I'm working on my 2nd EM repair, a chicago coin red baron, I have an issue that should be easy but I've racked my brain and not getting there. When I hit the start button and the game tries to reset score reels, it only resets 3 positions on each reel (I get one "click, click, click"). If I turn off the power and back on again then hit start I get 3 more and so on until eventually I can get reset all the way.
I have pretty well determined that the problem is that the reset relay engages and stays engaged. I took a screw driver and stuck it in between the reset relay coil and armature to prevent it from engaging like it "wanted" to, and this allowed the scores to reset correctly, and the score reset relay continued clicking away until I removed the screwdriver and allowed the reset relay to engage stopping the process.
I know that the reset relay is powered by the E-1 switch on the bottom cam of the score motor thingy and it is a normally closed switch that opens with each 1/3 turn (I think) of the score motor, but I'm missing something since that isn't causing the reset relay to disengage plus it seems like something else should keep the reset on throughout a game to prevent resetting every time you score...???
I could just play by turning on/off 3 times for every game but sure would appreciate some advice on how to just get it right
