Quoted from Wharhed:Quick question - how do we know when/if our orders ship? I didn’t see anything on the web site to check status.
You get a notification by email, but I'm still waiting for amplifiers.
Steve ships fast after he has all your parts. I got mine in only a few days, and I STILL havent had time to install it. I have everything built, just need to load the sounds and install the license.
Order arrived. Thanks Steve. Couple of questions. Looks like one of the volume knobs was mounted on the wrong side of the circuit board from the factory. Are both amps suppose to be the same? Also do I need to have Linux installed on sd card partition before installing RasPiSound image that I downloaded?
74AF4985-2A35-4494-9F7E-E75AAD83D6C3 (resized).jpegQuoted from Bd700:Order arrived. Thanks Steve. Couple of questions. Looks like one of the volume knobs was mounted on the wrong side of the circuit board from the factory. Are both amps suppose to be the same? Also do I need to have Linux installed on sd card partition before installing RasPiSound image that I downloaded?
You will have to fix that potentiometer, that’s a bummer. They should be identical.
And no just image your SDCard with the raspisound image using Etcher or something. You do not need to do anything additional
Wow that's weird. They should be the same of course, hope you can fix this. Never saw this before
Quoted from Bd700:That’s what figured. Thanks so much!
Are those soldered? Mine came unassembled, are you sure they’re really stuck together? Just figured I’d ask
Quoted from Bd700:Yep, they were soldered on in individually sealed packages.
Dang. Sorry man
Ok. I am waiting for my board but I have been reading etc. A buddy of mine is having trouble setting his up and I have been looking through trying to get answers. For a project like this and especially if your selling something, the documentation on how to make this work is just not there. There needs to be a step by step instructions on what to do to set this up. I think that there are assumptions made as to what everyone knows.
Can someone post a step by step guide on how to set this up from step zero. I have a board In front of me. What do I load on the Pi, how do I load it? Etc . There are too many variables to figure out on your own.
We need some help. I would install this on several of my games but if I can’t get it working then I will just move on.
I think most of the pictures are with either the old board or Pi zero.
HELP
Quoted from Lonzo:Ok. I am waiting for my board but I have been reading etc. A buddy of mine is having trouble setting his up and I have been looking through trying to get answers. For a project like this and especially if your selling something, the documentation on how to make this work is just not there. There needs to be a step by step instructions on what to do to set this up. I think that there are assumptions made as to what everyone knows.
HELP
Did you read the how-to on pinball-mods.de?
1. You need to put an image onto the sd card. You can get it for free in the shop at go-dmd.de. there's a couple of image writer programs like win32diskimager etc.
2. After imaging is done you will find two partitions one with Linux for the pi (the firmware). One windows readable partition for sounds and config. On a windows machine you will only see this partition.
3. Copy at least one sound set and do some basic configuration e.g. setup vendor setting for your machine (see how-to).
4. Do a try run. Connect some speaker or maybe only earphones to pi audio jack (or speaker outlets of the amplifiers) and power the thing up. You should a boot sound and some announcements (including serial number to use for licensing).
5. If you going to use sound sets from pinsound, these are scrambled most of the time. You can recognize this as the folders have big mixed numbers in the folder name. If so retrieve a descrambling config file from pinball-mods.de download section. There's one per sound set. If you don't find yours, give me a call, I'll create it.
6. Connect it to the real machine, by connecting the ribbon cable and do another test. If it works out go ahead and install it.
7. All kits 2 and newer need 12v power supply. I recommend a new separate switched power supply, but to connect those you need to touch main power, which is not everybody's taste. Alternatively you can draw power from the old power supply from the soundcard.
Hope this helps.
/Steve
If it helps at all, I've started to document the process from the receipt of the 2.x kit to the install in my Jurassic Park. I can share it with everyone on here once I'm done.
Quoted from Wharhed:If it helps at all, I've started to document the process from the receipt of the 2.x kit to the install in my Jurassic Park. I can share it with everyone on here once I'm done.
That would be great. Thank you.
Here's a real rough draft of where I'm at right now. Toward the last two steps, I'm make some assumptions as I didn't see anything about where the translation / descrambling file goes. I'll continue to update this as I work through the install on my end. I'm sure I'll have more questions for Steve BTW - Thanks again for making this possible Steve!
Things you’ll need before you start:
• A completely built 2.x Raspisound board
• 12v DC power supply
• 1x 6” USB micro to USB Male adapter
• 1x USB Sound Adapter
• 1x 6” Male to Male 3.5mm Stereo cable
• 1x Raspberry PI Zero (Standard or Wifi Version)
• 1x 16GB Micro SD Card
• 1x Micro SD adapter (I’m using a USB to Micro SD Adapter)
• The most current version of Raspisound firmware for the Raspberry PI Zero from https://go-dmd.de/produkt/raspberry-pinsound-image/
o At the time of this document, V1.14 is the most current
o V1.14 File Name - raspisound-zero-v1.14.img.xz
• A disk imaging utility. I use Windows and have found Win32DiskImager to be easy to use and it’s free
o https://sourceforge.net/projects/win32diskimager/files/Archive/win32diskimager-1.0.0-install.exe/download
• 7zip (for extracting the .img file from the .xz archive)
o https://www.7-zip.org/download.html
Setting up the Micro SD card
• Once you have the most current raspisound-zero firmware, open the archive with 7zip and extract the .img file to a folder like your desktop.
o ** This will expand to roughly 15GB
• Connect your Micro SD card to your PC and wait for Windows to install the “drive” and assign it a letter
o Take note of the drive letter as you will need it for the next step
• Open the Win32 Imager software
o Using the “Device” drop down at the far right, select the drive letter that contains your Micro SD card
o Click on the folder icon to the left of the “Device” drop down to browse to and select the raspisound-zero-v1.xx.img file
o Click “Write” to start the process of writing the image to the Micro SD card. This will take anywhere from 10-20 minutes
• Once you’ve successfully written the raspisound-zero-v1.xx.img file to your Micro SD card, you will get a message from Win32DiskImager saying that it was successful, and Windows will shortly after ask you if you want to format the newly discovered drive
o Click NO
• I downloaded the “JP OST Endprodukt” soundtrack from the Pinside community
o Since this is already a known soundtrack that needs to be descrambled, go to https://pinball-mods.de/downloads/ and download the corresponding file. In my case, the downloaded file was “config.raspisnd3.zip”
• Open Windows file explorer, and browse to the drive labeled “PINSOUND”
o Browse to “Data” and then “Sound”
• Extract the “JP OST Endprodukt” zip file to the “Sound” folder and rename the folder to which position you’d like it in the selection
o In my case, Jurassic Park was extracted to <Drive Letter>\data\sound\JP_OST_Endprodukt and I renamed the folder to <Drive Letter>\data\sound\1
o Extract the contents of the “config.raspisnd3.zip” file to the newly renamed folder from the step above
** MORE STEPS NEEDED STILL **
• Purchase your license from - https://go-dmd.de/produkt/10955/
Resources
https://pinball-mods.de/2017/01/27/new-pinball-sound-for-de/
https://pinball-mods.de/2017/12/19/howto-for-rasberry-pinball-sound/
http://rbelmont.mameworld.info/?page_id=223
https://pinside.com/pinball/forum/topic/rebuilding-sound-for-de-jurassic-park-using-a-pi/page/3#post-4562904
Pics of 2.1x board assembly - https://pinside.com/pinball/forum/topic/rebuilding-sound-for-de-jurassic-park-using-a-pi/page/5#post-4607615
Thanks for the instructions! Should the pi boot at this point Wharhed? Mine doesn’t, I just get a red blinking led.
Quoted from Bd700:Thanks for the instructions! Should the pi boot at this point Wharhed? Mine doesn’t, I just get a red blinking led.
Of course it should. You should even get starting RasPiSound announcements if some speaker is attached.
Check SD card. Did you download the right image? There's two different ones for PiZero or Pi3.
/Steve
Quoted from steve45:Of course it should. You should even get starting RasPiSound announcements if some speaker is attached.
/Steve
I did but I’ll download it again just to make sure. I just got another sd card to try as well.
Thanks,
Jay
Quoted from steve45:For some of the inspired testing guys:
there is a windows executable over here:
https://mega.nz/#!hshyQADI!5mVzvbErm...vDShDOK1z1v0ak
It's basically the RasPiSound "firmware" running on a windows host computer.
Of course you cannot connect the real machine to this exe running on windows, but to test the soundset and the config it's still suitable.
You can start it like: "despi.exe -d <basepath to soundsets>".
Its important to include .exe at the end, in order to find and validate the signature.
You can control sound effects and background music via keyboard and also playback recordings.
A simple "despi.exe -h" produces some help text.
Keyboard commands:
Digits -> entering sound number.
p -> play
+ oder - -> Volume up / down
n -> soundset 1
m -> soundset 2
q -> quit
d -> dump current state
All config files are read and written like from the real "firmware" of RasPiSound running on a PI in a real machine.
Logfile output is written to the console.
And not to forget: its a windows cmdline executable, so you need to start a shell "cmd.exe" first and use it from there.
Thx SteveAdded 103 days ago: updated link: https://mega.nz/#!hshyQADI!5mVzvbErmBi03OPW_8qOS_70Q9V-NvDShDOK1z1v0ak
Steve,
Could you provide the current link to this program ??
I want to test the sounds for Lord of the rings, because I bought the adapter
Quoted from fly:Steve,
Sorry I accidently deleted the upload. Here is the new link https://mega.nz/#!5w43yaiA!N1h6-RJqMaesj9utLYDqwcu7R1kgHOISBGya6Hgo88A
Version for this exe is still 1.13.
/Steve
Thank you Steve for Link,
I can not start after clicking on despi.exe for just a black screen and nothing
Quoted from fly:Thank you Steve for Link,
This is a command line tool. First start cmd.exe and then despi.exe.
/Steve
I’ve got mine working enough to tell me it’s running v1.14, Data East mode and the serial number! However, when it gets to the point where it uses sound set 1, all I get is a oscillating feedback like sound and the serial number repeating. I’m thinking something isn’t mapped correctly for the sounds.
I did leave the config.pinsound in the root of the \1\ folder - would that affect it?
What’s the next step?
Hi There Wharhed
To me it sounds like the licence is Missing? Did you purchase a licence file at the go-dmd shop?
After I got the key file from Steve, mine stopped announcing the serial number.
And the placement of your config.raspisnd is placed correctly in the /1/ folder. Note that it is actually no longer required that you name the folders 1, 2 and so on. So instead of /1 it could be something like /IJ_Original
So the config.raspisnd needs to contain the hash mappings and if needed gain and ducking info and be placed like this:
/data/sound/SOUNDSET_NAME/config.raspisnd
And the other more general config file containing vendor info, preload options and so on is called raspisnd.ini and needs to be placed like this:
/data/sound/raspisnd.ini
But start by making sure you have purchased a valid key file via the link above, and placed it in the /data folder.
Hope this helps
Quoted from Phantasize:Hi There Wharhed
Hope this helps
I get that it will continue to announce the serial number and say demo mode, but I didn't think I was required to have the license loaded to have the sound files function. Also, when I went through his documentation post, it said numbers, but either way is fine for me. In the log below, it looks like it found the files and the config.raspisnd.
steve - One thing, I'm using a USB soundbar at the moment as my USB sound card seems to have walked away :/. Also, I snagged the log (below). Is there anything you can see any obvious errors that would affect this?
Log file - https://pastebin.com/8yQpZSbk
Quoted from Wharhed:I get that it will continue to announce the serial number and say demo mode, but I didn't think I was required to have the license loaded to have the sound files function. Also, when I went through his documentation post, it said numbers, but either way is fine for me. In the log below, it looks like it found the files and the config.raspisnd.
Steve - One thing, I'm using a USB soundbar at the moment as my USB sound card seems to have walked away :/. Also, I snagged the log (below). Is there anything you can see any obvious errors that would affect this?
