhead:
    Let's see some clear pictures of your wiring
    #96 6 years ago
    Quoted from Elicash:
    First check if the ground is good at the wall socket (check the actual sockets that both games are plugged into):
    https://pinside.com/pinball/forum/topic/replacing-line-cords-plugs-wall-sockets-vids-guide#post-1945125
    Then check that the male ground pin of the plug actually has continuity to the green wire where it is soldered to the filter module
    #97 6 years ago
    #98 6 years ago
    Excellent picture.
    Put your meter on AC, keep one lead on the neutral terminal of the output side of the filter module.
    Put the other lead on the hot (black) conductor: After the fuse, then at the input of the filter, and then on the output of the filter.
    Power at the input, but not the output?
    #99 6 years ago
    Excellent picture.
    Odd.
    123V after the fuse, 0V after the thermistor, 0V at the filter output. Also no continuity across the thermistor. The thermistor is brand new.
    #100 6 years ago
    Vid thanks for your help. I am somewhat embarrassed to admit I didn't think to check the extension cord I was using.
    The plug and ground from the game's line cord was fine. The extension cord inexplicably didn't have a ground plug. So I am using a new extension cord and the problem is solved.
    Thanks again for our help. Even though this was a simple fix, it is another joy of the hobby learning to diagnose these things.
    This page was printed from https://pinside.com/pinball/forum/topic/replacing-line-cords-plugs-wall-sockets-vids-guide/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
