(Topic ID: 196734)
Recreating a Booz Barometer
By futurepinhead
1 year ago
  • 74 posts
  • 21 Pinsiders participating
  • Latest reply 1 year ago by
  • Topic is favorited by 10 Pinsiders
There have been 20 images uploaded to this topic. (View topic image gallery).
There are 74 posts in this topic. You are on page 1 of 2.
#1 1 year ago
I've been wanting a Booz Barometer for one of my locations and all of the ones I was finding were running on a Nickel. I know there are quarter ones out there but I wasn't having luck finding them. There were other reasons I wasn't happy with the original design. The original one opened from the back and sits on a table. I wanted to be able to mount it to a wall. Also, when it was not being used, the lights would turn off and I was afraid people would think that it was turned off/not working. I borrowed an original from a friend and have been using it for measuring.
#2 1 year ago
The first hurdle was to make the bent rod because that was going to be the make it or break it problem. I got some help from my metal working friends to get it this far. We made many different segments and welded them together. I just now noticed the original bent rod is a little more straight, so that must mean the one I was using has been bent by someone along its life so I will have to fix that up a bit.
#3 1 year ago
This weekend, I built the box. It now swings open on the front and lowers down. This will allow me to mount to a wall. I still have not figured out how I am going to do the lock yet.
I was also lucky to find an original handle in great condition on Ebay.
#4 1 year ago
sweet! One of the few bars games I have wanted to find!
Build 5 of them and sell 4! Ill take 1.
#5 1 year ago
Quoted from Whysnow:
I might look into it when I get his one done, but it will likely be more expensive than you can find an original for. The big draw to me to create my own was the customizations I was needing for it to be a route game.
#6 1 year ago
I plan on having it run on a Raspberry Pi. It will need a switch that for the coin mech to start the game. Once the game is running, it will run the voltage through the handle. I also plan on music to come out of it during game play for the player to know a game is actually going. If someone drops a quarter in and leaves it alone, I don't want it to play continuously so I will have it on a countdown timer programmed into the Pi, something like 2 mins. I will have a buzzer indicating that you lost when you touch the rod. I am also contemplating having a last switch at the very end of the rod indicating you won. It might play another jingle when you win.
#7 1 year ago
Gosh, I trashed these by the hundreds in the early seventies...Staten Island Landfill!
Lots of fun, I have only the table top Novelty ones, which are still a blast!
#8 1 year ago
Quoted from OLDPINGUY:
Man, I haven't seen one sell for less than $150 in the years that I've been searching for one. Hindsight right?
#9 1 year ago
Quoted from futurepinhead:
I would route mine also. I have the perfect spot to put one of these!
#10 1 year ago
sounds great and like a very fun project!
#11 1 year ago
Logan Arcade has one of these out on the bar. The handle wire will fray and short at the base from use after a while. Be sure to reinforce that with your build. Picked up some very durable cable from a neon light repair shop that held up superbly.
#12 1 year ago
You guys really think there is a market?
It was one of 3 games I was considering production on, before I did LEDs.
What would work best....
Antique, Retro, LCD Screen Modern?, Multi themes?
Ive been collecting these since I was 9!!
Found one in the trash.
#13 1 year ago
I had one for a couple years and it was a lot of fun, more challenging than you would expect! I think a modern version would be really cool. Incorporating an LCD screen opens up worlds of possibilities.
#14 1 year ago
100% Anything for a quarter at the bar is great. Very simple to make I assume. I would put the money into some decent coding to have a few different games and make it multiplayer. Seems with a simple LCD screen you could have all the instruction you need.
Aside from that, sell me one of your older ones I will put it at a bar and give you the numbers so you know if it is marketable.
People like stuff like this and even more so if it does not take up much room and can play in a group.
#15 1 year ago
LCD screen is definitely planned at some point. I want to have a timed feature so it can have a High Score type screen. I probably would not incorporate initials on the high score, just the time.
There is definitely a market for these. I prefer physical type games so this is right up my alley.
I wanted to start off with a very simple design, hence this game, so I can learn how to code in Pi. I plan to make EM type games after I have a better grasp on coding.
#16 1 year ago
I sold all the coin op ones I had.....4 of them, $150 each about 3 years ago.
I have only "toy" versions. Not what you need.
I reached out to a Cabinet maker local, 4 years ago, and did a bunch of leg work... No LCD then, but no issue now.
Maybe I can find some of my old stuff still. Cleaning up my life and moving out of office.
Feeling better, not sure if I want to go back to work though.....
Maybe Op wants to Mass produce??
#18 1 year ago
I always wanted an original just for my own collection but a fresh updated version for route operation in my bar accounts would be awesome!Please include me on any future build plans,I would gladly pitch in or purchase finished ones!
#19 1 year ago
I can assure you that it does very well at a bar in a big city with a hipster neighborhood demo.
#20 1 year ago
I'm curious about the licensing possibilities not only with northwestern(The original manufacturer which I understand recently changed ownership) and future ones.I could see a "coors light" or multiple other beer brand art packages on new production ones that would be great.
#21 1 year ago
I think I need one but cha-ching. Decent ones go about $300.
Looks like punt return is the same thing.
#22 1 year ago
Quoted from Travish:
where? Ill pay that for a decent one.
