(Topic ID: 77298)
Replacing bare GI playfield wiring
By dyno
5 years ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 5 years ago by dyno
    #1 5 years ago
    I need to replace some of the bare GI playfield wiring and was wondering what to use. There is no where locally I can find the tinned bare copper wire but I do have some 18 gauge black insulated copper wire, Also wire that is used to hang pictures can that be used as replacement for the bare GI wire, I know it is not copper but can it be used or am I better off using the black insulated copper wire I have. I read a post where the person used the bare wire used to hang pictures and said it worked fine. If I used the wire to hang pictures could I have problems down the road or would that be considered bad practice to use the picture wire.
    #2 5 years ago
    I'd use the insulated stuff. Don't go the ghetto route and use picture hanging wire. When I did a playfield swap on my pinbot I replaced that exposed GI wire with better insulated wire.
    #3 5 years ago
    You can buy the tinned copper wire from here:
    http://www.pinrestore.com/Supplies.html
    There are other sources that may be less expensive. This tinned copper seems like the way to go.
    Al
    #4 5 years ago
    I would prefer not to have to order and wire online since I don't need a whole bunch, would probably cost more in shipping than the wire. I don't have to replace all of it , just some of it is corroded and in rough shape. I was thinking of using the picture wire because it looks the same but know I am thinking of using the insulated wire because I assume it would be a better conductor and would be better since it is insulated. Did the manufactures use the bare wire because of cost?
    #5 5 years ago
    Haven't used picture wire myself, but others say it is harder to work with because it is less flexible and it will rust.
    I used a slightly heavier gauge wire from Marco I think. It laid down fine, but it's pretty obvious it's thicker wire. It cost about 1/3 the price of Pinrestore's stuff, but if I had to do it again I would go with Pinrestore.
    Bill
    #6 5 years ago
    Yeah I know what you mean about shipping costs! I usually wait until I need enough stuff to justify it. But then I think if I had to drive to the store (I live at least 45 min to 1 hour away from nearest store) the cost in gas is as much as shipping!
    Another thought, the site I posted sells the wire by the foot so if you only need a few feet it would not be too expensive and a few feet of wire should be able to be put in an envelope and mailed for the cost of a stamp. If you called they might accommodate you by doing just that. Worth the phone call or email probably.
    #7 5 years ago
    That was one of my concerns with using picture wire is that it may rust or corrode down the road, I don't want to have to be re wiring the gi lights again down the road. I may just go with the insulated wiring I have.
    #8 5 years ago
    I ended up just using the 18 gauge black insulated copper wire I had, I rewired the GI lamps tonight. I picked up an air stapler last week and wow did it make it easy stapling down the new wire, great tool.Thanks all for your input.
    $ 199.99
    $ 39.99
    $ 14.95
    $ 5,599.00
    Classic Game Rooms
    $ 123.00
    $ 7,399.00
    Nitro Pinball Shop
    $ 495.00
    MI Pinball Refinery
    $ 69.99
    $ 19.99
    $ 9,995.00
    Flip N Out Pinball
    $ 45.99
    Lee's Parts
    Pin Monk
    CzTV Mods
    £ 12.00
    Pinball Photos
    $ 14.00
    $ 26.99
    Lee's Parts
    $ 14.95
    $ 107.95
    Hookedonpinball.com
    Magazines/books
    The Flipper Room
