Well the caffeine from my double strong pot of (https://redroostercoffee.com/) coffee wore off and so eventually did my repair! After 3 games, the armature started to stick again. This time I was sure that there was no dirt or crud holding things up (sorry, cash-riprock). So it was back to the drawing board.
What I figured out was that there was too much clearance in the armature slot where it slides onto the frame. This additional clearance (.021”) allowed the armature to move around such that the little brass rivet on the armature was no longer aligning perfectly with the coil pole when it was pulled close. I figured out that this alignment was key in allowing the armature to release since the brass is non-magnetic.
I decided the best fix would be to make a shim to take up this clearance and keep the armature in position. I made a pattern and cut it out of .016” aluminum stock figuring that the additional .005” would allow for the correct action so it didn’t bind. I allowed a little extra on the sides to fold over the frame to keep everything in place.
The result was great! The relay now *snaps* open and close like it was designed. This is important since this relay controls the 1k/10k change over scoring feature between the two pairs of playfield bumpers. It’s fun to see the playfield light inserts dance back and forth during the reset sequence again.
C86A02B8-6FB1-46AC-A784-8B77DF2C5005 (resized).jpegF28EB025-97DA-495B-B203-603067408565 (resized).jpeg4D1E0F6E-45E0-41CE-BB19-947D1B9F1755 (resized).jpeg6C2F8FB7-1006-44D2-9615-A9B5050ED66B (resized).jpeg
