Nylon acorn nuts can be a pretty tight fit on metal posts. I'm sure I'm not alone in having this happen: a GI bulb under a plastic goes out, you need to remove the acorn nuts to get to it, and some of them are so tight that they unscrew the metal posts from the playfield instead of coming loose themselves. Then the taut rubber pulls the now-loosened plastic post over, and you have to grab the metal post right under the plastics with needlenose pliers, possibly scratching your plastics, etc. etc., you get the idea. It's a big pain in the ass, just to replace a bulb. Short of barely tightening the acorn nuts, which to me is a bad idea as the plastics can now move around freely and risk getting scratched, anyone got a good solution for this?
