Is there any plan to fix the issue with the Pin Map where it shows locations that no longer have any pinball machines attached to them? In Florida USA, there are many locations plotted on the map that do not have any machines attached to them. This makes it difficult to use the map to locate pinball machines while traveling, as you have to click on each dot to see if it actually has any machines.
Thanks,
-E
