Quoted from ZfromEarth:My T3 machine back legs screws isn't tight. Two screw is moving in the hole. If I replace the leg bracket this will be good?
Thanks[quoted image]
Sounds like it's stripped, so make sure you get the correct plate (check the online pdf of the manual) and TWO NEW BOLTS. Don't try using your stripped bolts in the new plate or you'll strip that out, too.
