Guys, You are the best.
I follow your advices, check the socket and the connector, what comes from the coin door. I unplug, it, check carefully, and...I found a broken leg.
I solder it (temporary, I think, I will replace the whole socket), and hallelujah, my flippers are alive!
So, a big thank You for everybody!
Now, I'm puzzled a bit, because a few coil is so loud in the machine. For example, the two flipper coils. If I keep pushed them, they are buzzing so loud. Seems the EOS switch is OK...
And, the top middle " O " in the machine, if I shoot it, it lights, but buzzing, humming so loud, and with time, it becomes more louder... But, if I shoot the " X " next to it, it quiets, but the lamp still lights, as it needs.
This can be the coil's problem, or contact?
I don't plan to make a camp fire from the pin...
