I have a TAF that could use some new sounds. Are assembled board available?
Quoted from steve45:
can you please state the version. I did a lot of changes these days. and volume control was still with some bugs, therefore a number would be nice.
I am using 1.30rc23 - The WebUI says that is the latest version.
Oled is not working, what could be the reason?
Edit.
After connecting, no sound, the display (Pin2Dmd) does not work properly, I think I installed something wrong?
Via Web UI, I connect and play sounds, so it seems to me that the hardware is the cause. Resistors??
Hi,
check and meassure the 5V on the board..
I can not see your DAC converter U5 by the way, this one is necesarry to connect between RasPI and Amplifiers
Quoted from Jim-Beam:
Hi,
I was convinced the U5 was optional
Thank you
Ordered ?
It is normally part of the standard. To prevent misunderstanding, U5a is a extra option DSP Modul, U5 is the smaller DAC and standard as far as i know...
So check the package, it should be in. In the meantime, connect a standard headphone to the 3,5mm socket direct at the Pi itself and change the output device accordingly in the Web UI
sorry i said wrong, sounds are working (run via web), display still not working.
EDIT..
I changed the raspberry to try another one and now the display works,
Quoted from fly:
U5 mounted, but unfortunately still the same problem, the display does not work properly, flippers do not work, music is just on the headphones directly from the Pi, it is not played properly.
Could this be the fault of the resistors ??
I may be mistaken, but I believe the normal resistors you have used should be replaced by a resistor network similar to the one nearer us in the picture ?
Quoted from fly:
If those are supposed to be bussed resistors in those locations then that would explain a lot! You'd need a resistor in each location except for the common. All the leads across the opt would be tied together and then go to the common pin
The network resistors RN3, RN4 and RN5 can be replaced with ordinary ones, Steve wrote advised, the display works fine, the fault was in soldering, one pin was not soldered exactly.
Now I have the sound on the headphones, I will change the wiring from the speakers and further tests.
HI, to change the sound output from the headphones to the DAC, you need to change the Audio device in the Web UI to equal-dac !
first tests done, I do not know if it is the fault of the sound package or hardware, but for example with "Super Charger" the music turns off, and after the game is over, attract sound will not turn off,
Besides these mistakes, it's great, I will change to TiltAudio in all my machines
One thing is for sure, as Steve wrote on his website, you must change the speakers
I had the same problem with the game over music not stopping on a DE star wars. Never could figure it out, I ended up changing a setting ( can't remember which one). Now there is no music after the match feature but at least it doesn't play continuously.
If someone has some ideas of why it does this, I would love to hear them
Lucky1, I also never got the data east volume control to work in the cabinet and the wifi never worked. Could only use ethernet
I think there was a problem with switching sound types in older releases. Do you use the latest version ?
DataEast Volume Control did not work reliable with the old R-C circuit. A ADC circuit was added to the latest pcb design for that.
Wifi Setup was also improved on the latest firmware releases.
I do not have the latest version. I think I am running 1.28. I have been shy about updating because it took so long to get the thing running close to right.
Has anyone added up all of the parts needed to add this TiltAudio to a WPC95 machine? I was intriqued by the $70 original board, but it looks like it adds up quite a bit more once you add of the additional aprts. Anyone have some guidance or experience that it is lower in cost than the $350 PinSound approach?
Quoted from Markharris2000:
I was using the project provided by Steve and I was completing the sets myself. Such a general calculation for 5 pieces is about $ 300-350, I did not include micro SD cards.
The fuse rating seems a little bit on the low side, 1A on the 18VAC line, it burned after two weeks. Unless I have a fault somewhere, but the circuitry seems relatively simple and I checked all soldering and signals and it seems good.
Is this a fast blow or slow blow?
Quoted from fly:
So PinSound and TiltAudio are about the same price out the door. Would anyone suggest some key pros or cons to steer towards either one of these? For instance PinSound seems to have a broad community of alternative sound libraries already built per machine, but there must be other features that are unique to each of these sound solutions.
300-350$ - for five pieces!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Quoted from fly:
So a single set for ONE machine is maybe $75 all in (without the RaspPi board)? I thought the "five pieces" referred to all the individual boards, displays, usb audio sticks, etc.
