Quoted from borna:Great. Looking forward for the challenge
Is it easy to make new cabinet by reverse engineer the existing one?
easier if you have the equipment to make accurate cuts and compound angle joints.
since modern glues are a lot better, usually people keep the joinery simple and it's strong enough, so they don't make the cabinet the same way and only the dimensions matter.
if your current cabinet is too far gone to repair, I'd consider trying to find another cabinet from a parts machine that's in better shape and start with that. Making a cabinet from plywood sheets is only economical if the labor is free and you already have the needed equipment.
typically the only cabinet that can't be repaired is rot / termite damage or massive delamination of the plywood layers - or swollen/moldy particle board if the cabinet used that.