___________________
2018-08-14 18:42:33.108 INFO [main] [despi.c:488] RasPinSound starting, version 1.14, serial: 464595793
2018-08-14 18:42:33.109 INFO [main] [despi.c:493] loading settings from .pisound2
2018-08-14 18:42:33.314 INFO [verifyKey] [crypt.c:208] trying to load key from 464595793.key
2018-08-14 18:42:33.374 ERROR [readFromFile] [crypt.c:68] could not read 464595793.key
2018-08-14 18:42:33.439 DEBUG [readConfig] [fileutil.c:41] reading config from: /boot/data/sound/raspisound.ini
2018-08-14 18:42:33.447 WARN [readConfig] [fileutil.c:77] config raspisound.ini not found in /boot/data/sound
2018-08-14 18:42:33.447 DEBUG [dumpConfig] [despi.c:236] say_version = 1
2018-08-14 18:42:33.447 DEBUG [dumpConfig] [despi.c:236] say_preload = 1
2018-08-14 18:42:33.447 DEBUG [dumpConfig] [despi.c:236] play_boot = 1
2018-08-14 18:42:33.447 DEBUG [dumpConfig] [despi.c:236] preload = 1
2018-08-14 18:42:33.447 DEBUG [dumpConfig] [despi.c:236] log_level = 9
2018-08-14 18:42:33.447 DEBUG [dumpConfig] [despi.c:236] vendor = 0
2018-08-14 18:42:33.447 DEBUG [dumpConfig] [despi.c:236] sample_pool_size = 0
2018-08-14 18:42:33.447 DEBUG [dumpConfig] [despi.c:236] preload_threshold = -1
2018-08-14 18:42:33.447 DEBUG [dumpConfig] [despi.c:236] attract_timeout = 60000
2018-08-14 18:42:33.447 DEBUG [dumpConfig] [despi.c:236] shaker_active_low = 0
2018-08-14 18:42:33.447 DEBUG [dumpConfig] [despi.c:236] suppress_repeated = 0
2018-08-14 18:42:33.447 DEBUG [dumpConfig] [despi.c:236] sound_device = 0
2018-08-14 18:42:33.447 DEBUG [dumpConfig] [despi.c:236] say_mode = 1
2018-08-14 18:42:33.447 DEBUG [main] [despi.c:522] Env for audio: hw,0
2018-08-14 18:42:33.448 DEBUG [dumpAudioDevices] [despi.c:213] Alsa sound info (/proc/asound/cards)
2018-08-14 18:42:33.448 DEBUG [dumpFile] [despi.c:203] 0 [ALSA ]: bcm2835 - bcm2835 ALSA
2018-08-14 18:42:33.448 DEBUG [dumpFile] [despi.c:203] bcm2835 ALSA
2018-08-14 18:42:33.448 DEBUG [dumpFile] [despi.c:203] 1 [SoundBar ]: USB-Audio - Dell AC511 USB SoundBar
2018-08-14 18:42:33.448 DEBUG [dumpFile] [despi.c:203] Dell Dell AC511 USB SoundBar at usb-20980000.usb-1.1, full speed
2018-08-14 18:42:33.448 DEBUG [dumpAudioDevices] [despi.c:225] Info for /proc/asound/card0/pcm0p/info
2018-08-14 18:42:33.449 DEBUG [dumpFile] [despi.c:203] card: 0
2018-08-14 18:42:33.449 DEBUG [dumpFile] [despi.c:203] device: 0
2018-08-14 18:42:33.449 DEBUG [dumpFile] [despi.c:203] subdevice: 0
2018-08-14 18:42:33.449 DEBUG [dumpFile] [despi.c:203] stream: PLAYBACK
2018-08-14 18:42:33.449 DEBUG [dumpFile] [despi.c:203] id: bcm2835 ALSA
2018-08-14 18:42:33.449 DEBUG [dumpFile] [despi.c:203] name: bcm2835 ALSA
2018-08-14 18:42:33.449 DEBUG [dumpFile] [despi.c:203] subname: subdevice #0
2018-08-14 18:42:33.449 DEBUG [dumpFile] [despi.c:203] class: 0
2018-08-14 18:42:33.449 DEBUG [dumpFile] [despi.c:203] subclass: 0
2018-08-14 18:42:33.449 DEBUG [dumpFile] [despi.c:203] subdevices_count: 8
2018-08-14 18:42:33.449 DEBUG [dumpFile] [despi.c:203] subdevices_avail: 8
2018-08-14 18:42:33.449 DEBUG [dumpAudioDevices] [despi.c:225] Info for /proc/asound/card0/pcm1p/info
2018-08-14 18:42:33.449 DEBUG [dumpFile] [despi.c:203] device: 1
2018-08-14 18:42:33.450 DEBUG [dumpFile] [despi.c:203] subdevice: 0
2018-08-14 18:42:33.450 DEBUG [dumpFile] [despi.c:203] stream: PLAYBACK
2018-08-14 18:42:33.450 DEBUG [dumpFile] [despi.c:203] id: bcm2835 ALSA
2018-08-14 18:42:33.450 DEBUG [dumpFile] [despi.c:203] name: bcm2835 IEC958/HDMI
2018-08-14 18:42:33.450 DEBUG [dumpFile] [despi.c:203] subname: subdevice #0
2018-08-14 18:42:33.450 DEBUG [dumpFile] [despi.c:203] class: 0
2018-08-14 18:42:33.450 DEBUG [dumpFile] [despi.c:203] subclass: 0
2018-08-14 18:42:33.450 DEBUG [dumpFile] [despi.c:203] subdevices_count: 1
2018-08-14 18:42:33.450 DEBUG [dumpFile] [despi.c:203] subdevices_avail: 1
2018-08-14 18:42:33.450 DEBUG [dumpAudioDevices] [despi.c:225] Info for /proc/asound/card1/pcm0p/info
2018-08-14 18:42:33.450 DEBUG [dumpFile] [despi.c:203] card: 1
2018-08-14 18:42:33.451 DEBUG [dumpFile] [despi.c:203] device: 0
2018-08-14 18:42:33.451 DEBUG [dumpFile] [despi.c:203] subdevice: 0
2018-08-14 18:42:33.451 DEBUG [dumpFile] [despi.c:203] stream: PLAYBACK
2018-08-14 18:42:33.451 DEBUG [dumpFile] [despi.c:203] id: USB Audio
2018-08-14 18:42:33.451 DEBUG [dumpFile] [despi.c:203] name: USB Audio
2018-08-14 18:42:33.451 DEBUG [dumpFile] [despi.c:203] subname: subdevice #0
2018-08-14 18:42:33.451 DEBUG [dumpFile] [despi.c:203] class: 0
2018-08-14 18:42:33.451 DEBUG [dumpFile] [despi.c:203] subclass: 0
2018-08-14 18:42:33.451 DEBUG [dumpFile] [despi.c:203] subdevices_count: 1
2018-08-14 18:42:33.451 DEBUG [dumpFile] [despi.c:203] subdevices_avail: 1
2018-08-14 18:42:34.516 DEBUG [soundInit] [sdl_sound.c:429] looking for custom boot: '/boot/data/sound/boot.ogg'
2018-08-14 18:42:34.527 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/boot.ogg
2018-08-14 18:42:36.885 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/version.ogg
2018-08-14 18:42:37.648 DEBUG [sayNumber] [sdl_sound.c:354] buf: 1, len 1
2018-08-14 18:42:37.648 DEBUG [sayNumber] [sdl_sound.c:358] play: 1.ogg
2018-08-14 18:42:37.653 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/1.ogg
2018-08-14 18:42:38.677 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/point.ogg
2018-08-14 18:42:39.320 DEBUG [sayNumber] [sdl_sound.c:354] buf: 1, len 1
2018-08-14 18:42:39.320 DEBUG [sayNumber] [sdl_sound.c:358] play: 1.ogg
2018-08-14 18:42:39.324 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/1.ogg
2018-08-14 18:42:40.342 DEBUG [sayNumber] [sdl_sound.c:354] buf: 4, len 1
2018-08-14 18:42:40.342 DEBUG [sayNumber] [sdl_sound.c:358] play: 4.ogg
2018-08-14 18:42:40.348 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/4.ogg
2018-08-14 18:42:41.762 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/mode.ogg
2018-08-14 18:42:42.275 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/dataeast.ogg
2018-08-14 18:42:43.313 INFO [main] [despi.c:533] /home/pi/despi/despi is running with trial license.
2018-08-14 18:42:43.323 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/running-with.ogg
2018-08-14 18:42:45.198 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/trial-license.ogg
2018-08-14 18:42:46.407 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/serialno.ogg
2018-08-14 18:42:47.446 DEBUG [sayNumber] [sdl_sound.c:354] buf: 464595793, len 9
2018-08-14 18:42:47.446 DEBUG [sayNumber] [sdl_sound.c:358] play: 4.ogg
2018-08-14 18:42:47.451 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/4.ogg
2018-08-14 18:42:48.609 DEBUG [sayNumber] [sdl_sound.c:358] play: 6.ogg
2018-08-14 18:42:48.616 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/6.ogg
2018-08-14 18:42:49.863 DEBUG [sayNumber] [sdl_sound.c:358] play: 4.ogg
2018-08-14 18:42:49.868 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/4.ogg
2018-08-14 18:42:51.023 DEBUG [sayNumber] [sdl_sound.c:358] play: 5.ogg
2018-08-14 18:42:51.030 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/5.ogg
2018-08-14 18:42:52.393 DEBUG [sayNumber] [sdl_sound.c:358] play: 9.ogg
2018-08-14 18:42:52.400 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/9.ogg
2018-08-14 18:42:53.670 DEBUG [sayNumber] [sdl_sound.c:358] play: 5.ogg
2018-08-14 18:42:53.676 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/5.ogg
2018-08-14 18:42:55.040 DEBUG [sayNumber] [sdl_sound.c:358] play: 7.ogg
2018-08-14 18:42:55.047 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/7.ogg
2018-08-14 18:42:56.177 DEBUG [sayNumber] [sdl_sound.c:358] play: 9.ogg
2018-08-14 18:42:56.180 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/9.ogg
2018-08-14 18:42:57.455 DEBUG [sayNumber] [sdl_sound.c:358] play: 3.ogg
2018-08-14 18:42:57.462 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/3.ogg
2018-08-14 18:42:58.545 INFO [searchSoundSets] [sound_util.c:368] searching for soundsets at: /boot/data/sound
2018-08-14 18:42:58.546 INFO [searchSoundSets] [sound_util.c:376] found soundset 1 at: /boot/data/sound/1
2018-08-14 18:42:58.546 INFO [searchSoundSets] [sound_util.c:385] maxSoundSets: 1
2018-08-14 18:42:58.547 INFO [main] [despi.c:556] max soundsets: 1
2018-08-14 18:42:58.550 DEBUG [loadHashMapping] [sound_util.c:405] loading hashes from /boot/data/sound/1/config.raspisnd
2018-08-14 18:42:58.556 DEBUG [loadHashMapping] [sound_util.c:415] loaded 220 hashes
2018-08-14 18:42:58.556 DEBUG [readConfig] [fileutil.c:41] reading config from: /boot/data/sound/1/config.ini
2018-08-14 18:42:58.556 WARN [readConfig] [fileutil.c:77] config config.ini not found in /boot/data/sound/1
2018-08-14 18:42:58.557 DEBUG [readConfig] [fileutil.c:41] reading config from: /boot/data/sound/1/config.raspisnd
2018-08-14 18:42:58.557 DEBUG [readConfig] [fileutil.c:47] read config.raspisnd from /boot/data/sound/1/config.raspisnd
2018-08-14 18:42:58.557 DEBUG [readConfig] [fileutil.c:66] read value for ducking_voice = 65
2018-08-14 18:42:58.557 DEBUG [readConfig] [fileutil.c:66] read value for ducking_sfx = 90
2018-08-14 18:42:58.557 DEBUG [readConfig] [fileutil.c:66] read value for gain_music = 13
2018-08-14 18:42:58.558 DEBUG [readConfig] [fileutil.c:66] read value for gain_sfx = 16
2018-08-14 18:42:58.558 DEBUG [readConfig] [fileutil.c:66] read value for gain_voice = 28
2018-08-14 18:42:58.558 DEBUG [readConfig] [fileutil.c:66] read value for gain_jingle = 11
2018-08-14 18:42:58.558 DEBUG [readConfig] [fileutil.c:66] read value for gain_single = 15
2018-08-14 18:42:58.559 DEBUG [readSoundConfig] [sound_util.c:322] type ducking activated
2018-08-14 18:42:58.563 DEBUG [scan] [sound_util.c:240] gain for /boot/data/sound/1/jingle is 11
2018-08-14 18:42:58.689 DEBUG [scan] [sound_util.c:240] gain for /boot/data/sound/1/music is 13
