(Topic ID: 318118)
Relays not holding in when energized.
By hoodie75
4 months ago
  • 8 posts
  • 4 Pinsiders participating
  • Latest reply 4 months ago by hoodie75
#1 4 months ago
I have a Williams Dipsy doodle and when I start the game the relays will pull in and not stay energized for the duration needed( say when the ball is in the outhole so it can be kicked out). Looked at all the switches and all seem to function. Score motor switch stacks all open and closed as they should. Machine was a re-import from Germany so it had the 50hz motor and transformer. I’ve replaced the motor with the correct one so it is running the correct rpm’s. Any ideas? Thanks in advance.
#2 4 months ago
Do you have the transformer primary re-wired for 110 volts?
#3 4 months ago
It’s wired on the 117 volts lug
#4 4 months ago
I'd focus on one circuit. If you start with the outhole circuit, the outhole relay is initially energized by the outhole switch, through a make-break switch at IND C. Then, it should stay energized thorugh the self-hold switch until it drops from the make-break switch at 5A.
You can put the score motor into "service mode" (there is a jones plug you can use to do this) and turn the motor by hand to ensure things are happening at the right time.
#5 4 months ago
A semi-dirty hold switch that is/looks closed can often open briefly with vibration and kill the circuit. I'd check associated relay's hold switch for any relay dropping out early. Make sure it is clean and has enough bias to remain closed.
#6 4 months ago
Quoted from dr_nybble:
Cam 5a is for the 4th player match, does that really control the relay holding during the score motor cycle?
#7 4 months ago
Quoted from hoodie75:
Look at area D-2 on the schematic, there is a ton of stuff that is released through that switch. It's the '5 plays 25c' side of the switch that it is piggy-backing off of I believe.
You'll have to follow the reference for the outhole relay down to that area:
#8 4 months ago
dr_nybble fir the win!!!!!! Thank you very much I would’ve never thought of checking that cam because I thought I only had to do with the $.25 relay and also The match and since I haven’t set for home use I didn’t care about that. All I Gotta do now is work on the ball index and have it switching players at the end of the ball and everything should be good.
$ 5.95
The Pinball Scientist
Protection
Other
Men
Professor Pinball
Led
$ 60.00
Trident Pinball Homebrew
Flipper parts
Great pinball charity
Pinball Edu
