(Topic ID: 109695)
Replace Flipper Coil, but it still buzzes
By JustinAhrens
9 years ago
#1 9 years ago
I had a flipper coil that buzzed when the flipper button was held down, and the EOS was working properly, so I got a new coil from Marco and replaced it. It still buzzes, even if I manually hold the EOS switch open with a large gap. What does this mean?
#2 9 years ago
I would try cleaning contacts.
#3 9 years ago
I had that happen also ,I would try too change the part at the end of the coil and the flipper shaft
#4 9 years ago
Check your solder connections and make sure they are good. A stop and or plunger that is not flat will create buzz also.
#5 9 years ago
What game is this on?
#6 9 years ago
Quoted from DocRotCod:
1964 Bally Bongo
#7 9 years ago
This can sure be frustrating. On my Abra Ca Dabra it ultimately (after hours of checking various scenarios) turned out to be the alignment of the plunger with the coil stop. This can be tricky and the alignment tolerance between buzz & no buzz extremely fine.
#8 9 years ago
Most Sterns do this as they don't have a true hold... Not that it is your problem in this case.
#9 9 years ago
No need to replace the coil, the problem is in the coil stop.
#10 9 years ago
Thanks for thee feedback. I really appreciate it.
#11 9 years ago
Quoted from got-pin2:
Yea that's what I said ,this happen too me let me know if that worked
This page was printed from https://pinside.com/pinball/forum/topic/replace-flipper-coil-but-it-still-buzzes and we tried optimising it for printing. Some page elements may have been deliberately hidden.
