New! Dark mode!
(Topic ID: 272732)
Remove Em bottom board?
By BBC
3 months ago
  • 11 posts
  • 8 Pinsiders participating
  • Latest reply 3 months ago by RonSS
#1 3 months ago
Hi, has anyone documented how to remove the bottom board in a em? I have an old Chicago I would like to take the bottom board out to work on (the one with the score motor on it). Is it a huge pain? It is a pain in the back right now leaning over into it!! Thanks.
#2 3 months ago
Take out the playfield, there should be 4 bolts on the corners fastening it to the cabinet. The bottom can be lifted out and placed on top of the cabinet to save on the back
Pretty straight-forward but use good lifting techniques.
Earlier Bally games had what I call a kickstand and a real pleasure to work on. https://www.ipdb.org/files/201/Bally_1966_Bazaar_New_Lift_Out_Mounting_Board_Instructions.pdf
#3 3 months ago
There’s also sometimes 1 screw somewhere in the middle of the front third of the playfield also holding it down. If after taking out the four bolts it won’t budge, look for a screw head that isn’t attaching anything to the board. Also, don’t forget to unplug the jones plugs from the bottom board. Easy once you’ve done it once.
#4 3 months ago
Quoted from BBC:
In my Freedom, it only has 2 bolts, on in the upper middle of the bottom score motor, and one in the back middle of the scoreboard.
#5 3 months ago
Old Chicago is definitely four bolts, two on each side. Maybe 1 screw.
#6 3 months ago
Will I need to disconnect any other wiring except the Jones plugs? Thanks.
#7 3 months ago
That should be it. Just get a good look around the perimeter of the board and if everything's disconnected, you should be ready to lift it out. Servicing is *way* easier on a table or work bench.
#8 3 months ago
Probably need to unplug the chime box and knocker too. I usually temporarily remove the chime box as it's in the way when you lift the relay panel up and out. Make sure the power cord has lots of slack too.
#9 3 months ago
Quoted from frunch:
Or on a playfield rotisserie.
#10 3 months ago
These components are all put together on separate lines and assembled into the cabinets. There made to be literally plug n play.
#11 3 months ago
Take some pics of where things go before. Ya know, just in case.
1,500 (OBO)
Reno, NV
$ 2.50
Doc's Pinball Shop
$ 20.90
Apparel - Unisex
$ 110.00
AMCO
$ 69.99
$ 26.99
Lee's Parts
Professor Pinball
$ 55.00
$ 39.00
The MOD Couple
$ 199.99
$ 299.00
Displays
Boston Pinball Company
$ 2.00
Doc's Pinball Shop
$ 129.00
Displays
Pappy's Pinball Palace
$ 229.99
$ 33.50
$ 40.00
Arcade Arts
CzTV Mods
$ 14.95
$ 49.99
$ 19.95
$ 87.95
$ 16.95
$ 5.00
$ 5,899.00
Gulf Coast Pinball, LLC
$ 89.99
