I have a Space Shuttle with a pop bumper that will only fire if I press very firmly on the skirt in a specific spot. If I open up the game, hitting the switch manually triggers the bumper each time, so I think the mechanism itself is still working fine. It was suggested to me to replace the spoon that hits the switch as often times these can be worn down. I guess my questions are:
1. I saw the full rebuild guide, but is there an easy way to just replace the spoon?
2. Does this seem like the most likely root cause given that the switch works consistently? Anything else worth checking?
