Hello All,
I'm hoping those with more experience than me can mentor me a little bit and check my thinking with a problem I am working through. This is on a Eight Ball Deluxe LE pinball with the -54 rectifier board. I picked this up recently and for some reason, many wires in the game were cut and then twisted back together (usually with electrical tape covering the twist). I repaired as many of these hacks as I could find and traced down any wires that seemed out of place. I then rebuilt every single component on the rectifier board because I found voltages out of spec. Just yesterday I was going through the test menu for the first time trying to find why I wasn't getting sound effects and I stopped on the solenoid test.
The game started doing the solenoid tests and the displays all went out when it reached #3. I did some digging today and discovered that solenoid #3 is for the knocker. So I traced the knocker wires and discovered that the previous owner had removed all traces of the knocker assembly and hacked together the power lead in to another circuit (coin door lockout solenoid). I guess he was thinking that that solenoid wasn't really needed, so firing that off when the knocker went off would be fine. It turns out it wasn't fine. I had missed it while fixing up their hacks. Because of the diode on that coil, the current was forced to flow back in to the rectifier board.
The green wire that the knocker wire was soldered in to went to connector J2 on the rectifier board. So here is where I begin to be unsure and would appreciate input. The current wanted to get to ground and complete the circuit, but it blew a few things along the way. It looks like it tried to cross the varistor and the fuse after going through the bridge rectifier. I'm not sure if the fuse blew because of that current, but regardless the varistor must have shorted and quickly wiped out the fuse. I'm also not sure why it blew this varistor at all, why not just go straight to the ground after going through the rectifier.
So that should cover the damage that was done by their hack (right?). I was thinking of removing that varistor to check if everything is functioning, but I don't fully understand what that varistor is doing, so I figured I should replace it instead of just remove it until the new one comes. I attempted to check the rectifier on that circuit, but I was getting weird readings and don't have a diode test function on my DMM. Based on my understanding of rectifiers, I figured I could check continuity between the negative and two adjacent legs. I wasn't getting any continuity even though I figured I should measuring in that direction. Same thing on both rectifiers, so I wasn't sure how to interpret that.
So thanks for reading. I am attaching an image from the schematic so you don't have to search. If you can, please let me know if I seem to be on the right track. Anything else you can think of would be appreciated also. Thanks!