2018-08-14 18:42:58.991 DEBUG [scan] [sound_util.c:240] gain for /boot/data/sound/1/sfx is 16
2018-08-14 18:42:59.569 DEBUG [scan] [sound_util.c:240] gain for /boot/data/sound/1/voice is 28
2018-08-14 18:42:59.870 DEBUG [initSamples] [sound_util.c:464] sample 0000000000 0x00000000 0xcb523460, type: music, gain: 20, name: system_failure_theme, path: /boot/data/sound/1/music/3411162208-system_failure_theme/System Failure.ogg
2018-08-14 18:42:59.871 DEBUG [initSamples] [sound_util.c:464] sample 0000000001 0x00000001 0x6339e17c, type: music, gain: 15, name: main_theme, path: /boot/data/sound/1/music/1664737660-main_theme/Main Theme.ogg
2018-08-14 18:42:59.871 DEBUG [initSamples] [sound_util.c:464] sample 0000000002 0x00000002 0x3d389061, type: music, gain: 15, name: mosquito_theme, path: /boot/data/sound/1/music/1027117153-mosquito_theme/mosquito theme.ogg
2018-08-14 18:42:59.871 DEBUG [initSamples] [sound_util.c:464] sample 0000000003 0x00000003 0x8bf80812, type: music, gain: 13, name: tri-ball-ready, path: /boot/data/sound/1/music/2348288018-tri-ball-ready/Triball Ready.ogg
2018-08-14 18:42:59.871 DEBUG [initSamples] [sound_util.c:464] sample 0000000004 0x00000004 0xd2375693, type: music, gain: 15, name: tri-ball-Theme, path: /boot/data/sound/1/music/3526842003-tri-ball-Theme/Triball Theme.ogg
2018-08-14 18:42:59.871 DEBUG [initSamples] [sound_util.c:464] sample 0000000005 0x00000005 0xb05e91c3, type: music, gain: 12, name: shooter_theme, path: /boot/data/sound/1/music/2958987715-shooter_theme/Welcome To Jurassic Park.ogg
2018-08-14 18:42:59.871 DEBUG [initSamples] [sound_util.c:464] sample 0000000006 0x00000006 0x75dbd7a7, type: music, gain: 15, name: welcome_jurassic_park, path: /boot/data/sound/1/music/1977341863-welcome_jurassic_park/Welcome To Jurassic Park.ogg
2018-08-14 18:42:59.871 DEBUG [initSamples] [sound_util.c:464] sample 0000000007 0x00000007 0x9494db06, type: music, gain: 15, name: jackpot_theme, path: /boot/data/sound/1/music/2492783366-jackpot_theme/Jackpot Theme.ogg
2018-08-14 18:42:59.871 DEBUG [initSamples] [sound_util.c:464] sample 0000000008 0x00000008 0x77cb56c6, type: music, gain: 15, name: jackpot_theme, path: /boot/data/sound/1/music/2009814726-jackpot_theme/Jackpot Theme.ogg
2018-08-14 18:42:59.871 DEBUG [initSamples] [sound_util.c:464] sample 0000000009 0x00000009 0x219a39df, type: music, gain: 15, name: multiball_ready, path: /boot/data/sound/1/music/0563755487-multiball_ready/Multiball Ready.ogg
2018-08-14 18:42:59.871 DEBUG [initSamples] [sound_util.c:464] sample 0000000010 0x0000000a 0xae4d9b93, type: music, gain: 15, name: multiball_ready, path: /boot/data/sound/1/music/2924321683-multiball_ready/multibal__LEGACY.ogg
2018-08-14 18:42:59.871 DEBUG [initSamples] [sound_util.c:464] sample 0000000011 0x0000000b 0xfa2f0a5e, type: music, gain: 15, name: electric_fence, path: /boot/data/sound/1/music/4197386846-electric_fence/Electric Fence Theme.ogg
2018-08-14 18:42:59.871 DEBUG [initSamples] [sound_util.c:464] sample 0000000012 0x0000000c 0xca953e69, type: music, gain: 15, name: Chaos, path: /boot/data/sound/1/music/3398778473-Chaos/Chaos.ogg
2018-08-14 18:42:59.871 DEBUG [initSamples] [sound_util.c:464] sample 0000000013 0x0000000d 0x7d164621, type: music, gain: 13, name: end_of_ball_bonus_theme, path: /boot/data/sound/1/music/2098611745-end_of_ball_bonus_theme/End Of Ball Bonus.ogg
2018-08-14 18:42:59.871 DEBUG [initSamples] [sound_util.c:464] sample 0000000015 0x0000000f 0x230bf57b, type: music, gain: 12, name: the_end_party, path: /boot/data/sound/1/music/0587986299-the_end_party/The End Soft.ogg
2018-08-14 18:42:59.872 DEBUG [initSamples] [sound_util.c:464] sample 0000000017 0x00000011 0xc6c8bb3c, type: music, gain: 11, name: Stampede, path: /boot/data/sound/1/music/3335043900-Stampede/Stampede.ogg
2018-08-14 18:42:59.872 DEBUG [initSamples] [sound_util.c:464] sample 0000000019 0x00000013 0x41aa6f69, type: music, gain: 13, name: electric_fence, path: /boot/data/sound/1/music/1101688681-electric_fence/Electric Fence Theme.ogg
2018-08-14 18:42:59.872 DEBUG [initSamples] [sound_util.c:464] sample 0000000021 0x00000015 0xca56a034, type: music, gain: 15, name: feed-trex, path: /boot/data/sound/1/music/3394674740-feed-trex/Feed Trex.ogg
2018-08-14 18:42:59.872 DEBUG [initSamples] [sound_util.c:464] sample 0000000022 0x00000016 0x187a9097, type: music, gain: 15, name: main_theme, path: /boot/data/sound/1/music/0410685591-main_theme/Main Theme.ogg
2018-08-14 18:42:59.872 DEBUG [initSamples] [sound_util.c:464] sample 0000000025 0x00000019 0x6a7ce679, type: music, gain: 15, name: mr_dna_theme, path: /boot/data/sound/1/music/1786570361-mr_dna_theme/Mr Dna.ogg
2018-08-14 18:42:59.872 DEBUG [initSamples] [sound_util.c:464] sample 0000000027 0x0000001b 0x724856d8, type: music, gain: 15, name: never_heard_it, path: /boot/data/sound/1/music/1917343448-never_heard_it/never_he__LEGACY.ogg
2018-08-14 18:42:59.872 DEBUG [initSamples] [sound_util.c:464] sample 0000000029 0x0000001d 0x715c5245, type: music, gain: 15, name: Escape, path: /boot/data/sound/1/music/1901875781-Escape/Escape.ogg
2018-08-14 18:42:59.872 DEBUG [initSamples] [sound_util.c:464] sample 0000000047 0x0000002f 0x15387d17, type: music, gain: 15, name: never_heard_it, path: /boot/data/sound/1/music/0356023575-never_heard_it/never_he__LEGACY.ogg
2018-08-14 18:42:59.872 DEBUG [initSamples] [sound_util.c:464] sample 0000000049 0x00000031 0x6cdb8646, type: music, gain: 15, name: runaway, path: /boot/data/sound/1/music/1826326086-runaway/run.ogg
2018-08-14 18:42:59.872 DEBUG [initSamples] [sound_util.c:464] sample 0000000051 0x00000033 0xb1333b5d, type: music, gain: 15, name: bone, path: /boot/data/sound/1/music/2972924765-bone busting/Bone Busting.ogg
2018-08-14 18:42:59.872 DEBUG [initSamples] [sound_util.c:464] sample 0000000053 0x00000035 0x2aab4a2a, type: music, gain: 14, name: 2, path: /boot/data/sound/1/music/0715868714-2 ball retry/2 Ball Retry.ogg
2018-08-14 18:42:59.872 DEBUG [initSamples] [sound_util.c:464] sample 0000000055 0x00000037 0x4d5a9103, type: music, gain: 15, name: system, path: /boot/data/sound/1/music/1297780995-system boot/System Boot.ogg
2018-08-14 18:42:59.872 DEBUG [initSamples] [sound_util.c:464] sample 0000000057 0x00000039 0x34b155b3, type: music, gain: 15, name: raptor_rampage, path: /boot/data/sound/1/music/0884037043-raptor_rampage/Raptor Rampage.ogg
2018-08-14 18:42:59.872 DEBUG [initSamples] [sound_util.c:464] sample 0000000059 0x0000003b 0x3c6516c2, type: music, gain: 13, name: mosquito_theme_with_mosquito, path: /boot/data/sound/1/music/1013257922-mosquito_theme_with_mosquito/mosquito theme with mosquito.ogg
2018-08-14 18:42:59.873 DEBUG [initSamples] [sound_util.c:464] sample 0000000061 0x0000003d 0xc591514b, type: music, gain: 16, name: Spitter, path: /boot/data/sound/1/music/3314635083-Spitter/Spitter.ogg
2018-08-14 18:42:59.873 DEBUG [initSamples] [sound_util.c:464] sample 0000000062 0x0000003e 0xce6dd981, type: music, gain: 15, name: the_end_party, path: /boot/data/sound/1/music/3463305601-the_end_party/The End Power.ogg
2018-08-14 18:42:59.873 DEBUG [initSamples] [sound_util.c:464] sample 0000000063 0x0000003f 0x246b5b10, type: sfx, gain: 6, name: car_starter, path: /boot/data/sound/1/sfx/0611015440-car_starter/Car Starter.ogg
2018-08-14 18:42:59.873 DEBUG [initSamples] [sound_util.c:464] sample 0000000064 0x00000040 0x53be50c1, type: sfx, gain: 15, name: bouing, path: /boot/data/sound/1/sfx/1404981441-bouing/bouing____LEGACY.ogg
2018-08-14 18:42:59.873 DEBUG [initSamples] [sound_util.c:464] sample 0000000065 0x00000041 0x9485ac25, type: music, gain: 20, name: system_failure, path: /boot/data/sound/1/music/2491788325-system_failure/System Fail.ogg
2018-08-14 18:42:59.873 DEBUG [initSamples] [sound_util.c:464] sample 0000000066 0x00000042 0xfba53973, type: music, gain: 15, name: raptor_rampage, path: /boot/data/sound/1/music/4221909363-raptor_rampage/Raptor Rampage.ogg
2018-08-14 18:42:59.873 DEBUG [initSamples] [sound_util.c:464] sample 0000000067 0x00000043 0xf22bb0e6, type: jingle, gain: 15, name: baby_t_rex, path: /boot/data/sound/1/jingle/4062949606-baby_t_rex/Baby T Rex.ogg
2018-08-14 18:42:59.873 DEBUG [initSamples] [sound_util.c:464] sample 0000000068 0x00000044 0x4463d4c9, type: music, gain: 15, name: tilt, path: /boot/data/sound/1/music/1147393225-tilt/tilt__LE__LEGACY.ogg
2018-08-14 18:42:59.874 DEBUG [initSamples] [sound_util.c:464] sample 0000000069 0x00000045 0xff7710e2, type: music, gain: 15, name: raptor_rampage, path: /boot/data/sound/1/music/4285993186-raptor_rampage/Raptor 2er Multi.ogg
2018-08-14 18:42:59.874 DEBUG [initSamples] [sound_util.c:464] sample 0000000070 0x00000046 0x8916b85a, type: sfx, gain: 15, name: electric_fence, path: /boot/data/sound/1/sfx/2299967578-electric_fence/Electric Fence.ogg
2018-08-14 18:42:59.874 DEBUG [initSamples] [sound_util.c:464] sample 0000000071 0x00000047 0x46e152d2, type: jingle, gain: 15, name: dino, path: /boot/data/sound/1/jingle/1189171922-dino/two ball start.ogg
2018-08-14 18:42:59.874 DEBUG [initSamples] [sound_util.c:464] sample 0000000072 0x00000048 0x44ce171c, type: sfx, gain: 8, name: timer_expire, path: /boot/data/sound/1/sfx/1154357020-timer_expire/Timer.ogg
2018-08-14 18:42:59.874 DEBUG [initSamples] [sound_util.c:464] sample 0000000073 0x00000049 0x14845c0c, type: sfx, gain: 15, name: tilt, path: /boot/data/sound/1/sfx/0344218636-tilt/tilt__LE__LEGACY.ogg
2018-08-14 18:42:59.874 DEBUG [initSamples] [sound_util.c:464] sample 0000000074 0x0000004a 0x79d02c30, type: sfx, gain: 15, name: bouing, path: /boot/data/sound/1/sfx/2043685936-bouing/bouing____LEGACY.ogg
