(Topic ID: 917)
Replacing hard to reach bulbs
By tallgrass
10 years ago
  • 10 posts
  • 8 Pinsiders participating
  • Latest reply 10 years ago by HELLODEADCITY
    #1 10 years ago
    Is there a tool that can be used to replace bulbs in tight places? I have a tough time reaching in some spots, so any suggestions or ideas are welcome.
    #2 10 years ago
    for #47 - #44 type lamps you can use the white rubber cap that goes on the end of the shooter rod just put a spacer inside so you can get the lamp out .
    #3 10 years ago
    I use a piece of vacuum line or fuel line that just fits over the bulb.
    #4 10 years ago
    Those are the 2 best suggestions.
    When I first started I used some needlenose pliers......ummmm NO don't use those unless you like to pick up glass shards.
    #5 10 years ago
    An old plunger rubber tip will also work
    #6 10 years ago
    Do you guy's replace from the top, or under the playfield??
    Some of my lamps are so burried, I would have to take a lot of things off to get to them.
    I have not looked underneath yet.
    Any tips would be appreciated.
    #7 10 years ago
    Most GI lamps on williams/bally games are really easy to get to from the underside of the playfield, so I would go that route. Just get a nut driver and start taking off the bracket, make sure you have a magnet tool handy, you will need it to retrieve screws.
    #8 10 years ago
    Got a good chuckle when I found this in my new Scared Stiff. Didn't know they really made this.
    #9 10 years ago
    They probably charged $5 for it.
    #10 10 years ago
    Love it the 23-6767 B.E. tool
    $ 5.00
    Doc's Pinball Shop
    $ 79.00
    Creo Pinball
    $ 28.00
    Pin Monk
    $ 20.90
    Apparel - Unisex
    $ 109.99
    $ 44.00
    $ 5,799.00
    Flip N Out Pinball
    $ 14.95
    $ 18.99
    $ 299.00
    $ 42.00
    The MOD Couple
    $ 149.95
    Allteksystems
    $ 17.50
    Playfield - Plastics
    $ 28.75
    The MOD Couple
    Creo Pinball
    $ 289.00
