(Topic ID: 300838)
Remove pin from flipper link on Gottlieb 1976 EM
By WolfWeb
2 years ago
  • 6 posts
  • 5 Pinsiders participating
  • Latest reply 2 years ago by WolfWeb
    #1 2 years ago
    Dumb question alert, I'm new to EM.
    How do I remove and replace the pin that I have circled in this image? It's the flipper mech under the playfield, the link / particle board section snapped, I have new ones in a kit from PBresource. I asked Jimmy if I needed any special tools and he said no but not sure how this pin works. How do I get it out and how do I put it back?
    TIA
    #2 2 years ago
    It's called a roll pin. You can watch some youtube videos. Basically you pound it in and out using a hammer and punch that is just the right diameter.
    #3 2 years ago
    Roll pin punch works great.
    #4 2 years ago
    You need a roll pin punch set, vise, and a hammer. Here's the roll pin punch set:
    https://www.amazon.com/Pieces-Gunsmithing-Removing-Automotive-Jewelry/dp/B07JNS1ZF7/ref=sr_1_6
    #5 2 years ago
    Depending how much space there is between the two metal faces you might want to put a shim between them. I have a variety of thin washers I use to fill up any gap between the faces and the fiber link. If you try to knock out the pin with a gap in there you risk bending one or both faces so they're no longer parallel which can make it harder to reinstall the pin. If there's no gap then the blow from the hammer all goes into moving the pin and not into bending the metal faces.
    Also, don't completely remove the roll pin. If you back it out slowly you can stop when there's just enough clearance to replace the link and the pin is still held in place by one of the faces. Then it's much easier to tap back into place, again with a shim to fill the gap.
    /Mark
    #6 2 years ago
    Thanks all, all sorted. They came out and went back without too much trouble.
    This page was printed from https://pinside.com/pinball/forum/topic/remove-pin-from-flipper-link-on-gottlieb-1976-em and we tried optimising it for printing. Some page elements may have been deliberately hidden.
