image-620.jpgI'm wanting to remove my JP battery pack and I have a few questions. I have attached a picture. I assume that I have to desolder the 6 points on the back. What soldering iron do you recommend and what temp should I have it set on? I have a soldering iron, but you can't adjust the temp on it. I shouldn't use that one, correct? Also, there seems to be some rubbery glue of some sort under the holder. Do I just pull the holder off after I desolder. How do I know if I took enough solder off?
There is a nice description of how to install a remote battery pack on pinwiki. I just need help removing the old one.
