What's the easiest way to remove dried-up rubber stuck to plastic posts, using stuff around the house? I've soaked them in Simple Green and in 91% Alcohol, to no effect. Is there anything that will loosen/soften the rubber but not harm the plastic?
I've had good luck removing dried rubber with an ultrasonic cleaner and a 50/50 mix of hot water and Mean Green. After 5 minutes most of the rubber is gone and the bits still attached are loose enough to remove with a toothbrush.
Quoted from vid1900:A little lighter fluid usually works nicely.
Like Naphtha? that won't attack/soften/melt the plastic?
The Simply Green seems to be working, just slowwwwwwly.
Quoted from jibmums:Like Naphtha? that won't attack/soften/melt the plastic?
It does not attack any flipper or post plastic I've ever tried it on.
Like they always say, test in an inconspicuous area, lol.
I have not tried it on plastic posts, but whenever I've had a tough stain to get rid of, white vinegar usually does the job.
The easiest way is to buy new plastic posts. A quart of Naphtha will cost about the same as 20 new posts. And a lot less messy/time consuming.
This page was printed from https://pinside.com/pinball/forum/topic/remove-dried-up-rubber-from-plastic-posts and we tried optimising it for printing. Some page elements may have been deliberately hidden.
