(Topic ID: 262133)
Replacement coil for A-15943 (williams)
By Chicoman
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by Pin_Guy
#1 4 years ago
Recently ordered a replacement coil for A-15943 for an Indiana Jones Pinball Machine. The replacement coil according to several sites is a FL-11753. My question is that new coil the FL-11753 has 2 diodes across the terminals where as the original coil the A-15943 does not have those diodes. I don't want to cause any permanent damage to the machine before connecting it or fry something I'm not supposed to.
Do I just install this new coil with the 2 diodes attached or do I need to remove those diodes before installing this coil? It's for the UP/DOWN post for the mini-playfield.....original part A-15943 which is apparently NO LONGER MADE.....replaced by the FL-11753.
Any help is appreciated.....
#2 4 years ago
The diodes are for something like protection.
Are you sure that the original is not with removed/cut diodes previously?
You can measure (with DMM) and compare both coils so you will know where each wire must go from the original to new one.
#3 4 years ago
You can probably go either way; if you leave them on, be sure that your 50V power connection (GRY-YEL) is connected to the end terminal with the stripped side of the diode or you will break things.
Your game already has an FL-11753 without diodes that's powering the diverter and uses identical circuity on the Fliptronics board. Fore reference, PN FL-11753-1 is the same coil without diodes. This is a fairly low power coil, similar in strength to the coil in a popup target, but you still wouldn't want to drive that for a long period of time which is why Williams is powering this from Flipper 4 on the Fliptronics board.
Fill disclosure: I do not own, nor have I ever worked on a Williams IJ.
11,250 (Firm)
Trumansburg, NY
$ 69.99
12,500 (OBO)
$ 59.95
pinballmod
$ 123.00
$ 18.00
Volcano Pinball
Pinball Photos LLC
Various Novelties
Pinball Photos LLC
14,000 (OBO)
$ 0.00
Lighting - Backbox
Creekside Hideaway, LLC
$ 12.95
$ 1,159.00
$ 41.99
Lee's Parts
€ 160.00
Pino Pinball Mods Shop
YouBentMyWookie
$ 75.00
PFX Pinball Mods
$ 0.00
PinJewels
2step’s shop
€ 50.00
$ 1,419.00
$ 29.00
$ 70.00
$ 59.95
pinballmod
Pinball Photos LLC
$ 69.99
This page was printed from https://pinside.com/pinball/forum/topic/replacement-coil-for-a-15943-williams and we tried optimising it for printing. Some page elements may have been deliberately hidden.
