Best thing to do is go through the pinrepair stuff, and value the stuff on pinwiki. Isolation as others have said is helpful, but ultimately if you are doing a flip you don't need to do more than fix and play. The more you play, the more the EM will come together. However, if you are doing a full restoration, you need to and ultimately must go over every single item in the game which takes ~40 hours total with PF strip and wax. Its fun, a full week, 7 AM to 3 PM each day for a solid week. You will then not only learn what you must, but also have a game (in most cases) that works, and works right. What isn't right will be obvious and you will live with it or you won't, and order parts from the butt rapers in the business. GL in all things.