2018-08-14 18:42:59.874 DEBUG [initSamples] [sound_util.c:464] sample 0000000075 0x0000004b 0xa46087ed, type: sfx, gain: 15, name: dring, path: /boot/data/sound/1/sfx/2757789677-dring/dring__L__LEGACY.ogg
2018-08-14 18:42:59.874 DEBUG [initSamples] [sound_util.c:464] sample 0000000076 0x0000004c 0xc7537a7d, type: sfx, gain: 20, name: graduated_sound, path: /boot/data/sound/1/sfx/3344136829-graduated_sound/graduate2.ogg
2018-08-14 18:42:59.874 DEBUG [initSamples] [sound_util.c:464] sample 0000000077 0x0000004d 0x04c1a5b1, type: sfx, gain: 15, name: gun_shot, path: /boot/data/sound/1/sfx/0079799729-gun_shot/Gun Shot.ogg
2018-08-14 18:42:59.874 DEBUG [initSamples] [sound_util.c:464] sample 0000000078 0x0000004e 0x65f6c939, type: jingle, gain: 15, name: extra_ball_lit, path: /boot/data/sound/1/jingle/1710672185-extra_ball_lit/Extra Ball Lit.ogg
2018-08-14 18:42:59.874 DEBUG [initSamples] [sound_util.c:464] sample 0000000079 0x0000004f 0x95b56102, type: jingle, gain: 15, name: special_lit, path: /boot/data/sound/1/jingle/2511692034-special_lit/special___LEGACY.ogg
2018-08-14 18:42:59.875 DEBUG [initSamples] [sound_util.c:464] sample 0000000080 0x00000050 0x5d3190da, type: jingle, gain: 14, name: freeze_ball_saver_, path: /boot/data/sound/1/jingle/1563529434-freeze_ball_saver_/Freeze 2.ogg
2018-08-14 18:42:59.875 DEBUG [initSamples] [sound_util.c:464] sample 0000000081 0x00000051 0x86f2bd60, type: sfx, gain: 15, name: badaboum, path: /boot/data/sound/1/sfx/2264055136-badaboum/badaboum__LEGACY.ogg
2018-08-14 18:42:59.875 DEBUG [initSamples] [sound_util.c:464] sample 0000000082 0x00000052 0x3fc35b05, type: sfx, gain: 15, name: egg_crack, path: /boot/data/sound/1/sfx/1069767429-egg_crack/Spitter 1.ogg
2018-08-14 18:42:59.875 DEBUG [initSamples] [sound_util.c:464] sample 0000000083 0x00000053 0x5f8737ae, type: sfx, gain: 15, name: horn, path: /boot/data/sound/1/sfx/1602697134-horn/horn__LE__LEGACY.ogg
2018-08-14 18:42:59.875 DEBUG [initSamples] [sound_util.c:464] sample 0000000084 0x00000054 0xe9347c65, type: sfx, gain: 17, name: echo_back, path: /boot/data/sound/1/sfx/3912531045-echo_back/raptor 3.ogg
2018-08-14 18:42:59.875 DEBUG [initSamples] [sound_util.c:464] sample 0000000085 0x00000055 0xe9956a0a, type: sfx, gain: 16, name: bouing_echo_3_times, path: /boot/data/sound/1/sfx/3918883338-bouing_echo_3_times/raptor pan.ogg
2018-08-14 18:42:59.875 DEBUG [initSamples] [sound_util.c:464] sample 0000000086 0x00000056 0xb9ddec34, type: sfx, gain: 16, name: jackpot, path: /boot/data/sound/1/sfx/3118328884-jackpot/raptor pan 2.ogg
2018-08-14 18:42:59.875 DEBUG [initSamples] [sound_util.c:464] sample 0000000087 0x00000057 0x25b8090c, type: sfx, gain: 12, name: vibrating_douing, path: /boot/data/sound/1/sfx/0632817932-vibrating_douing/Raptor shout 2.ogg
2018-08-14 18:42:59.875 DEBUG [initSamples] [sound_util.c:464] sample 0000000088 0x00000058 0x5699823a, type: sfx, gain: 15, name: spitter, path: /boot/data/sound/1/sfx/1452900922-spitter/Spitter 1.ogg
2018-08-14 18:42:59.875 DEBUG [initSamples] [sound_util.c:464] sample 0000000089 0x00000059 0x6dc68833, type: sfx, gain: 7, name: splash, path: /boot/data/sound/1/sfx/1841727539-splash/Splash.ogg
2018-08-14 18:42:59.875 DEBUG [initSamples] [sound_util.c:464] sample 0000000090 0x0000005a 0xd563d953, type: sfx, gain: 15, name: jackpot, path: /boot/data/sound/1/sfx/3580090707-jackpot/jackpot___LEGACY.ogg
2018-08-14 18:42:59.875 DEBUG [initSamples] [sound_util.c:464] sample 0000000091 0x0000005b 0xd56b80ac, type: jingle, gain: 17, name: tri_ball_start, path: /boot/data/sound/1/jingle/3580592300-tri_ball_start/Tri Ball Voice.ogg
2018-08-14 18:42:59.875 DEBUG [initSamples] [sound_util.c:464] sample 0000000092 0x0000005c 0xff4ffca5, type: sfx, gain: 15, name: xylophone, path: /boot/data/sound/1/sfx/4283432101-xylophone/xylophon__LEGACY.ogg
2018-08-14 18:42:59.875 DEBUG [initSamples] [sound_util.c:464] sample 0000000093 0x0000005d 0xfa6c26ce, type: sfx, gain: 8, name: boum, path: /boot/data/sound/1/sfx/4201391822-boum/boom down sweep.ogg
2018-08-14 18:42:59.876 DEBUG [initSamples] [sound_util.c:464] sample 0000000094 0x0000005e 0x0c0b8bfe, type: sfx, gain: 15, name: bsmt_2000_attract_sound, path: /boot/data/sound/1/sfx/0202083326-bsmt_2000_attract_sound/bsmt_200__LEGACY.ogg
2018-08-14 18:42:59.876 DEBUG [initSamples] [sound_util.c:464] sample 0000000095 0x0000005f 0xfbef607c, type: sfx, gain: 17, name: tilt, path: /boot/data/sound/1/sfx/4226769020-tilt/Tilt 1.ogg
2018-08-14 18:42:59.876 DEBUG [initSamples] [sound_util.c:464] sample 0000000096 0x00000060 0xed050110, type: jingle, gain: 19, name: tilt_warning, path: /boot/data/sound/1/jingle/3976528144-tilt_warning/Tilt Warning 1.ogg
2018-08-14 18:42:59.876 DEBUG [initSamples] [sound_util.c:464] sample 0000000097 0x00000061 0x209a5f60, type: sfx, gain: 15, name: amblin_attract_sound, path: /boot/data/sound/1/sfx/0546987872-amblin_attract_sound/attract.ogg
2018-08-14 18:42:59.876 DEBUG [initSamples] [sound_util.c:464] sample 0000000098 0x00000062 0x1d04860c, type: sfx, gain: 15, name: tilt, path: /boot/data/sound/1/sfx/0486835724-tilt/Tilt.ogg
2018-08-14 18:42:59.876 DEBUG [initSamples] [sound_util.c:464] sample 0000000099 0x00000063 0xb3c37383, type: music, gain: 15, name: coming, path: /boot/data/sound/1/music/3015930755-coming soon/coming soon.ogg
2018-08-14 18:42:59.876 DEBUG [initSamples] [sound_util.c:464] sample 0000000100 0x00000064 0x547afed1, type: jingle, gain: 15, name: 100_million_score, path: /boot/data/sound/1/jingle/1417346769-100_million_score/100 million.ogg
2018-08-14 18:42:59.876 DEBUG [initSamples] [sound_util.c:464] sample 0000000101 0x00000065 0x33f8c3a3, type: sfx, gain: 15, name: bip_music, path: /boot/data/sound/1/sfx/0871941027-bip_music/bip_musi__LEGACY.ogg
2018-08-14 18:42:59.876 DEBUG [initSamples] [sound_util.c:464] sample 0000000103 0x00000067 0x2f20089b, type: sfx, gain: 15, name: wave_coming, path: /boot/data/sound/1/sfx/0790628507-wave_coming/wave_com__LEGACY.ogg
2018-08-14 18:42:59.876 DEBUG [initSamples] [sound_util.c:464] sample 0000000104 0x00000068 0x55e3b370, type: sfx, gain: 11, name: bip_echo, path: /boot/data/sound/1/sfx/1440985968-bip_echo/mud crash.ogg
2018-08-14 18:42:59.876 DEBUG [initSamples] [sound_util.c:464] sample 0000000105 0x00000069 0x2165fa93, type: sfx, gain: 15, name: biping, path: /boot/data/sound/1/sfx/0560331411-biping/biping____LEGACY.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000106 0x0000006a 0xd3ecdbc0, type: sfx, gain: 8, name: left_kickout, path: /boot/data/sound/1/sfx/3555515328-left_kickout/Left Kickout.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000107 0x0000006b 0x5089a997, type: sfx, gain: 15, name: pending_bouing, path: /boot/data/sound/1/sfx/1351199127-pending_bouing/pending___LEGACY.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000108 0x0000006c 0xa2ee7fcc, type: sfx, gain: 15, name: big_splash, path: /boot/data/sound/1/sfx/2733539276-big_splash/big_spla__LEGACY.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000109 0x0000006d 0xe6328649, type: sfx, gain: 15, name: tadam, path: /boot/data/sound/1/sfx/3862070857-tadam/tadam.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000110 0x0000006e 0xf4f94fe4, type: sfx, gain: 15, name: bell, path: /boot/data/sound/1/sfx/4109979620-bell/bell__LE__LEGACY.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000111 0x0000006f 0x1d16bd35, type: voice, gain: 15, name: jackpot, path: /boot/data/sound/1/voice/0488029493-jackpot/jackpot.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000112 0x00000070 0x6ef401cc, type: jingle, gain: 16, name: extra_ball, path: /boot/data/sound/1/jingle/1861485004-extra_ball/Extra Ball 2.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000113 0x00000071 0x822d5a4d, type: sfx, gain: 15, name: scary_attack, path: /boot/data/sound/1/sfx/2184010317-scary_attack/scary_at__LEGACY.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000114 0x00000072 0xa927f184, type: sfx, gain: 15, name: boing_splash, path: /boot/data/sound/1/sfx/2837967236-boing_splash/boing_sp__LEGACY.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000115 0x00000073 0x105c80b7, type: sfx, gain: 15, name: electronic_missile_detonation, path: /boot/data/sound/1/sfx/0274497719-electronic_missile_detonation/electron__LEGACY.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000116 0x00000074 0xb4974d38, type: sfx, gain: 15, name: 2_gun_shot, path: /boot/data/sound/1/sfx/3029814584-2_gun_shot/2 explosion.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000117 0x00000075 0x5c7a72de, type: sfx, gain: 15, name: dinosaur_footstep, path: /boot/data/sound/1/sfx/1551528670-dinosaur_footstep/dinosaur__LEGACY.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000118 0x00000076 0xb449288a, type: sfx, gain: 15, name: tadam, path: /boot/data/sound/1/sfx/3024693386-tadam/tadam__L__LEGACY.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000119 0x00000077 0xc1c30465, type: sfx, gain: 15, name: jackpot, path: /boot/data/sound/1/sfx/3250783333-jackpot/jackpot___LEGACY.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000120 0x00000078 0xaa6323a8, type: sfx, gain: 15, name: chaos, path: /boot/data/sound/1/sfx/2858623912-chaos/chaos__L__LEGACY.ogg
2018-08-14 18:42:59.877 DEBUG [initSamples] [sound_util.c:464] sample 0000000121 0x00000079 0xf872e034, type: sfx, gain: 13, name: small_bomb_echo, path: /boot/data/sound/1/sfx/4168278068-small_bomb_echo/Small Bomb Echo.ogg
2018-08-14 18:42:59.878 DEBUG [initSamples] [sound_util.c:464] sample 0000000122 0x0000007a 0x0f00cb7a, type: sfx, gain: 15, name: credit, path: /boot/data/sound/1/sfx/0251710330-credit/credit____LEGACY.ogg
2018-08-14 18:42:59.878 DEBUG [initSamples] [sound_util.c:464] sample 0000000123 0x0000007b 0x9e6ccb47, type: sfx, gain: 15, name: vibrating_echo, path: /boot/data/sound/1/sfx/2657930055-vibrating_echo/Vibrating Echo.ogg
