I would think if you aren't really worried so much about cosmetics, you could probably use a clear 2 part epoxy to repair and build up the back to prevent further breakout. I have not done this, just my thoughts. See what others advise.
Quoted from Insane:I would think if you aren't really worried so much about cosmetics, you could probably use a clear 2 part epoxy to repair and build up the back to prevent further breakout. I have not done this, just my thoughts. See what others advise.
Given the location, it would be very hard for the player to see any repair so cosmetics matter a little less than strength. I have some "crystal clear" two part epoxy along with some self adhesive drywall joining tape that I was thinking might help give it a bit more rigidity?
I use bondic on my stuff.
https://www.amazon.com/Bondic-Better-Anything-Seconds-Situations/dp/B00UAH19FS/ref=sr_1_1
Just saw this thread after answering in your restoration thread so I'll repeat here.
The problem with all clear ramp repairs is the stronger the repair the more obvious the repair.
For the crack along the bend in the ramp I would first glue it together with Weld-On. This solution works well when you have a crack that will fit tightly back together. The glue wicks into the small gap and melts the plastic. More info in the following link.
The next step if you want to strengthen the joint would be clear epoxy. Lightly sand the inside curve to give the glue some tooth. Only sand a narrow area like 1/4" since it will show unless covered by epoxy. Then apply 3M Instant Adhesive Primer (AC77) to the area you just sanded. This will help promote adhesion between the epoxy and the plastic. Use a clear epoxy like Epoxy 330--optically clear--or Devcon 2 Ton clear. Apply a small bead in the corner and smooth out.
That should give you a pretty good looking repair and good strength.
It's always a good idea to practice on a scrap piece of plastic since there is some technique involved (especially with the Weld-On, where less is better).
Note: Weld-On (or other solvents like Ambroid) provide a much stronger bond than Crazy Glue, Bondic, etc. since they actually melt and fuse the plastic back together.
Quoted from zr11990:Isn't that a Whitewater? Buy a new Ramp.
It's the top left ramp from Radical!, so this crack runs up along the outside of the entrance. I didn't tag the game on the thread because I didn't think it was game specific.
This page was printed from https://pinside.com/pinball/forum/topic/repairing-cracked-ramp and we tried optimising it for printing. Some page elements may have been deliberately hidden.
