The first task is to build a new cabinet. I wanted to keep the original Bally design but add some improvements where necessary. But, in general, the Bally cabinet isn’t’ the most efficient thing to assemble. It’s somewhat of a puzzle. I imagine they used lots of jigs to get these things together.
I am using 3/4” Baltic birch. Well, not quite. You’ll find out that 2023 plywood isn’t the same dimensions as 1980 plywood. I am using an old blown out Vector cabinet as my template and each piece is exactly ¾” thick. But plywood is now 18mm thick which is about 1mm thinner. It doesn’t seem like a big deal, but it can add up when you are trying to piece together this cabinet puzzle and you find pieces don’t match up. You don’t want your glass binding because you were 2mm off on your dimensions. The key is to determine if you are more interested in matching inside dimensions or outside. Metal brackets and glass aren’t easy to adjust if your wood is off.
An annoying part of the early Bally cabinets is the constant angles. Because the body is sloped at about 3.5 degrees everything on top of that must be cut at 3.5 degrees or the compliment. And I mean EVERYTHING. Even the metal hinges need to be adjusted. I can see why cabinet designs use a plateau for mounting the head these days.
The first to be cut are the cabinet sides and the evil 3.5-degree slope. The easiest way to do this is with a handheld circular saw. It’s easy to do with a sharp blade. First, I cut the entire panel to length, then marked the front height and the back height and aligned a guide rail for the saw. The back panel was small enough to fit on my table saw.
Cutting side panels
For the front panel I used my CNC router since it has a couple of cutouts. This was probably overkill since the cutouts are not that difficult to do with a handheld router.
CNC routing front
There are some dados cut into the sides for the bottom and head supports.
Finished sides and front
I am using a double rabbet joint to join the corners. And then glue and screw it. A rabbet joint would probably have been fine though. The original joint is too complex for what I am trying to accomplish.
The bottom piece is a piece of 1/4” (or 6mm) birch plywood.
Using some old cabinet parts to do a sanity check is required to make sure I am not too far off on any dimension.
Sanity check
If you have a sharp eye, there is a flaw...
