(Topic ID: 124106)
Replacement switch capacitor/older Bally pins
By indypinhead
5 years ago
  • 26 posts
  • 17 Pinsiders participating
  • Latest reply 1 year ago by jj44114
  • Topic is favorited by 9 Pinsiders
    #1 5 years ago
    Which capacitor should I use to replace the old capacitors on playfield switches on older Bally pins such as 8 ball deluxe?
    #3 5 years ago
    This is what I have in mine. I was having problems with them being removed on my Gold Ball so the targets were really picky about working, glancing blows, scrapes, lower velocity usually always picked up, anything with high speed (flipper shot, pop bumper) would ignore it almost every single time (same on the star roll overs.) Got these installed, hasn't missed a bit.
    #4 5 years ago
    Big Daddy (http://www.bigdaddy-enterprises.com) sells 0.047uF 50 Volt Ceramic Capacitor for these in a 20 pack for about $3.25. Problem is you'd have to buy $30.00 worth to reach their minimum order...
    #5 5 years ago
    GPE has them for $0.20 and no minimum order. Part # CCD-0.047uF-50V.
    https://greatplainselectronics.com/products.asp?cat=27
    #6 5 years ago
    Quoted from erichill:
    Thought there was a $5 minimum order...
    #8 5 years ago
    Quoted from danczaz:
    Ah, looks like you're right. Still, way easier to hit that than $30.
    #9 5 years ago
    The one cent ones from Tayda work well. Tayda has great prices for your run of the mill components like ceramic caps.
    If you want to one off order. I would look at ebay. Axial caps are probably easier to mount.
    ebay.com link » 100 Pcs 047uf 50v 20 Z5u Axial Ceramic Mlcc Capacitors Sa055e473maa Avx
    #10 5 years ago
    For what its worth, when we were operating Classic Bally pins, the caps liked to break off at the solder joint. When I would replace them, I would leave the leads full length and wrap them around a small allen wrench to form a "spring" and then solder the ends to the lugs. Never had another cap break off once done like that. Buy this might be harder to do today since many disc caps are sold with super short leads.
    2 years later
    #11 2 years ago
    I know this is an old thread. Is 470pf the same as .047uf?
    #12 2 years ago
    Quoted from SealClubber:
    No 470pf is the same as .00047pf.
    #13 2 years ago
    Quoted from GRUMPY:
    Of course he meant .00047
    uF I'm sure. Probably a typo.
    Here is a sight I found with a nice little chart.
    http://www.justradios.com/uFnFpF.html
    #14 2 years ago
    It is MF - F - mF - uF - nF - pF
    If im not mistaken.
    Mega - Farad - milli - micro - nano - pico
    And technically, the u in microFarad is actually a symbol rhat looks like a lower case u, but jas a longer tail on it....not that it's important. Lol
    There are others inbetween (like Kilofarad; half way between MF and F), but I dont think they are too common for our use
    #16 2 years ago
    I wonder how big a one Mega-Farad capacitor would be...
    #17 2 years ago
    Quoted from pacmanretro:
    uF I'm sure.
    #18 2 years ago
    Quoted from G-P-E:
    I recently saw an article about a new design allowing much more power storage in a smaller space, but I honestly can't imagine the size it would still have to be.
    I was obviously just showing there is a scale both directions of the Farad...though not directly relavent. I have a tendancy to over answer things I'm told
    Until they can get a MegaFarad capacitor small enough to fit in a Delorean, I don't have a use for one anyway
    7 months later
    #20 1 year ago
    Size is based on the technology used. If we never designed smaller transistors and came up with the integrated circuit, computers would be as big as office buildings. A 10,000 Farad graphene supercapacitor created by Sunvault Energy is powerful enough to power up a Semi Truck while being the size of a paperback novel.
    #21 1 year ago
    MLCC has seemingly come a long way.
    You can get a 10uF cap with good specs in a pretty damn small size.
    My thing is the crazy decimal points and using MICRO farads.
    Why not nano farad. It is lot easier to keep track of capacitors by number system 105, 104, 223, etc... and not go back and forth between pico and buncha decimal points 0.0003uF. nF!
    #22 1 year ago
    I used to think about capacitors in my car audio set up way back in the late 90s/ early 2000s. The 1 farad caps are still as big as i remember them lol. Totally off topic I know, but since you were all talking about how small they've gotten, I'm somewhat surprised that the larger car audio caps are still as big as they are.
    #23 1 year ago
    Quoted from FatPanda:
    The only reason for that is "pose value" and marketing - it certainly isn't for electronic reasons.
    #24 1 year ago
    Heck yeah!! Big subs gotta have a big cap!
    Maybe even some useless leds and even a meter of some type to look at!
    #25 1 year ago
    You never know what lives inside of those big caps....until they cut them open
    #26 1 year ago
    Chinois!!
    $ 9.95
    Apparel - Unisex
    Pinball Wheezer
    Metal-Mods
    $ 139.00
    Sparky Pinball
    G-Money Mods
    $ 5.00
    $ 7.50
    $ 18.00
    The MOD Couple
    $ 24.00
    Pin Monk
    $ 150.00
    $ 7.50
    Doc's Pinball Shop
    $ 48.00
    £ 29.00
    PinballToys
    $ 19.00
    Chrome Candy
    $ 149.99
    $ 175.00
    Professor Pinball
    $ 9.00
    PinBoss Mods
    Apparel - Unisex
    Silverball Swag
    $ 8.50
    $ 14.95
