I am like you, I enjoy incandescents over LED's in my games. When I buy a game I do replace LEDs with incandescents. I have 12 games and they are all incandescents.
It should be a simple swap back. You might need to bypass OCD boards if they were installed by the previous owner.
I believe for System 11 games, people have to cut resistors to make LED flashers work, so if you have one of those games, this is something to check.
Like others have said incandescents generate more heat. What I do is use lower power bulbs. They are slightly dimmer, but doesn't bother me at all. Instead of the normal 44 bayonet bulbs, try using the lower power 47 bulbs. Instead of normal 555 wedge bulbs, use lower power 159 bulbs. Flashers should stay the same (906 and 89 bulbs).
Check out this club:
https://pinside.com/pinball/forum/topic/incandescent-bulb-fan-club
Old school all the way!!
if you need more help, just let us know.