2018-08-14 18:42:59.878 DEBUG [initSamples] [sound_util.c:464] sample 0000000124 0x0000007c 0x2a8302c6, type: sfx, gain: 15, name: boum, path: /boot/data/sound/1/sfx/0713228998-boum/Shotgun.ogg
2018-08-14 18:42:59.878 DEBUG [initSamples] [sound_util.c:464] sample 0000000125 0x0000007d 0x495f32ae, type: sfx, gain: 5, name: gunshot, path: /boot/data/sound/1/sfx/1230975662-gunshot/gunshot.ogg
2018-08-14 18:42:59.878 DEBUG [initSamples] [sound_util.c:464] sample 0000000126 0x0000007e 0x050bd196, type: sfx, gain: 15, name: bonus_credit, path: /boot/data/sound/1/sfx/0084660630-bonus_credit/bonus_cr__LEGACY.ogg
2018-08-14 18:42:59.878 DEBUG [initSamples] [sound_util.c:464] sample 0000000127 0x0000007f 0x65199c89, type: sfx, gain: 15, name: t_rex, path: /boot/data/sound/1/sfx/1696177289-t_rex/T Rex 2.ogg
2018-08-14 18:42:59.878 DEBUG [initSamples] [sound_util.c:464] sample 0000000128 0x00000080 0x17255a39, type: sfx, gain: 8, name: t_rex_roar_2, path: /boot/data/sound/1/sfx/0388323897-t_rex_roar_2/T Rex Roar 2.ogg
2018-08-14 18:42:59.878 DEBUG [initSamples] [sound_util.c:464] sample 0000000129 0x00000081 0xefd54f86, type: voice, gain: 15, name: they_should_all_be_destroyed, path: /boot/data/sound/1/voice/4023734150-they_should_all_be_destroyed/They should all be destroyed.ogg
2018-08-14 18:42:59.878 DEBUG [initSamples] [sound_util.c:464] sample 0000000130 0x00000082 0x2f1d4aec, type: voice, gain: 13, name: you_didn_t_say_the_magic_work, path: /boot/data/sound/1/voice/0790448876-you_didn_t_say_the_magic_work/ah ah ah you didnt say the magic word.ogg
2018-08-14 18:42:59.878 DEBUG [initSamples] [sound_util.c:464] sample 0000000131 0x00000083 0x980a3332, type: voice, gain: 13, name: over_here, path: /boot/data/sound/1/voice/2550805298-over_here/over here.ogg
2018-08-14 18:42:59.878 DEBUG [initSamples] [sound_util.c:464] sample 0000000132 0x00000084 0x9bf337e5, type: sfx, gain: 8, name: t_rex_roar_3, path: /boot/data/sound/1/sfx/2616408037-t_rex_roar_3/T Rex Roar 3.ogg
2018-08-14 18:42:59.878 DEBUG [initSamples] [sound_util.c:464] sample 0000000133 0x00000085 0x355d5fc0, type: sfx, gain: 9, name: t_rex, path: /boot/data/sound/1/sfx/0895311808-t_rex/t rex.ogg
2018-08-14 18:42:59.878 DEBUG [initSamples] [sound_util.c:464] sample 0000000134 0x00000086 0x167b7576, type: sfx, gain: 20, name: targets, path: /boot/data/sound/1/sfx/0377189750-targets/target 1.ogg
2018-08-14 18:42:59.878 DEBUG [initSamples] [sound_util.c:464] sample 0000000135 0x00000087 0x43f63e64, type: sfx, gain: 15, name: t_rex_roar, path: /boot/data/sound/1/sfx/1140211300-t_rex_roar/T Rex Roar.ogg
2018-08-14 18:42:59.879 DEBUG [initSamples] [sound_util.c:464] sample 0061532807 0x03aaea87 0x00000000, type: jingle, gain: 15, name: t_rex, path: /boot/data/sound/1/jingle/0061532807-t_rex/t_rex__L__LEGACY.ogg
2018-08-14 18:42:59.879 DEBUG [initSamples] [sound_util.c:464] sample 0000000136 0x00000088 0x36f1da68, type: sfx, gain: 13, name: t_rex_footstep, path: /boot/data/sound/1/sfx/0921819752-t_rex_footstep/T Rex Footstep 2.ogg
2018-08-14 18:42:59.879 DEBUG [initSamples] [sound_util.c:464] sample 0000000137 0x00000089 0x91b710cc, type: sfx, gain: 16, name: broum, path: /boot/data/sound/1/sfx/2444693708-broum/broum 1.ogg
2018-08-14 18:42:59.879 DEBUG [initSamples] [sound_util.c:464] sample 0000000138 0x0000008a 0x42327439, type: sfx, gain: 14, name: broum_3, path: /boot/data/sound/1/sfx/1110602809-broum_3/broum 3.ogg
2018-08-14 18:42:59.879 DEBUG [initSamples] [sound_util.c:464] sample 0000000139 0x0000008b 0x890f6988, type: sfx, gain: 14, name: broum_2, path: /boot/data/sound/1/sfx/2299488648-broum_2/broum 2.ogg
2018-08-14 18:42:59.879 DEBUG [initSamples] [sound_util.c:464] sample 0000000140 0x0000008c 0xd0f2b640, type: music, gain: 15, name: amblin_attract_sound_2, path: /boot/data/sound/1/music/3505567296-amblin_attract_sound_2/attract 2.ogg
2018-08-14 18:42:59.879 DEBUG [initSamples] [sound_util.c:464] sample 0000000141 0x0000008d 0xbc793256, type: voice, gain: 13, name: ouh, path: /boot/data/sound/1/voice/3162059350-ouh/ouh 1.ogg
2018-08-14 18:42:59.879 DEBUG [initSamples] [sound_util.c:464] sample 0000000142 0x0000008e 0x62b7e071, type: sfx, gain: 15, name: spitters, path: /boot/data/sound/1/sfx/1656217713-spitters/Spitter 1.ogg
2018-08-14 18:42:59.880 DEBUG [initSamples] [sound_util.c:464] sample 0000000143 0x0000008f 0x5b9f044b, type: voice, gain: 15, name: welcome, path: /boot/data/sound/1/voice/1537147979-welcome/I bring scientists, you bring a rockstar.ogg
2018-08-14 18:42:59.880 DEBUG [initSamples] [sound_util.c:464] sample 0000000144 0x00000090 0xf5c13ec3, type: voice, gain: 8, name: how_about_another_tour_of_the_park_, path: /boot/data/sound/1/voice/4123082435-how_about_another_tour_of_the_park_/after careful considerations i decided not do endorse your park.ogg
2018-08-14 18:42:59.880 DEBUG [initSamples] [sound_util.c:464] sample 0000000145 0x00000091 0x5f8fd867, type: voice, gain: 19, name: oh_t_rex_got_him, path: /boot/data/sound/1/voice/1603262567-oh_t_rex_got_him/I think this was.ogg
2018-08-14 18:42:59.880 DEBUG [initSamples] [sound_util.c:464] sample 0000000146 0x00000092 0x8d616290, type: voice, gain: 13, name: enjoy_jurassic_park, path: /boot/data/sound/1/voice/2371969680-enjoy_jurassic_park/enjoy JP.ogg
2018-08-14 18:42:59.880 DEBUG [initSamples] [sound_util.c:464] sample 0000000147 0x00000093 0x11e3bcad, type: voice, gain: 13, name: oh_no_it_s_t_rex, path: /boot/data/sound/1/voice/0300137645-oh_no_it_s_t_rex/oh no its trex.ogg
2018-08-14 18:42:59.880 DEBUG [initSamples] [sound_util.c:464] sample 0000000148 0x00000094 0xb35b4e0a, type: voice, gain: 13, name: hurry_restart_the_system, path: /boot/data/sound/1/voice/3009105418-hurry_restart_the_system/hurry restart the system 2.ogg
2018-08-14 18:42:59.880 DEBUG [initSamples] [sound_util.c:464] sample 0000000149 0x00000095 0x7fda9823, type: voice, gain: 15, name: oh_a_raptor_got_him, path: /boot/data/sound/1/voice/2145032227-oh_a_raptor_got_him/I really hate that man.ogg
2018-08-14 18:42:59.880 DEBUG [initSamples] [sound_util.c:464] sample 0000000150 0x00000096 0x33a43464, type: sfx, gain: 15, name: burp, path: /boot/data/sound/1/sfx/0866399332-burp/Burp 1.ogg
2018-08-14 18:42:59.880 DEBUG [initSamples] [sound_util.c:464] sample 0000000151 0x00000097 0xc943dbbe, type: voice, gain: 13, name: ooh_no_no_no_, path: /boot/data/sound/1/voice/3376667582-ooh_no_no_no_/oh no nononoo.ogg
2018-08-14 18:42:59.880 DEBUG [initSamples] [sound_util.c:464] sample 0000000152 0x00000098 0x024e086a, type: voice, gain: 13, name: chaos, path: /boot/data/sound/1/voice/0038668394-chaos/Chaos 2.ogg
2018-08-14 18:42:59.880 DEBUG [initSamples] [sound_util.c:464] sample 0000000153 0x00000099 0xe1979895, type: voice, gain: 14, name: should_have_been_there_by_now, path: /boot/data/sound/1/voice/3784808597-should_have_been_there_by_now/everybody stay here.ogg
2018-08-14 18:42:59.880 DEBUG [initSamples] [sound_util.c:464] sample 0000000154 0x0000009a 0x67738049, type: voice, gain: 9, name: oh_god_no_no_aahh_ooh_no_no_, path: /boot/data/sound/1/voice/1735622729-oh_god_no_no_aahh_ooh_no_no_/AAAHAHAHAAAAA.ogg
2018-08-14 18:42:59.880 DEBUG [initSamples] [sound_util.c:464] sample 0000000155 0x0000009b 0xce4e5a2e, type: voice, gain: 12, name: go_go_go_go_go_go_go_, path: /boot/data/sound/1/voice/3461241390-go_go_go_go_go_go_go_/come on we gotta get out of here.ogg
2018-08-14 18:42:59.880 DEBUG [initSamples] [sound_util.c:464] sample 0000000156 0x0000009c 0x5acbd05b, type: voice, gain: 13, name: the_t_rex_is_loose, path: /boot/data/sound/1/voice/1523306587-the_t_rex_is_loose/t rex is loose.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000157 0x0000009d 0xe50da53a, type: sfx, gain: 15, name: baby_t_rex, path: /boot/data/sound/1/sfx/3842876730-baby_t_rex/baby_t_r__LEGACY.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000158 0x0000009e 0xf3ebe099, type: voice, gain: 13, name: just_shut_down_the_system, path: /boot/data/sound/1/voice/4092321945-just_shut_down_the_system/just shut down the system.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000159 0x0000009f 0x183197c1, type: sfx, gain: 15, name: goat, path: /boot/data/sound/1/sfx/0405903297-goat/Goat 1.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000160 0x000000a0 0x183d0d34, type: sfx, gain: 12, name: donosaur, path: /boot/data/sound/1/sfx/0406654260-donosaur/T Rex Goat 1.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000161 0x000000a1 0x29be8711, type: sfx, gain: 8, name: t_rex_roar_4, path: /boot/data/sound/1/sfx/0700352273-t_rex_roar_4/T Rex Roar 4.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000162 0x000000a2 0x4ff489cb, type: sfx, gain: 19, name: dinosaur, path: /boot/data/sound/1/sfx/1341426123-dinosaur/dinosaur 2.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000163 0x000000a3 0x74ee0bed, type: sfx, gain: 15, name: electric_fence, path: /boot/data/sound/1/sfx/1961757677-electric_fence/Fence.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000164 0x000000a4 0x37c09b16, type: sfx, gain: 14, name: nice_dinosaur_voice, path: /boot/data/sound/1/sfx/0935369494-nice_dinosaur_voice/More Dino 1.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000165 0x000000a5 0x10e81a6b, type: sfx, gain: 13, name: dinosaur_scream, path: /boot/data/sound/1/sfx/0283646571-dinosaur_scream/Dino 1.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000166 0x000000a6 0xf76205fc, type: sfx, gain: 8, name: helicopter_flyby, path: /boot/data/sound/1/sfx/4150396412-helicopter_flyby/heli.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000167 0x000000a7 0x9fe90593, type: sfx, gain: 12, name: ship_horn, path: /boot/data/sound/1/sfx/2682848659-ship_horn/Ship Horn.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000168 0x000000a8 0xf550f446, type: sfx, gain: 14, name: dinosaur, path: /boot/data/sound/1/sfx/4115723334-dinosaur/dinosaur.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000169 0x000000a9 0x9b386bc0, type: sfx, gain: 14, name: baby_t_rex_2, path: /boot/data/sound/1/sfx/2604166080-baby_t_rex_2/baby_t_r__LEGACY.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000170 0x000000aa 0x80f7a06e, type: sfx, gain: 15, name: thunder, path: /boot/data/sound/1/sfx/2163712110-thunder/Thunder.ogg
