New! Dark mode!
(Topic ID: 253478)
Reducing Arcing on Early SS Pin Flipper EOS and Cabinet Switches
By Pecos
1 year ago
  • 23 posts
  • 7 Pinsiders participating
  • Latest reply 1 year ago by Escapism
  • Topic is favorited by 12 Pinsiders
There have been 8 images uploaded to this topic. (View topic image gallery).
#1 1 year ago
I need to replace the flipper EOS switch on my left flipper of #mr-and-mrs-pac-man. As you can see, these contacts are fried. One of them was so damaged from arcing that it fell off! I want the contacts on the new switches I buy to last longer than these did. And I want to do it for all of my early SS pins. The question is, how can I reduce the arcing that damages the contacts, reduces the power to the flipper solenoids and causes weaker flipper performance?
In the picture above it appears like the metal from the lower contact was deposited onto the upper contact.
I have done some research about adding a capacitor to flipper EOS and cabinet switches. I have read that it only matters on later 80s games and newer that use parallel and not series solenoids. I have read that 2.2 uF capacitors on the EOS switches and .1 uF capacitors on the cabinet flipper switches will help. I have read that capacitors will not help at all on early SS pins. I don't know what to believe.
Bay Area Amusements has these "225K 50V Axial Capacitor - Early Williams EOS Switch Cap[s]"
http://bayareaamusements.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=CA-225
I don't think I have ever seen capacitors on early Williams pins and I haven't read anything about 225K uF capacitors used for flipper EOS switches.
I know I can upgrade the solenoids/flipper assemblies, but I have too many pins to do that. I don't need to eliminate the arcing entirely. I just want to reduce the amount wear on the contacts and reduce the amount of time that I have to polish these contacts with a Dremel and #443 wire brushes.
So, what is the real story here? Is there a way I can reduce the arcing? I want the pins I have on route to have powerful flippers and I don't want to have to spend a lot of money to do it.
#2 1 year ago
Bally flipper coils are parallel wound, just like the later Williams flipper coils. I unspooled one of them to verify this - there are 2 separate coil windings in the coil, with the hold coil first, then the primary coil closest to the bobbin. So any benefit to the flipper cap WMS uses will benefit the Bally cap as well.
#3 1 year ago
Capacitors across the EOS switches on these old solid state machines does improve the situation. I installed some 0.22uF 630V caps across the EOS switches on my old SS Bally a year ago and the arcing does not happen 2/3 of the time.
Notes:
50V capacitors are not sufficient for this application - they need to be rated in the hundreds of volts.
The capacitors need to be cable tied to the flipper frame, otherwise vibration from the flipper will cause the cap leads to break off at the solder joints.
If you look at the Bally schematics of this era, they list that Germany has 0.01uf 500volt capacitors across the EOS switches, though I believe this was done more for EMI reasons rather than wanting to prolong the life of the EOS switch though one goes in hand with the other.
#4 1 year ago
I thought the caps on williams were because they were 50V and not 25V, and the higher voltage increased arcing to the point where the caps were needed... Where did you see the parallel stuff?
I can confirm though, that even on a gottlieb (25V, presumably series wound?) that adding caps to the EOS does reduce arcing and EMI
#5 1 year ago
I did some research for non-pinball solutions and found that there is something called a 'snubber' circuit that reduces the arcing.
But first I want to understand what, exactly, is causing the arcing. Okay guys, please work with me here. I am not an electronics expert so I could have some of the following wrong. Please correct any mistakes I make.
Electricity flows into the coils (wires) of the high power flipper solenoid when the cabinet flipper button is pressed and when the EOS switch is closed. This creates a strong electro-magnetic field. The high power solenoid is deactivated when the flipper button is released or when the flipper button continues to be pushed and the flipper moves to the 'up' position, opening up the EOS switch. Current then flows to the low power solenoid (hold solenoid) when the EOS switch is opened. This is better explained here:
http://stevekulpa.net/pinball/bally_flipper1.htm
As I understand it, and, as I mentioned above, I may not understand it, this is how the arcing is created. The 43 to 48 Volts DC causes some arcing as the EOS switch opens. More arcing occurs when the current to the solenoid is turned off and the EOS switch closes. The electro-magnetic field collapses and that creates an electrical current with high voltages - much higher than the 43 to 48 Volts DC used to power the flipper solenoids causing arcing. This is why solenoids on solid state pinball machines have diodes. They prevent the solenoid voltage and the high 'kickback' voltage from reaching the sensitive transistors on the driver board that control the solenoids.
