Okay, thanks again all. I bought 10 - 1 foot 3/32 polished stainless steel rods. I'm just going to measure, cut, heat where I need to bend it, bend it then install. This should go smoothly, but if something can be screwed up, I'LL find a way to screw it up. LOL Oh well, I'll try my best.
BTW, I have the entire PF stripped and I have put 3 coats of clear on it. I'm going to drive the broken ends still in the wood down into the wood and out the back. Then I'm going to fill the holes up with wood putty for the new rails to have a real tight solid base. Then I'm going to sand the PF and give it another 4 coats of clear sanding with finer and finer paper all the way up to 2000 grit. Then install the new PF decal and then repopulate it. Lastly, I'll drive the new ball guides in. Say a prayer for me.
