(Topic ID: 260456)
Rebuilding flippers on Jurassic Park, where does this part go?
By Spencer
70 days ago
  • 11 posts
  • 6 Pinsiders participating
  • Latest reply 69 days ago by Roverius
#1 70 days ago
So I got the rebuild kit from Pinball life. I've changed everything over but I have 2 larger sized wave washers left over. (They are the size of the coil sleeves.) They were not installed on my game when I took it apart. Where are they supposed to go?
Thanks in advance
#2 70 days ago
in between the coil and the rear coil stop. keeps the coil tight in the mech.
#3 70 days ago
Great, thank you.
#4 70 days ago
It keeps the flipper coil tight so it won't flop around.
#5 70 days ago
Quoted from bigehrl:
Pretty sure this is incorrect. That's how Stern used them but it's been recommended to put them between the front of the coil and the metal bracket. This way it keeps them from rubbing against the coil stop and contributing to wearing it out. I know some company put them in the back and others out them in the front side.
#6 70 days ago
Opposite the coil stop nearer to the mech is where they go.
#7 70 days ago
Quoted from arcademojo:
i read what you're talking about, and have tried this. all this did was make it difficult for the sleeve to sit properly in the center of the front coil stop, and it actually flopped around more. don't believe everything you read.
#8 70 days ago
Then you are installing it incorrectly. The washer will fit on either side of the coil. The coil stop will last longer if it is placed on the opposite side.
#9 70 days ago
Quoted from D-Gottlieb:
i believe i installed it correctly. both coil stops were held tightly together when screwed down. i'm not sure how else you're supposed to do that. but, installing it on the front side of the coil presses the coil tighter against the rear stop. what's the theory on how that preserves it? not saying you're wrong, just curious?
#10 69 days ago
I’ve changed at least a dozen Stern games over to the correct way with washer in front and never had any of the problems you are talking about. But it make it a little more difficult to get together. The sleeves all sat properly once you got it right. Think that’s why they put them in the back since it was a lot quicker to do that way.
#11 69 days ago
I have also rebuild my flippers. Some parts are not needed and might be used for other models.
Here, on the image, you can see how they look on a LW3 from Data East.
$ 149.99
$ 40.00
G-Money Mods
Professor Pinball