An RC 'snubbing' circuit can be added that will reduce the arcing. The circuit is simple with a capacitor in parallel to the EOS switch and a resistor in series with the capacitor, thus the name 'RC', not to be confused with model RC cars or planes. In layman's terms, that's me, the capacitor goes across the EOS switches and the resistor goes 'inline' next to the capacitor.
This page shows the circuit and some guidelines for determining the values of the resistor and capacitor:
https://www.idec.com/language/english/AppNotes/Relays/contact_circuit_protection.pdf
Resistor Value = .5 to 1 Ohm per Volt
Capacitor Value = .5 to 1 uF per Amp
Bally pins use 43VDC and Williams pins use 25VDC and, later, 50VDC. So, the resistor value should be 22 to 43 Ohms for Bally and 13 to 25 Ohms for Williams @25VDC and 25 to 50 Ohms for Williams @50VDC. I am unsure of the Wattage.
Flipper solenoids draw approximately 4.3A per Steve Kulpa (http://stevekulpa.net/pinball/bally_flipper1.htm). So the capacitor value should be 2.2 to 4.3 uF.
As quench mentioned:
Quoted from Quench:50V capacitors are not sufficient for this application - they need to be rated in the hundreds of volts.
Has anyone tried an RC 'snubber' circuit to reduce arcing? Results?
#6 1 year ago
Quoted from Pecos:
I did this in a homebrew because the arcing was causing EMI and resetting my mpu. Put it on the eos and cab switches, fixed the issue. Not sure why the Williams don't have a resistor though?
#7 1 year ago
Quoted from zacaj:
Well, Bally/Stern coils are 43 volts so not that much less than Williams.
The parallel winding on Bally coils I unwound one myself. They are 2 separate coils on the same bobbin, hence why they also have 4 wires to 3 terminals, and 2 diodes. Just like Williams later patented (great that people can patent preexisting tech). The info about parallel vs. series was from Clay's old guides/videos - he made one where he put the caps on the series wound and said it didn't decrease arcing, but in the video you can plainly see that it did.
I don't have a large problem with the pitting so I don't really worry about it on games that originally didn't have them.
#8 1 year ago
Quoted from slochar:
So it seems that it helps even on series wound 25v?
#9 1 year ago
Quoted from zacaj:
Apparently. I guess in an arcade or heavy play situation it might be good to have.
I guess the theory is that a back EMF spark is a back EMF spark it doesn't really matter what kind of coil it comes from either will wear away the EOS contact.
#10 1 year ago
Quoted from Pecos:
Not really, when the EOS switch is closing, the flipper circuit is already open circuit because you've released the flipper button so there is no return current path. The flipper button switch itself may arc though when opening.
Quoted from Pecos:
RC snubber circuit is useful when the contacts are arcing as they close.
However optimal reduction of arcing when switches are opening (as in the case of EOS switches) is better served with a capacitor alone. See your pdf:
Bit more of an explanation of RC snubbing here:
https://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=13C3236_AppNote&DocType=CS&DocLang=EN
Extract of the section:
#11 1 year ago
Several years ago, I put the 2.2 uf @ 250 capacitors on the end of stroke switches on an 8 Ball Deluxe as well as some .1 uf @ 500 volts ceramic disc capacitors on the cabinet flipper button switches. Made a big difference in the sparking for sure. Almost no sparking at all.
#12 1 year ago
I was trying to figure out the wattage needed for a resistor in the RC circuit and came up with this:
P = I x V
P = 4.3A x 25V
P (Watts) = 107.5
107.5 Watts? That can’t be right, can it?
Quoted from KenLayton:
Thanks Ken. That’s what I am going with.
