(Topic ID: 141013)
Repair score motor on Williams Star Pool
By pinball_bob
6 years ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 6 years ago by KenLayton
#1 6 years ago
Hi everyone,
I have a 1974 Williams Star Pool. Recently the solenoid on the score motor burst into flames! Bit of a short-circuit I think.
I have removed the motor and counted the windings off the solenoid (340!) so that I can try to hand wind a new solenoid.
Has anyone tried this before? Any recommendations on the wire gauge? Source of wiring in the UK? I can not see an easy way to disassemble the motor so will have to make a bobbin and hand wind the solenoid 'in place'. Any other suggestions?
Score motor spec is #7884
#2 6 years ago
Easier to buy another one.
Should be quite a lot of these motors around.
#3 6 years ago
Pinball Resource rebuilds those motors. They could even sell you the replacement coil for the motor if you wanted to swap out the bad one yourself.
#4 6 years ago
Quoted from KenLayton:
I would like to look at that. Does anyone know how to disassemble the motor to be able to be able to fit a new coil? I could easily make a new coil but can't work out how to fit it?
#5 6 years ago
I believe the coil is attached by two tubular rivets that you drill out. Then replace the destroyed rivets with brass nut and brass bolt.
$ 24.98
The Pinball Scientist
$ 5.95
Lighting - Backbox
Arcade Upkeep
$ 7.49