#23 1 year ago
Quoted from Brian541:
I don't think many breweries would want their products associated with a drinking game any longer. This ain't 1950. For home use, sure. The Punt Return or something similar would work for location play.
#24 1 year ago
I just googled it and several auction sites popped up with sold listings. looks like a market for these.
#25 1 year ago
I'd take 1 too!
#26 1 year ago
I have mine mounted on e the wall and it works great, I just cut a piece of 1/2" plywood and mounted it to the wall and it screws right to that. Mine didn't have the original base. Works great and everyone has to try and beat it after we've been drinking
#27 1 year ago
I noticed many different games used the same bent rod. Here's a love tester I saw.
#28 1 year ago
I saw this thread and thought it was a,pretty neat idea to make one!
I tried, but only got as far as the booze and took a nap......it's called R and D
Really though, neat idea! Always wanted one of those too.
#29 1 year ago
Started the coding tonight. I had a friend helping me which was great since this is my first go around. So far, we've got it so it woll credit, once credited it will start the game and it won't end until you mess up and hit the bar. I didn't have a buzzer so I swapped that with an LED temporarily. Works great so far.
#30 1 year ago
As it sits now, it is identical to the original gameplay. But we are trying to think of a way to have a switch for it to recognize that it's in the start position, a switch to recognize it's in the finished position, add music, add a timer, and I'm thinking of adding a blinking LED behind the lamp post on the lower right artwork (poor man's attract mode)
#31 1 year ago
Since the game originally came out in the 50s, I am thinking about playing 5 or 6 different songs at random from the 50s. I'm leaning more toward instrumental only, but I'm not opposed to singing. This is just for me and testing right now so I am not worried about any licensing issues. Any suggestions?
#33 1 year ago
Tequila by The Champs
#34 1 year ago
Quoted from Thrillhouse:
Nice one. Definitely on the list.
#35 1 year ago
Anything Dick Dale is awesome and may fit the theme, Lets Go Trippin is a personal fav
#36 1 year ago
Dead Mans Curve, by Jan and Dean would be cool.
#37 1 year ago
Cool! This is something I was thinking of making after my next project. Now I can just sit back and relax.
Happy to help, if I can.
#38 1 year ago
$650 for the one you have pictured!
ebay.com link » Punt Return Football Arcade Trade Stimulator Nickel Machine Like Booz Barometer
#39 1 year ago
I have an Alky Meter I would sell. I am in Illinois. I'll get a pic this weekend
#40 1 year ago
I was going to say The Beatles Twist & Shout, but I believe that was around 63...
How about Chubby Checker's version of The Twist! (Late 50s ... like 58 or 59 I think).
#41 1 year ago
Thanks for the list of songs. I'll get them and add them to the next phase of coding. Right now, I am going to figure up a way to mount the Pi in the metal case and worry about getting the artwork.
#42 1 year ago
Quoted from meSz:
I didn't mean same thing as in price. I just meant looks like the exact same machine with a different theme/decals. $650 is WAY to steep for me but if one fell in my lap for $200 I would be all over it.
#43 1 year ago
I wasn't stating that at all! I just happened to be on eBay and noticed the one I was looking at was the one you had pictured so I provided the link! Yeah $650 is way steep!
There is a Booze one on eBay in so so shape but the seller is asking 350 for it, he came down to 300 but not sure it's worth the $300 in the state it's currently in!
#44 1 year ago
I tried completing the code by myself, it didn't go great, so I am having my friend come back out and give me another lesson.
#45 1 year ago
The second night of my friend helping to code went very well. Now we have the game where it won't do anything until it is credited. Once credited, it doesn't do anything until the handle is returned to inital starting point (no cheaters). Then once the start has been activated the game will start and you'll either win, or lose, or time out. The original had no way to determine if you won, but mine will have a switch at the far end as well.
I did the first couple coats of paint. Now, I didn't have an original to copy paint from so I had to go off of what the store had and compare it to online photos. I know its not perfect but I like it. The original, to me, seems a little more maroon whereas mine will be a little more burgandy, but it's going to look great. Here's what the first round looks like.
Also, here is a video of the coding prototype.
#46 1 year ago
Put Link Wray - Rumble on it. Cool idea, man!
#47 1 year ago
Very nice.
#48 1 year ago
looking good!
#49 1 year ago
Looking at the stock photos and the color I chose, I think the reds may be too similar. I'm supposed to be getting the art files this weekend and I'll be sending them to my designated art guy. Once I have the art next to it, I'll make a decision. I might have to go darker with the cabinet to separate the colors more.
#50 1 year ago
Art preview my friend did for me, scanned from an original. Also I have the hinge and locks installed.
CzTV Mods
$ 22.50
$ 69.99
$ 5,799.00
Operation Pinball
$ 12,500.00
Nitro Pinball Shop
Playfield - Plastics
Bright Lights Pinball
$ 2.50
Various Novelties
Pinball Wheezer
$ 9,500.00
$ 7.65
Cabinet Parts
Third Coast Pinball
$ 84.95
PinBoss Mods
$ 159.99
$ 229.99
$ 218.00
$ 369.00
$ 7,999.00
Classic Game Rooms
$ 45.00
Sparky Pinball
$ 499.99
Great American Pinball
Third Coast Pinball