Exactly. It's way cheaper than a Pinsound
BUT, bear in mind, this is not PnP, you need to know how to solder, and potentially to debug. Be prepared for that. There's a reason Pinsound is more expensive, it's literally PnP, you have warranty, and it's a 10 min install
On the flip side, Tiltaudio capabilities are more extensive
That said, I'm using Tiltaudio
Damn, looks like the 12v regulator on my Tiltaudio is dead.
Anyone has experienced something similar? Any pointer to a quick to get replacement part?
ebay has a lot of suppliers for these. You need to adjust the converter to 12V before use in TA
ebay.com link » Lm2596s Dc Dc Spannungsregler Step Down Converter Regler Einstellbar 1 2v 30v 3a
Quoted from lucky1:
Thanks, I checked the schematics and found out that Amazon has both packs for the 12V regulator and the 5V regulator.
Now one additionnal question: is there any specific tips and tricks for the "upload sound package" functionality ?
Specifically, I downloaded the recently released altsound pack for Creature (available on vpinball), and when I try to use the "upload package", I get the following in the log file:
2021-01-11 10:37:46.135 DEBUG MHD-sing [initPostProcessor] [httpservice.c:608] init post processor of type SOUNDSET_UPLOAD_POST
2021-01-11 10:37:46.135 DEBUG MHD-sing [initPostProcessor] [httpservice.c:621] post processor 679ff008
2021-01-11 10:37:46.143 DEBUG MHD-sing [requestHandler] [httpservice.c:1632] url: /soundsets, method: POST, version: HTTP/1.1, contentType: multipart/form-data; boundary=----WebKitFormBoundaryW4ZcBDAsB0s7T8yd, upload_data: 67b007ac, size: 1460, connCtx: 0x67b9bd60
2021-01-11 10:37:46.143 DEBUG MHD-sing [handleContextRequests] [httpservice.c:1592] POST req count 1, size 1460
2021-01-11 10:37:46.143 DEBUG MHD-sing [handleContextRequests] [httpservice.c:1612] calling post processor callback 0x679ff008
2021-01-11 10:37:46.143 DEBUG MHD-sing [uploadSoundsetPostCallback] [httpservice.c:289] connCtx: 0x67b9bd60, kind: 4, key: file, filename: , contentType: application/octet-stream, TransferEncoding: (null), data: 0x679ff070, off: 0, size: 0
2021-01-11 10:37:46.143 DEBUG MHD-sing [uploadSoundsetPostCallback] [httpservice.c:316] writing file /boot/data/sound/1.zip
2021-01-11 10:37:46.144 DEBUG MHD-sing [uploadSoundsetPostCallback] [httpservice.c:289] connCtx: 0x67b9bd60, kind: 4, key: options, filename: (null), contentType: (null), TransferEncoding: (null), data: 0x679ff070, off: 0, size: 2
2021-01-11 10:37:46.144 ERROR MHD-sing [uploadSoundsetPostCallback] [httpservice.c:307] no file key provided -> abort
2021-01-11 10:37:46.144 DEBUG MHD-sing [requestHandler] [httpservice.c:1632] url: /soundsets, method: POST, version: HTTP/1.1, contentType: multipart/form-data; boundary=----WebKitFormBoundaryW4ZcBDAsB0s7T8yd, upload_data: 67b007ac, size: 2920, connCtx: 0x67b9bd60
2021-01-11 10:37:46.144 DEBUG MHD-sing [handleContextRequests] [httpservice.c:1592] POST req count 2, size 2920
2021-01-11 10:37:46.144 DEBUG MHD-sing [handleContextRequests] [httpservice.c:1612] calling post processor callback 0x679ff008
2021-01-11 10:37:46.144 DEBUG MHD-sing [handleContextRequests] [httpservice.c:1592] POST req count 3, size 2920
followed by hundred of similar of lines, and it never stops, to the point that my log file gets bigger and bigger. I also don't see any progress bar, is there supposed to be one ?
The file is a zip file of the sound package folder (so one folder up)
Am I missing something ?
So in debugging my problem on the 12V regulator, it's behaviour is relatively odd:
- At 18V DC input it's working
- At 22V DC input it's not working at all
Turns out that I have 22V DC input (or output from the rectifier), which explains why it's not working when put in the pinball, but working when I power it from my lab power supply (which was set to 18V).
