I'd like to remove the score motor from this assembly for a good cleaning but there's a set screw with a square head that holds an actuator to the shaft. The set screw is wedged in there tight and the gap between the actuator and the frame isn't big enough for a wrench or a socket. I can grab it with needle nose pliers but can't apply enough torque to get it off. Penetrating oil and heat haven't helped yet. Any other suggestions?
/Mark
