Thank you again for the advice, and it I the J3 plug that is causing f4 to blow, not J2 - sorry for the confusion. I was working on it while having a couple of beverages last evening - or at least that is my excuse for giving the wrong plug.
Here is what I have done so far. Disconnected displays, only J3 is plugged to the solenoid board.
* Replaced two bad transistors on the board q3 and q19 - fuse still blows
* disconnected flippers and cut a wire to the knocker - fuse still blows
* unplugged coin door from inside cabinet - fuse still blows
* rebuilt the solenoid board with full rebuild kits from BigDaddy Enterprises, checked continuity on the two large transisters with heat sinks to make sure they were not touching the heat sink - those things were a bear to install.
