Wrapping up replacing the headers on my current project... 3rd time I've done headers on a pin and decided to make my life a touch easier this time round. Here is a quick "hack" using using clothespins:
You need to cut one of the fingers. The pliers I'm using, it took a few times to work my way through to make the cut.
Not required, but I'd suggest you use a file to clean up your cut area and to also file a notch into the long finger to give it more clearance.
And here is the results of about 60 seconds worth of work.
Long finger for headers set back in the board.
Short finger for headers along the edge of the board.
Why I suggest to file a notch, more likely to clear the pins.
A bunch of headers loaded up. I would solder 1 pin into place and remove the clip. While the soldier was still flowing, I'd put my finger on the header to make sure it was flush/flat on the PCB. Once all the headers were secured, I went back and did all my soldering.
PCB pegs or something... 5/8" dowels cut to 2.5" and drilled. #6 screws and #6 washers. Just fit them to the mounting holes of the PCB and snug into place.
A few pegs I had to whittle down a little bit with a pocket knife.
This worked out pretty good for me, figure I'd share. If you find it useful, leave a comment.
Regards.
