Quoted from CNKay:Well a dead short will almost blow any fuse instantly. Have you checked fuses ?
Pm sent as well.
Chris, thanks again for your help. I measured the rectifiers as you described. BR1 was acting flaky when placing the probes on them. All of the sudden the feature lamps started working. I shut down the game. I figured there was a connector issue. I pulled the whole assembly from the cab. Checked all connectors associated with feature lamps. All seemed good.
When to the rectifier board which was soldered in by previous owner. Some joints look iffy but still tight. While handling the board I noticed F1 fuse was a little loose. I had this problem recently with a -54 repro board. I measured the size of the fuse with calipers to make sure it was not one of those cheapy skinny fuses, it was exactly .25 in.
I'm not sure how the fuse clips became spread apart but I tightened it and now fuse is snug. While I have the power supply on table, I will resolder all the E connections.
Are you going to Pinfest?
Rich
