(Topic ID: 235024)
replacing 12,000mf capacitor with parallel ones
By mark532011
4 months ago
  • 8 posts
  • 5 Pinsiders participating
  • Latest reply 4 months ago by G-P-E
#1 4 months ago
I am pretty sure I need to replace the C15 (12,000mf 16v) on my Flash. It doesn't have any obvious bulges but I have weird voltages and the DMM AC test shows a quick 4v which is way over the .3v most threads say is correct.
My question, since a 12,000mf 16v capacitor is pretty hard to get, I thought I could wire them in parallel to achieve the desired result.
I thought I could get a 10,000mf 16v: https://www.mouser.com/ProductDetail/Vishay-BC-Components/MAL202115103E3?qs=sGAEpiMZZMu3dWSqd4Tl0IrB%252bE%2fYPbXzX8%252bZe5Xfl4A%3d
and a 2,000mf 16v: https://www.mouser.com/ProductDetail/Cornell-Dubilier-CDE/WBR2000-16A?qs=sGAEpiMZZMu3dWSqd4Tl0C1dQxjcpck%252bK7MLQlpbxWs%3d
both are axial mounted so they will be easy to solder in parallel, that should work shouldn't it?
#2 4 months ago
The exact value isn't important in this case... anything 10k to 15k should work if you can find one. Higher the better
#3 4 months ago
and you can make it 25v rather than 16v
#4 4 months ago
thanks guys! moving to 25v made it easy. There is a axial 15,000uf 25v capacitor for $7. thats what I like!
https://www.mouser.com/ProductDetail/Illinois-Capacitor-CDE/159TTA025M?qs=sGAEpiMZZMu3dWSqd4Tl0OIl6dT4vs0mI3yk0PJU%2fOfXAfQBkoNXwg%3d%3d
#5 4 months ago
Not exactly sure where your cap is going but remember a higher voltage cap comes with larger physical footprint as well. Definitely better to move up in voltage if you have the room.
#6 4 months ago
Quoted from CNKay:
The logic voltage filter cap on the power supply board, I'm assuming
#7 4 months ago
Yeah axial is what triggered my comment.
I must have made that mistake before.
$ 399.95
Siegecraft Electronics
$ 279.95
$ 14.99
PinballElectronics.com
$ 22.00
$ 14.00
Yorktown Parts and Equip
900
Albany, NY
$ 50.00
1,650
Blaine, TN
$ 279.95
$ 279.95
$ 279.95
$ 17.00
Great pinball charity
Pinball Edu