2018-08-14 18:42:59.881 DEBUG [initSamples] [sound_util.c:464] sample 0000000171 0x000000ab 0x7b16b144, type: voice, gain: 15, name: stempede, path: /boot/data/sound/1/voice/2065084740-stempede/Stampede.ogg
2018-08-14 18:42:59.882 DEBUG [initSamples] [sound_util.c:464] sample 0000000172 0x000000ac 0xf7168c7f, type: voice, gain: 14, name: electric_fence_mode, path: /boot/data/sound/1/voice/4145450111-electric_fence_mode/Electric Fence Mode.ogg
2018-08-14 18:42:59.882 DEBUG [initSamples] [sound_util.c:464] sample 0000000173 0x000000ad 0x2424f2ef, type: voice, gain: 16, name: spitter_mode, path: /boot/data/sound/1/voice/0606401263-spitter_mode/I run you over when I come back down.ogg
2018-08-14 18:42:59.882 DEBUG [initSamples] [sound_util.c:464] sample 0000000174 0x000000ae 0x435074a3, type: voice, gain: 16, name: system_boot, path: /boot/data/sound/1/voice/1129346211-system_boot/I can't get JP back online without Dennis Nedry.ogg
2018-08-14 18:42:59.882 DEBUG [initSamples] [sound_util.c:464] sample 0000000175 0x000000af 0x3eb4804b, type: voice, gain: 20, name: escape, path: /boot/data/sound/1/voice/1052016715-escape/Escape.ogg
2018-08-14 18:42:59.882 DEBUG [initSamples] [sound_util.c:464] sample 0000000176 0x000000b0 0x008fd778, type: voice, gain: 16, name: bone_busting, path: /boot/data/sound/1/voice/0009426808-bone_busting/Bone Busting.ogg
2018-08-14 18:42:59.882 DEBUG [initSamples] [sound_util.c:464] sample 0000000177 0x000000b1 0xb0c0df86, type: voice, gain: 16, name: extra_ball_is_lit, path: /boot/data/sound/1/voice/2965430150-extra_ball_is_lit/Extra Ball is lit.ogg
2018-08-14 18:42:59.882 DEBUG [initSamples] [sound_util.c:464] sample 0000000178 0x000000b2 0xaf8c0d8e, type: voice, gain: 20, name: tri_ball_is_lit, path: /boot/data/sound/1/voice/2945191310-tri_ball_is_lit/Tri Ball is Lit.ogg
2018-08-14 18:42:59.882 DEBUG [initSamples] [sound_util.c:464] sample 0000000179 0x000000b3 0x9691d087, type: voice, gain: 18, name: two_ball_is_lit, path: /boot/data/sound/1/voice/2526138503-two_ball_is_lit/Two Ball is lit.ogg
2018-08-14 18:42:59.882 DEBUG [initSamples] [sound_util.c:464] sample 0000000180 0x000000b4 0xc1ca7748, type: sfx, gain: 12, name: ramp, path: /boot/data/sound/1/sfx/3251271496-ramp made/ramp made.ogg
2018-08-14 18:42:59.882 DEBUG [initSamples] [sound_util.c:464] sample 0000000181 0x000000b5 0x80e93ef2, type: voice, gain: 15, name: shoot_again, path: /boot/data/sound/1/voice/2162769650-shoot_again/last chance.ogg
2018-08-14 18:42:59.883 DEBUG [initSamples] [sound_util.c:464] sample 0000000182 0x000000b6 0x1cb98d2c, type: sfx, gain: 13, name: ugly_dinosaur_scream, path: /boot/data/sound/1/sfx/0481922348-ugly_dinosaur_scream/dinosaur.ogg
2018-08-14 18:42:59.883 DEBUG [initSamples] [sound_util.c:464] sample 0000000183 0x000000b7 0x011c0e43, type: voice, gain: 13, name: the_raptors_are_out, path: /boot/data/sound/1/voice/0018615875-the_raptors_are_out/don't let them out.ogg
2018-08-14 18:42:59.883 DEBUG [initSamples] [sound_util.c:464] sample 0000000184 0x000000b8 0xde3788dc, type: voice, gain: 13, name: doors_security_systems_are_shutting_down, path: /boot/data/sound/1/voice/3728181468-doors_security_systems_are_shutting_down/door security systems.ogg
2018-08-14 18:42:59.883 DEBUG [initSamples] [sound_util.c:464] sample 0000000185 0x000000b9 0x5d1d70f1, type: voice, gain: 20, name: the_raptors_are_clever, path: /boot/data/sound/1/voice/1562210545-the_raptors_are_clever/Dinosaurs droppings.ogg
2018-08-14 18:42:59.883 DEBUG [initSamples] [sound_util.c:464] sample 0000000186 0x000000ba 0x08042ac1, type: voice, gain: 16, name: those_raptors_are_clever, path: /boot/data/sound/1/voice/0134490817-those_raptors_are_clever/come on this way.ogg
2018-08-14 18:42:59.883 DEBUG [initSamples] [sound_util.c:464] sample 0000000187 0x000000bb 0x7f7d6855, type: voice, gain: 13, name: the_t_rex_is_loose, path: /boot/data/sound/1/voice/2138925141-the_t_rex_is_loose/trex is loose 2.ogg
2018-08-14 18:42:59.883 DEBUG [initSamples] [sound_util.c:464] sample 0000000188 0x000000bc 0xaaec6a9f, type: voice, gain: 16, name: thumper_ready, path: /boot/data/sound/1/voice/2867620511-thumper_ready/Tasers on full charge.ogg
2018-08-14 18:42:59.883 DEBUG [initSamples] [sound_util.c:464] sample 0000000189 0x000000bd 0x387b052f, type: voice, gain: 9, name: ok_fire, path: /boot/data/sound/1/voice/0947586351-ok_fire/Shoot Her 1.ogg
2018-08-14 18:42:59.883 DEBUG [initSamples] [sound_util.c:464] sample 0000000190 0x000000be 0xfdaeca35, type: sfx, gain: 15, name: electrik_sound, path: /boot/data/sound/1/sfx/4256090677-electrik_sound/electricity 1.ogg
2018-08-14 18:42:59.883 DEBUG [initSamples] [sound_util.c:464] sample 0000000191 0x000000bf 0x987718e5, type: voice, gain: 13, name: mosquito, path: /boot/data/sound/1/voice/2557941989-mosquito/mosquito 2.ogg
2018-08-14 18:42:59.883 DEBUG [initSamples] [sound_util.c:464] sample 0000000192 0x000000c0 0x72b2a8ba, type: voice, gain: 13, name: scream, path: /boot/data/sound/1/voice/1924311226-scream/scream 1.ogg
2018-08-14 18:42:59.883 DEBUG [initSamples] [sound_util.c:464] sample 0000000193 0x000000c1 0x67600a33, type: sfx, gain: 14, name: dino_growl, path: /boot/data/sound/1/sfx/1734347315-dino_growl/dino.ogg
2018-08-14 18:42:59.883 DEBUG [initSamples] [sound_util.c:464] sample 0000000194 0x000000c2 0xc4af134b, type: sfx, gain: 17, name: dino_growl, path: /boot/data/sound/1/sfx/3299808075-dino_growl/dino.ogg
2018-08-14 18:42:59.883 DEBUG [initSamples] [sound_util.c:464] sample 0000000195 0x000000c3 0x500d5ca3, type: voice, gain: 15, name: feed_t_rex, path: /boot/data/sound/1/voice/1343052963-feed_t_rex/Feed Trex.ogg
2018-08-14 18:42:59.884 DEBUG [initSamples] [sound_util.c:464] sample 0000000196 0x000000c4 0x68caaf4e, type: sfx, gain: 12, name: dinosaur_voice, path: /boot/data/sound/1/sfx/1758113614-dinosaur_voice/Raptor 1.ogg
2018-08-14 18:42:59.884 DEBUG [initSamples] [sound_util.c:464] sample 0000000197 0x000000c5 0x905c122d, type: voice, gain: 13, name: scream, path: /boot/data/sound/1/voice/2421953069-scream/scream 1.ogg
2018-08-14 18:42:59.884 DEBUG [initSamples] [sound_util.c:464] sample 0000000198 0x000000c6 0x493c2b58, type: voice, gain: 15, name: oh_god, path: /boot/data/sound/1/voice/1228680024-oh_god/oh god 1.ogg
2018-08-14 18:42:59.884 DEBUG [initSamples] [sound_util.c:464] sample 0000000199 0x000000c7 0x1662ec06, type: music, gain: 15, name: Super, path: /boot/data/sound/1/music/0375581702- Super Egg/Super Egg.ogg
2018-08-14 18:42:59.884 DEBUG [initSamples] [sound_util.c:464] sample 0000000200 0x000000c8 0x246f43a1, type: voice, gain: 13, name: bingo, path: /boot/data/sound/1/voice/0611271585-bingo/Bingo.ogg
2018-08-14 18:42:59.884 DEBUG [initSamples] [sound_util.c:464] sample 0000000201 0x000000c9 0xc99628f5, type: voice, gain: 16, name: dino_dna, path: /boot/data/sound/1/voice/3382061301-dino_dna/bingo dino dna.ogg
2018-08-14 18:42:59.884 DEBUG [initSamples] [sound_util.c:464] sample 0000000202 0x000000ca 0xb2ae2397, type: voice, gain: 13, name: nooo, path: /boot/data/sound/1/voice/2997756823-nooo/Nooo 1.ogg
2018-08-14 18:42:59.884 DEBUG [initSamples] [sound_util.c:464] sample 0000000203 0x000000cb 0x9120c56e, type: voice, gain: 17, name: love_your_butt, path: /boot/data/sound/1/voice/2434844014-love_your_butt/hold onto your butts.ogg
2018-08-14 18:42:59.884 DEBUG [initSamples] [sound_util.c:464] sample 0000000204 0x000000cc 0xf21cd44f, type: sfx, gain: 15, name: boum_suspicious, path: /boot/data/sound/1/sfx/4061975631-boum_suspicious/boum_sus__LEGACY.ogg
2018-08-14 18:42:59.884 DEBUG [initSamples] [sound_util.c:464] sample 0000000205 0x000000cd 0x58f3f2d9, type: sfx, gain: 15, name: laser, path: /boot/data/sound/1/sfx/1492382425-laser/laser__L__LEGACY.ogg
2018-08-14 18:42:59.884 DEBUG [initSamples] [sound_util.c:464] sample 0000000206 0x000000ce 0x13b2be1b, type: sfx, gain: 15, name: tilt, path: /boot/data/sound/1/sfx/0330481179-tilt/tilt__LE__LEGACY.ogg
2018-08-14 18:42:59.884 DEBUG [initSamples] [sound_util.c:464] sample 0000000207 0x000000cf 0xc682904d, type: voice, gain: 13, name: get_off_the_fence, path: /boot/data/sound/1/voice/3330445389-get_off_the_fence/big tim the human piece of toast.ogg
2018-08-14 18:42:59.884 DEBUG [initSamples] [sound_util.c:464] sample 0000000208 0x000000d0 0xab666462, type: voice, gain: 15, name: now, path: /boot/data/sound/1/voice/2875614306-now/NOW.ogg
2018-08-14 18:42:59.885 DEBUG [initSamples] [sound_util.c:464] sample 0000000209 0x000000d1 0x24108f35, type: voice, gain: 14, name: our_attractions_will_drive_kids_out_of_their_minds, path: /boot/data/sound/1/voice/0605065013-our_attractions_will_drive_kids_out_of_their_minds/Really spectacular, spared no expense.ogg
2018-08-14 18:42:59.885 DEBUG [initSamples] [sound_util.c:464] sample 0000000210 0x000000d2 0xedafa307, type: voice, gain: -20, name: to_jurassic_park, path: /boot/data/sound/1/voice/3987710727-to_jurassic_park/to jurassic park.ogg
2018-08-14 18:42:59.885 DEBUG [initSamples] [sound_util.c:464] sample 0000000211 0x000000d3 0xfbed9b46, type: sfx, gain: 15, name: bouing, path: /boot/data/sound/1/sfx/4226652998-bouing/bouing____LEGACY.ogg
