When replacing headers on boards, what cutters do you use for removal of the old header plastic? My small side cutters aren't quite right for this job. Even if I snip the header pins, the side cutters can't quite get in everywhere to make the cuts on the header plastic for removal.
What do you use, and any references to source would be appreciated.
In case you are wondering, I first cut the old header plastic away, then desolder and remove each header pin, then remove the remaining solder. Although with the Hakko I can do those last 2 steps in one (remove pin and solder) since the solder is well melted by the desoldering tool allowing clean removal of the pin without damage right before sucking the solder.
