(Topic ID: 45899)
Reinforce Theatre of Magic trunk: anyone try duct tape?
By nosro
6 years ago
  • 18 posts
  • 13 Pinsiders participating
  • Latest reply 6 years ago by Skypilot
#1 6 years ago
The trunk sure seems to crack quickly. I saw this post that suggested reinforcing the trunk with fiberglass (http://pinside.com/pinball/forum/topic/theatre-of-magic-trunk-repair).
Has anyone tried duct tape? It seems to be able to do everything else.
Myth Busters test duct tape:
#2 6 years ago
Maybe WD-40 doesn't belong in a pinball machine, but what about duct tape in this case?
#3 6 years ago
Fiberglass is pretty easy to work with. Seems like a good fix, unless you find some Kevlar
Duct tape might hold it together, but it will still flex and move a bit IMO.
#4 6 years ago
After my second trunk broke I lined the inside lower edge with a foam insulating strip. Peel and stick. Its been good for many years now.
#5 6 years ago
Quoted from Taxman:
That did no good on mine, brand new one cracked in the first 10 games.
I plan on ordering another one and filling it smooth with Lexel and then the foam tape.
Lexel is some tough stuff and will stick better than fiberglass.
#6 6 years ago
Dead stop foam from PinBits will help fix this problem.
#7 6 years ago
I used the foam insulating strip on mine and have had no problems since.
#8 6 years ago
Quoted from Magic_Mike:
I lined the bottom edge all around with the dead stop foam and it kept mine like new. Some of the other foams were too "bouncy" and created too many air balls. Good luck.
#9 6 years ago
I just started another post looking for a better quality trunk. any suggestions
#10 6 years ago
Quoted from Shadow:
I'm guessing that you install the foam on the inside?
#11 6 years ago
Quoted from indypinhead:
Yes. My replacement trunk was good quality, durable material. But I don't recall where it came from. Good luck with this.
#12 6 years ago
I put Dynamat around the inside of mine years ago and it has never cracked.
#13 6 years ago
Some people call duct tape "chrome".
#14 6 years ago
Quoted from cal50:
? really?
#15 6 years ago
Quoted from blubboman:
That sounds like a great idea blubboman. Thanks for the input.
#16 6 years ago
I was the original poster fiberglassing the trunks - and guess what - its still perfect 3 years later
#17 6 years ago
Quoted from fusion301:
Can you post a procedure for dummies (e.g. me)? I do not even know what to go shopping for.
$ 14.00
Yorktown Parts and Equip
3D MODS