2018-08-14 18:42:59.885 DEBUG [initSamples] [sound_util.c:464] sample 0000000212 0x000000d4 0xa167eda5, type: sfx, gain: 15, name: jumping_music, path: /boot/data/sound/1/sfx/2707942821-jumping_music/jumping___LEGACY.ogg
2018-08-14 18:42:59.885 DEBUG [initSamples] [sound_util.c:464] sample 0000000213 0x000000d5 0x186e45a0, type: voice, gain: 15, name: the_most_advanced_amusement_park_in_the_world, path: /boot/data/sound/1/voice/0409879968-the_most_advanced_amusement_park_in_the_world/the most advanced amusement park in the entire world.ogg
2018-08-14 18:42:59.885 DEBUG [initSamples] [sound_util.c:464] sample 0000000214 0x000000d6 0x949241d2, type: sfx, gain: 6, name: jackpot, path: /boot/data/sound/1/sfx/2492613074-jackpot/more boom.ogg
2018-08-14 18:42:59.885 DEBUG [initSamples] [sound_util.c:464] sample 0000000215 0x000000d7 0x1909edef, type: jingle, gain: 15, name: dna_choice, path: /boot/data/sound/1/jingle/0420081135-dna_choice/dna choice.ogg
2018-08-14 18:42:59.885 DEBUG [initSamples] [sound_util.c:464] sample 0000000216 0x000000d8 0xd263c6c7, type: sfx, gain: 15, name: tiny_bell, path: /boot/data/sound/1/sfx/3529754311-tiny_bell/tiny_bel__LEGACY.ogg
2018-08-14 18:42:59.885 DEBUG [initSamples] [sound_util.c:464] sample 0000000217 0x000000d9 0xa40449d6, type: sfx, gain: 15, name: bell_ring, path: /boot/data/sound/1/sfx/2751744470-bell_ring/bell_rin__LEGACY.ogg
2018-08-14 18:42:59.885 DEBUG [initSamples] [sound_util.c:464] sample 0000000218 0x000000da 0x848e8432, type: sfx, gain: 15, name: boummm, path: /boot/data/sound/1/sfx/2223932466-boummm/boummm____LEGACY.ogg
2018-08-14 18:42:59.886 DEBUG [initSamples] [sound_util.c:464] sample 0000000219 0x000000db 0x33f6e95b, type: sfx, gain: 15, name: advance_bonus_x, path: /boot/data/sound/1/sfx/0871819611-advance_bonus_x/Advance Bonus X.ogg
2018-08-14 18:42:59.886 DEBUG [initSamples] [sound_util.c:464] sample 0000000220 0x000000dc 0x8f912a51, type: sfx, gain: 16, name: little_bell_echo, path: /boot/data/sound/1/sfx/2408655441-little_bell_echo/keyboard.ogg
2018-08-14 18:42:59.886 DEBUG [initSamples] [sound_util.c:464] sample 0000000221 0x000000dd 0x21e8c9ea, type: sfx, gain: 14, name: dinosaur_tricky_voice, path: /boot/data/sound/1/sfx/0568904170-dinosaur_tricky_voice/raptor brrr L to R.ogg
2018-08-14 18:42:59.886 DEBUG [initSamples] [sound_util.c:464] sample 0000000222 0x000000de 0x4b383846, type: music, gain: 15, name: mr_dna_selection, path: /boot/data/sound/1/music/1261975622-mr_dna_selection/MR Dna Selection.ogg
2018-08-14 18:42:59.886 DEBUG [initSamples] [sound_util.c:464] sample 0000000223 0x000000df 0x91c929a9, type: jingle, gain: 15, name: shootout, path: /boot/data/sound/1/jingle/2445879721-shootout/Shootout.ogg
2018-08-14 18:42:59.886 DEBUG [initSamples] [sound_util.c:464] sample 0000000224 0x000000e0 0x83af730f, type: sfx, gain: 14, name: egg_crackle, path: /boot/data/sound/1/sfx/2209313551-egg_crackle/egg.ogg
2018-08-14 18:42:59.886 DEBUG [initSamples] [sound_util.c:464] sample 0000000225 0x000000e1 0xd19dcc60, type: sfx, gain: 15, name: mosquito, path: /boot/data/sound/1/sfx/3516779616-mosquito/Mosquito 1.ogg
2018-08-14 18:42:59.886 DEBUG [initSamples] [sound_util.c:464] sample 0000000226 0x000000e2 0xc6d16a37, type: sfx, gain: 16, name: boum_bouinngg, path: /boot/data/sound/1/sfx/3335612983-boum_bouinngg/Raptor Shout 1.ogg
2018-08-14 18:42:59.886 DEBUG [initSamples] [sound_util.c:464] sample 0000000227 0x000000e3 0x812b67ac, type: sfx, gain: 15, name: jackpot, path: /boot/data/sound/1/sfx/2167105452-jackpot/jackpot___LEGACY.ogg
2018-08-14 18:42:59.886 DEBUG [initSamples] [sound_util.c:464] sample 0000000228 0x000000e4 0x9add44b7, type: sfx, gain: 15, name: big_boummmmm, path: /boot/data/sound/1/sfx/2598192311-big_boummmmm/big booom.ogg
2018-08-14 18:42:59.886 DEBUG [initSamples] [sound_util.c:464] sample 0000000229 0x000000e5 0x853bc486, type: sfx, gain: 15, name: jackpot, path: /boot/data/sound/1/sfx/2235286662-jackpot/jackpot___LEGACY.ogg
2018-08-14 18:42:59.886 DEBUG [initSamples] [sound_util.c:464] sample 0000000230 0x000000e6 0x419ee8b6, type: sfx, gain: 16, name: ziouw, path: /boot/data/sound/1/sfx/1100933302-ziouw/ziouw.ogg
2018-08-14 18:42:59.886 DEBUG [initSamples] [sound_util.c:464] sample 0000000231 0x000000e7 0xe7aac769, type: jingle, gain: 12, name: mission_start, path: /boot/data/sound/1/jingle/3886729065-mission_start/Mission Start.ogg
2018-08-14 18:42:59.886 DEBUG [initSamples] [sound_util.c:464] sample 0000000232 0x000000e8 0xd252e414, type: jingle, gain: 15, name: tri_ball_restart, path: /boot/data/sound/1/jingle/3528647700-tri_ball_restart/Tri Ball Restart.ogg
2018-08-14 18:42:59.887 DEBUG [initSamples] [sound_util.c:464] sample 0000000233 0x000000e9 0x8ae8d73a, type: sfx, gain: 15, name: tadam_echo, path: /boot/data/sound/1/sfx/2330515258-tadam_echo/tadam_ec__LEGACY.ogg
2018-08-14 18:42:59.887 DEBUG [initSamples] [sound_util.c:464] sample 0000000234 0x000000ea 0x77570a3b, type: sfx, gain: 13, name: smart_bomb, path: /boot/data/sound/1/sfx/2002192955-smart_bomb/smart missile.ogg
2018-08-14 18:42:59.887 DEBUG [initSamples] [sound_util.c:464] sample 0000000235 0x000000eb 0x771cf8af, type: jingle, gain: 15, name: chaos, path: /boot/data/sound/1/jingle/1998387375-chaos/Chaos Jingle.ogg
2018-08-14 18:42:59.887 DEBUG [initSamples] [sound_util.c:464] sample 0000000236 0x000000ec 0xd806cdec, type: sfx, gain: 15, name: chaos_letter, path: /boot/data/sound/1/sfx/3624324588-chaos_letter/chaos letter.ogg
2018-08-14 18:42:59.887 DEBUG [initSamples] [sound_util.c:464] sample 0000000237 0x000000ed 0x54d3676c, type: sfx, gain: 7, name: boumm_down, path: /boot/data/sound/1/sfx/1423140716-boumm_down/booom.ogg
2018-08-14 18:42:59.887 DEBUG [initSamples] [sound_util.c:464] sample 0000000238 0x000000ee 0x97c29677, type: sfx, gain: 15, name: bells, path: /boot/data/sound/1/sfx/2546112119-bells/bells__L__LEGACY.ogg
2018-08-14 18:42:59.887 DEBUG [initSamples] [sound_util.c:464] sample 0000000239 0x000000ef 0x0b4ba9e0, type: sfx, gain: 15, name: test_tone_right, path: /boot/data/sound/1/sfx/0189508064-test_tone_right/test_ton__LEGACY.ogg
2018-08-14 18:42:59.887 DEBUG [initSamples] [sound_util.c:464] sample 0000000240 0x000000f0 0xdbd2de4e, type: sfx, gain: 15, name: test_tone_left, path: /boot/data/sound/1/sfx/3688029774-test_tone_left/test_ton__LEGACY.ogg
2018-08-14 18:42:59.887 DEBUG [initSamples] [sound_util.c:464] sample 0000000241 0x000000f1 0x625da4b3, type: sfx, gain: 15, name: test_tone_both, path: /boot/data/sound/1/sfx/1650304179-test_tone_both/test_ton__LEGACY.ogg
2018-08-14 18:42:59.887 DEBUG [initSamples] [sound_util.c:464] sample 0000000243 0x000000f3 0xad86cff5, type: music, gain: 15, name: dna, path: /boot/data/sound/1/music/2911293429-dna/dna__LEG__LEGACY.ogg
2018-08-14 18:42:59.887 DEBUG [initSamples] [sound_util.c:464] sample 0000000244 0x000000f4 0x3d851afa, type: music, gain: 15, name: ambiant_music, path: /boot/data/sound/1/music/1032133370-ambiant_music/ambiant___LEGACY.ogg
2018-08-14 18:42:59.887 DEBUG [initSamples] [sound_util.c:464] sample 0000000245 0x000000f5 0x8cd8f7cd, type: music, gain: 15, name: 3rd_ball_multiball_ready, path: /boot/data/sound/1/music/2363029453-3rd_ball_multiball_ready/3rd Ball Tri Ball Ready.ogg
2018-08-14 18:42:59.887 DEBUG [initSamples] [sound_util.c:464] sample 0000000246 0x000000f6 0x01dd4f08, type: music, gain: 15, name: spitter_attack_mission, path: /boot/data/sound/1/music/0031280904-spitter_attack_mission/Spitter.ogg
2018-08-14 18:42:59.887 DEBUG [initSamples] [sound_util.c:464] sample 0000000247 0x000000f7 0xdd44dbab, type: music, gain: 15, name: game_ending, path: /boot/data/sound/1/music/3712277419-game_ending/game_end__LEGACY.ogg
2018-08-14 18:42:59.888 DEBUG [initSamples] [sound_util.c:464] sample 0000000248 0x000000f8 0xf65cd0e6, type: jingle, gain: 15, name: hurry_up_mission, path: /boot/data/sound/1/jingle/4133277926-hurry_up_mission/Hurry Up.ogg
2018-08-14 18:42:59.888 DEBUG [initSamples] [sound_util.c:464] sample 0000000249 0x000000f9 0x4b1b42fa, type: music, gain: 15, name: enter_initials, path: /boot/data/sound/1/music/1260077818-enter_initials/enter_in__LEGACY.ogg
2018-08-14 18:42:59.888 DEBUG [initSamples] [sound_util.c:464] sample 0000000250 0x000000fa 0x3fc701b4, type: music, gain: 12, name: restart_multiball, path: /boot/data/sound/1/music/1070006708-restart_multiball/Restart Multiball.ogg
2018-08-14 18:42:59.888 DEBUG [initSamples] [sound_util.c:464] sample 0000000251 0x000000fb 0xd92d9296, type: music, gain: 15, name: multiball_ready, path: /boot/data/sound/1/music/3643642518-multiball_ready/multibal__LEGACY.ogg
2018-08-14 18:42:59.888 DEBUG [initSamples] [sound_util.c:464] sample 0000000252 0x000000fc 0x72fd4989, type: music, gain: 15, name: victory_lap, path: /boot/data/sound/1/music/1929202057-victory_lap/victory___LEGACY.ogg
2018-08-14 18:42:59.888 DEBUG [initSamples] [sound_util.c:464] sample 0000000253 0x000000fd 0xa75e7ad6, type: jingle, gain: 15, name: mosquito_missions, path: /boot/data/sound/1/jingle/2807986902-mosquito_missions/mosquito__LEGACY.ogg
2018-08-14 18:42:59.888 DEBUG [initSamples] [sound_util.c:467] scanned 221 sounds, using 220 hashes
2018-08-14 18:42:59.888 ERROR [initSamples] [sound_util.c:478] unmapped sample 0061532807 0x03aaea87 0x00000000, type: jingle, gain: 15, name: t_rex, path: /boot/data/sound/1/jingle/0061532807-t_rex/t_rex__L__LEGACY.ogg
2018-08-14 18:42:59.895 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/soundset.ogg
2018-08-14 18:43:00.778 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/1.ogg
2018-08-14 18:43:01.804 DEBUG [playSound] [sdl_sound.c:295] play sound: sounds/ready.ogg
2018-08-14 18:43:02.146 INFO [loadSoundSet] [sdl_sound.c:567] loaded (0/0) samples/errors, used B of 1024 MB max, time 2257 ms