#13 1 year ago
The full power of the flipper wouldn't be going through the resistor, so the 4.3A isn't applicable. Also it won't be 25V, since as discussed the arc is higher voltage (or at least you need a higher rated cap to handle it)
#14 1 year ago
Thanks guys for the good info!
I have ordered the following from GPE for the grand experiment:
Caps For Flipper EOS Switch:
Part Number CPA-2.2uF-250V Capacitor, Axial Polyester. These are the yellow caps, equivalent to the ones that Williams used.
Part Number CPR-2.2uF-250V-J Capacitor, Radial Polyester, 2.2uF, 250V, 5% Metalized Polyester Film. These are smaller and probably lighter.
Cap for Cabinet Flipper Switch:
Part Number CCD-0.1uF-500V-P5 Capacitor, Ceramic Disc, 0.1uF, 500V
Resistors For Both Flipper EOS Switch and Cabinet Switch:
Part Number RN70D33R2F, Resistor Metal Glaze, 33.2 Ohm, 3/4 Watt 1% These are really 2 Watt resistors downgraded to 3/4 Watt for Mil-Spec purposes.
Part Number RC5W-27-SQT Resistor, 27 Ohm, 5 Watt, SQT, in case 2 Watts isn't enough and parts begin to fry.
Both resistors are supposed to be flame resistant so I don't expect to be starting any fires. But there could be some smoke! Can you tell that I like to experiment?
I plan to somehow attach the caps to the EOS switch with zip ties, silicone or ???
I will be reporting back how well these parts reduce arcing in several different configurations.
#15 1 year ago
Quoted from Pecos:
Most people solder them on
The EOS bracket was originally taller to accommodate zip tying the cap to it, with a couple holes drilled in it to hold the zip tie. As noted, no resistors were used so it will be interesting to see what comes of your experiment with them.
#16 1 year ago
Oh, that’s bad, really bad. I like it!
#17 1 year ago
Look at a Flash schematic.It shows the values you need.
3 weeks later
#18 1 year ago
Quoted from Pecos:
Any luck with those resistors?
#19 1 year ago
Thanks for asking. I haven't gotten to it yet.
I got the parts from GPE:
I will try to get to the experimenting soon.
#20 1 year ago
If you are experimenting, use some alligator clip leads to connect everything. Saves a lot of time and effort soldering/unsoldering. Once you are happy with what works, then you can solder everything.
#21 1 year ago
I wouldn't trust the clips not to arc themselves...
#22 1 year ago
Good idea, but you are too late Ken. Experiment completed!
All tests were done using a Williams 1980 Black Knight.
Experiment 1: Part Number CPA-2.2uF-250V Capacitor, Axial Polyester, only.
There was a big, huge suppression of any arcing. There would occasionally be some visible arcing, less than without the capacitor, but most of the time there was little or no spark.
Experiment 2: Part Number CPA-2.2uF-250V Capacitor, Axial Polyester, only AND Part Number RN70D33R2F, Resistor Metal Glaze, 33.2 Ohm, 3/4 Watt 1% These are really 2 Watt resistors downgraded to 3/4 Watt for Mil-Spec purposes.
The arcing was much worse with the resistor and capacitor than with the capacitor only! It shouldn't be according to what I read about RC snubbing circuits, but that is what I saw and I'm sticking to it!
Quoted from zacaj:
During the second experiment the resistor didn't even get warm, even with constant flipping.
Quoted from Pecos:
Quoted from Quench:
I never really paid attention to this, but you are absolutely right quench. Thanks for the correction.
So, I will be putting the capacitors on all of my SS flipper EOS switches.
I just realized that I didn't test the flipper cabinet switches with the ceramic capacitors. Maybe I will do that experiment later.
#23 1 year ago
Thanks a stack.
$ 49.99
PinballElectronics.com
$ 9.00
$ 125.00
$ 149.00
Displays
PinballSolutions.eu
$ 40.00
Arcade Arts
$ 17.00
nvram.weebly.com
$ 149.95
Allteksystems
$ 90.00
