Hi i have issues getting sound out through shield. Works fine when using HDMI and sound coming out from tv. Have hw1.9, Image 1.24 using a Pi zero with usb soundcard. Have anybody had any success with this combo? I have tried so many options with use-usb.txt in data directory using windows, but no success. If somebody has made it work with this combo please explain how it should be done and maybe make a PrtSC. Havent got the wifi to work either, heres how i typed in my SSID on file dietpi-wifi
# - Entry 0
# WiFi SSID (Case Sensitive)
aWIFI_SSID[0]="Xiaomi_D9D7 Cederl"
# Key options: If no key (open), leave this blank
aWIFI_KEY[0]="blajajablabla"
# Available options: NONE (no key/open) | WPA-PSK | WEP | WPA-EAP (then use settings below)
aWIFI_KEYMGR[0]="WPA-PSK"
# - WPA-EAP Options
aWIFI_PROTO[0]=""
aWIFI_PAIRWISE[0]=""
aWIFI_AUTH_ALG[0]=""
aWIFI_EAP[0]=""
aWIFI_IDENTITY[0]=""
aWIFI_PASSWORD[0]=""
aWIFI_PHASE1[0]=""
aWIFI_PHASE2[0]=""
# Location of the certificate file (eg: /boot/mycert.cer)
aWIFI_CERT[0]=""
# - Entry 1
aWIFI_SSID[1]=""
aWIFI_KEY[1]=""
aWIFI_KEYMGR[1]="WPA-PSK"
# - WPA-EAP Options
aWIFI_PROTO[1]=""
aWIFI_PAIRWISE[1]=""
aWIFI_AUTH_ALG[1]=""
aWIFI_EAP[1]=""
aWIFI_IDENTITY[1]=""
aWIFI_PASSWORD[1]=""
aWIFI_PHASE1[1]=""
aWIFI_PHASE2[1]=""
aWIFI_CERT[1]=""
# - Entry 2
aWIFI_SSID[2]=""
aWIFI_KEY[2]=""
aWIFI_KEYMGR[2]="WPA-PSK"
# - WPA-EAP Options
aWIFI_PROTO[2]=""
aWIFI_PAIRWISE[2]=""
aWIFI_AUTH_ALG[2]=""
aWIFI_EAP[2]=""
aWIFI_IDENTITY[2]=""
aWIFI_PASSWORD[2]=""
aWIFI_PHASE1[2]=""
aWIFI_PHASE2[2]=""
aWIFI_CERT[2]=""
# - Entry 3
aWIFI_SSID[3]=""
aWIFI_KEY[3]=""
aWIFI_KEYMGR[3]="WPA-PSK"
# - WPA-EAP Options
aWIFI_PROTO[3]=""
aWIFI_PAIRWISE[3]=""
aWIFI_AUTH_ALG[3]=""
aWIFI_EAP[3]=""
aWIFI_IDENTITY[3]=""
aWIFI_PASSWORD[3]=""
aWIFI_PHASE1[3]=""
aWIFI_PHASE2[3]=""
aWIFI_CERT[3]=""
# - Entry 4
aWIFI_SSID[4]=""
aWIFI_KEY[4]=""
aWIFI_KEYMGR[4]="WPA-PSK"
# - WPA-EAP Options
aWIFI_PROTO[4]=""
aWIFI_PAIRWISE[4]=""
aWIFI_AUTH_ALG[4]=""
aWIFI_EAP[4]=""
aWIFI_IDENTITY[4]=""
aWIFI_PASSWORD[4]=""
aWIFI_PHASE1[4]=""
aWIFI_PHASE2[4]=""
aWIFI_CERT[4]=""
Hopefully somebody can help the newbie Regards/Stefan C