From the specs it should be able to accomodate up to 30V, so it seems to me it's dead.
Sidenote: am I right to assume the PIN2DMD connectors are to power a PIN2DMD from TiltAudio (instead of using an alternate connector on the power board, such as J118) ? If so, I would tend to think the power regulator is slightly under rated for the usage, as a PIN2DMD is about 10W peak, so 1A, leaving 2A for the amplifiers, which are powered at 12V, so 24W. Even without a PIN2DMD connected, that's only 36W for the amplifiers, that seems rather low ? Or am I misled and amplifier power consumption is way lower than 2A anyway ?
Unfortunately I could not find a much higher current DC-DC 12V regulator in a similar form factor, if anyone has a pointer that would be welcome
I did find much higher amp regulator (8A or 10A) though, but they use screw in connectors, and their footprint is slightly bigger. i'll take a look to see if I can adapt it
The pin2dmd connector should only be used if you use a external 12V powersupply for both TA and PIN2DMD
On WPC machines use the 12V power from the WPC PDB board as described on www.pin2dmd.com
Thanks, that's what I suspected. I'm not powering Pin2DMD through Tilt Audio anyway, so that does not explain why my regulator broke
Feedback for steve45 , it would be nice if instead of using male header pins to connect the various additionnal PCBs (regulators, amplifiers and so one), you would use female headers similar to these on the attached picture, this would allow for much easier replacement in case of one component dying.
It's probably even possible as is, by using the pins headers and removing one of the pin since there is no hole), just need to supply them (come to think of it, I'll order a bunch)
Also, I worked around my issue for uploading the altsound sound package by adding it manually.
However I would have the following questions:
- I get a bunch of errors in the log file, such as " 2021-01-13 14:08:38.549 ERROR MHD-sing [getFileSize] [fileutil.c:412] stat call on /boot/data/sound/cftbl_l4/ok failed "
All failed files are in the jingles section. Yet they are accessible afterward through the WebUI, and can be played back.
- How does the "serial" command in the case of altsound package ? I bought the TiltAudio full media package for Creature, and when checking the file structure I see that there are serial.txt files in various folders, which are used to trigger multimedia command, but how would that work for an altsound package for which all files are in a common folder with a CSV file ?
- On the topic of the media player : any specific reason why both TiltAudio and multimedia playback for the video mod under the Creature window could not be combined into a single HW unit ? That would make it easier for installation (just need an HDMI cable from the RPI to the display)
What are the values for C7-C12 on the v3.0 board ? BOM only says C-EU050-025X075, schematics say nothing ...
Quoted from Zigzagzag:
200pf
Quoted from kba78:
Latest firmware also works with old style data east volume control, but you need to change the resistor and e-cap. just pn me.
Quoted from Ashram56:
That one was broken, please update to the latest firmware. Also always double check with https://tiltaudio.com/changelog to see if it is a know bug / fixed bug.
TILT!Audio supports a couple of additional columns in the csv table. These columns are added of the fly if you edit the sounds in the web UI. For serial commands the column name is "SERIAL", for the new stop commands the column name is "STOPCMD"
I'm indeed working on that. Prototype is looking good already. The lua binding is also ready. Basically I need more testing and create a easy install image
Im assuming the older board versions are backwards compatible with the newest software releases? I don't see it specifically mentioned.
And the WPC communication timing issue won't be a problem now?
Added today:Is the timing issue solution a hardware repair or done in software? What boards did it affect?
Quoted from WW2GURU:
I tested the v3 board in my IJ but unfortunately had some problems. I posted about it earlier, but have not been able to find an answer.
I would still like to hear if others with a tilt audio board, successfully hears all 5 "dings" when entering the test menu, and there is an error? With my tilt audio board, i have never been able to hear all 5 "dings". There is always one or 2 of them missing. And this seems to suggest that there is something still a little of in the triggering / timing / emulation. It is a really simple sound, so i would think it should be able to play correctly.
And i know that a few missing "dings" doesn't affect gameplay, but perhaps identifying the underlying issue could help with potential issues during gameplay, and move it a little closer to that coveted 100% emulation
Quoted from Phantasize:
Is preloading activated in the config ?
