(Topic ID: 301933)
Re-Import Question
By GPS
2 years ago
    #1 2 years ago
    Hello All
    Just wondering what is done on the game to convert a 50 hz 220 vac machine to 60/110? I have recently acquired a re-import I am guessing as the. Pin door is setup fir German Francs and there is a German sticker on the back of the cab. Is a re-import necessarily any less valuable than a non re-import?? Game is in great shape!
    Thank you
    George
    #2 2 years ago
    Depends on the game. Normally, 50/60 Hz is not a problem, but newer Sterns (SAM games at least, dont know about Spikes) check the line frequency and refuse to operate if they find out a game is used in different country it was sold to.
    Older games usually have multiple configurations of transformer primary, that you can change via a jumper plug (in modern games) or by wiring the transformer according to line voltage and manual/schematic (older SS and EM games). Very often the European 220/230V games have a wiring option for 110/115 volts, but not the other way around.
    #3 2 years ago
    Got it. Thank you
    #4 2 years ago
    You should post which game, as what you do varies with the platform. It often involves switching jumper wire position on a power connector in the cab, you can consult the manual for your game.
    You can also use the search function, this topic has been covered numerous times.
    This page was printed from https://pinside.com/pinball/forum/topic/re-import-question-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