2018-08-14 18:43:02.148 INFO [initGpio] [pincom.c:210] setting up GPIO for DATAEAST
2018-08-14 18:43:02.305 DEBUG [stbInterrupt] [pincom.c:86] stb int. address 128 0x80
2018-08-14 18:43:02.305 DEBUG [loadSample] [sdl_sound.c:745] sample not in RAM, loading 1 samples
2018-08-14 18:43:02.305 DEBUG [loadSample] [sdl_sound.c:747] sample not in RAM, loading from /boot/data/sound/1/sfx/0388323897-t_rex_roar_2/T Rex Roar 2.ogg
2018-08-14 18:43:02.306 DEBUG [encode_init] [rot_decode.c:72] init GPIO for rotary encoder
2018-08-14 18:43:02.306 DEBUG [encode_init] [rot_decode.c:74] phase A pin 23
2018-08-14 18:43:02.306 DEBUG [encode_init] [rot_decode.c:77] phase B pin 22
2018-08-14 18:43:02.307 DEBUG [encode_init] [rot_decode.c:80] button pin 21
2018-08-14 18:43:02.619 DEBUG [loadSample] [sdl_sound.c:754] Loaded sample 128:0: len: 582 kB, used: 582 kB
2018-08-14 18:43:02.620 DEBUG [playSample] [sdl_sound.c:804] playing sample 128:0 vol: 8->46 'sfx' 't_rex_roar_2' on channel 0
2018-08-14 18:43:02.620 DEBUG [doCheckDucking] [sdl_sound.c:235] sample starts playing, set music vol to 90
2018-08-14 18:43:02.620 DEBUG [stbInterrupt] [pincom.c:86] stb int. address 128 0x80
2018-08-14 18:43:02.621 DEBUG [stbInterrupt] [pincom.c:86] stb int. address 128 0x80
2018-08-14 18:43:02.621 WARN [soundHandler] [sdl_sound.c:888] supressed repeated cmd: 128
** Line in bold repeated until I removed power
Ok dude let’s use Pastebin next time for a huge post like that!
Quoted from Rdoyle1978:Ok dude let’s use Pastebin next time for a huge post like that!
Only big on a mobile phone .. Anyhow, I've moved the log output to pastebin.
Quoted from Wharhed:Only big on a mobile phone .. Anyhow, I've moved the log output to pastebin.
Lol it was not! Haha. Pastebin is a lot easier to manage - post the url too so Steve can check it out
Rotary encoder is mounted to the pcb. This is before I added the jumpers as per Steve’s documentation. I ended up drilling holes through the board to better secure the rotary encoder with the two unused tabs.
07563B99-515C-467F-9B2D-BCC650548D77 (resized).jpeg71C10224-1C97-4109-B6B6-81430129BF4F (resized).jpegQuoted from Wharhed:I get that it will continue to announce the serial number and say demo mode, but I didn't think I was required to have the license loaded to have the sound files function. Also, when I went through his documentation post, it said numbers, but either way is fine for me. In the log below, it looks like it found the files and the config.raspisnd.
Steve - One thing, I'm using a USB soundbar at the moment as my USB sound card seems to have walked away :/. Also, I snagged the log (below). Is there anything you can see any obvious errors that would affect this?
Log file - https://pastebin.com/8yQpZSbk
What I can see from the logfile: the board is receiving a command 0x80 (play sound effect 128 -> trex roar sound) in a high frequency, which isn't normal. I would recommend to check the shield especially bit 7. There seems to be some noise on that wire that make the sound triggering over and over again?
Also you need to check the interrupt wire SWDEN, maybe you simply missed to place the jumper correctly to DE mode (lower left of schematics)
Quoted from steve45:What I can see from the logfile: the board is receiving a command 0x80 (play sound effect 128 -> trex roar sound) in a high frequency, which isn't normal. I would recommend to check the shield especially bit 7. There seems to be some noise on that wire that make the sound triggering over and over again?
I went back through and tested everything that I soldered, and didn't find any immediate issues. However, I did notice that the small 5v transformer is making a noticeable high pitch noise. I'm wondering if it's having issues too.
Quoted from Wharhed:I went back through and tested everything that I soldered, and didn't find any immediate issues. However, I did notice that the small 5v transformer is making a noticeable high pitch noise. I'm wondering if it's having issues too.
It's true you can hear these DC DC stepdown converter, at least if you younger than me
But I would not consider this to be the problem as the pi was booting and running, so the 5v seem to be okay. If you have a DMM you can also test the power supply.
Thanks for the replies - I'll have to test it when I have some more time this evening and post an update.
I have a Pi3 B+. The firmware will not boot. I’ve tried my sd card in my friends Pi3 B and it boots fine. I have booted mine with Noobs just to make sure my Pi3 works. Is the firmware compatable with Pi3 B+ or did I miss that in the documentation?
Quoted from Bd700:I have a Pi3 B+. The firmware will not boot. I’ve tried my sd card in my friends Pi3 B and it boots fine. I have booted mine with Noobs just to make sure my Pi3 works. Is the firmware compatable with Pi3 B+ or did I miss that in the documentation?
Honestly, I've never tried Pi3 B+. From what I know it should run, because it's a simple Arch Linux based image with some preinstalled libraries and the RasPiSound service.
I will do some research, if there is a known issue with the arch Linux version I use and maybe buy a Pi3 B+ for myself for testing.
For now that's all I can say.
/Steve
I still haven’t found any obvious issues on my board. I know the Pi boots by itself ok and doesn’t trigger the repeating sound.
At this point, any other tips or should I pull the surface mount logic chips and reinspect?
There is an issue with Pi3 B+ and the arch linux distribution, so I need to create a complete new image in order to run on Pi3 B+. For now you can only use Pi3 (classic). As soon as the image is ready, I will announce it here.
/Steve
Quoted from Wharhed:I still haven’t found any obvious issues on my board. I know the Pi boots by itself ok and doesn’t trigger the repeating sound.
There are some tests you can do:
1. try to switch the mode jumper to wpc or pull it completely out, see what happens.
2. switch to vendor=1 in raspisound.ini even if you're going to use it with DE.
3. If you have the equipment try to sample the signal on the SWDEN wire (this triggers the interrupt)
/Steve
Good news for pending orders: the amplifier modules arrived today. all pending orders will ship tomorrow!
/Steve
How are you guys connecting the speakers? I haven’t gotten mine installed yet and I want it to be reversible; what do you suggest instead of cutting wires? I guess I could jumper the connectors..
Quoted from steve45:There is an issue with Pi3 B+ and the arch linux distribution, so I need to create a complete new image in order to run on Pi3 B+. For now you can only use Pi3 (classic). As soon as the image is ready, I will announce it here.
/Steve
Thanks Steve, I was going crazy thinking I was doing something wrong.
Quoted from Bd700:Thanks Steve, I was going crazy thinking I was doing something wrong.
Just because this wasn’t your fault doesn’t mean you’re not going crazy.
Still haven't had much luck. For some reason or another, it seems like it's locking up on this round. Everything stops playing and nothing seems to be responsive while using the rotary encoder.
Log 1 - https://pastebin.com/ceGKs3ah
Log 2- https://pastebin.com/8XJXUyDm
I do have an oscilloscope, but I'm pretty new to using it. I'll see if I can dig it out and do the testing you suggested.
** Update **
Jumper placement and complete removal did not make a difference. However, I changed the vendor to WPC (1) in the raspisound.ini and the log output looks a bit different. It almost looks like it's doing more what it should be now. There is still complete silence after it says the serial number and that it's preloading the sounds.
Bug?
Quoted from Lonzo:Just because this wasn’t your fault doesn’t mean you’re not going crazy.
True, you and me both.
I have had success with playing sound sets through the raspisound board to speakers but only if I select the sound. The pin is not calling for the sounds to be played. I think it’s a configuration problem on my part. I’m confused about the raspisound.ini. Is this a file I create on my own? Also unsure what to put in the use-usb.txt file or is it suppose to be empty? Sounds play fine through the 3.5mm port from the pi but not through my usb sound card.
Thanks for all the help!
Jay
Quoted from Bd700:I have had success with playing sound sets through the raspisound board to speakers but only if I select the sound. The pin is not calling for the sounds to be played. I think it’s a configuration problem on my part. I’m confused about the raspisound.ini. Is this a file I create on my own? Also unsure what to put in the use-usb.txt file or is it suppose to be empty? Sounds play fine through the 3.5mm port from the pi but not through my usb sound card.
Jay
use-usb.txt file can be empty. It's just an indication for the RasPiSound service that it should use USB sound. Unfortunately this cannot be controlled easily through config files, that's why I need an indication file.
The config file raspisound.ini is meant to be created by you to set some basic configuration for your machine. Most relevant is the vendor setting, because it controls the wire protocol use by the machine. See how-to on pinball-mods.de for description of all settings.
Br Steve
Quoted from steve45:use-usb.txt file can be empty. It's just an indication for the RasPiSound service that it should use USB sound. Unfortunately this cannot be controlled easily through config files, that's why I need an indication file.
Br Steve
Thanks Steve
This page was printed from https://pinside.com/pinball/forum/topic/rebuilding-sound-for-de-jurassic-park-using-a-pi/page/4 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
