Hello all!
I am picking up an AFM pinball machine soon and was wondering if anyone has installed LEDs into their machine? If so, did you go for a full LED conversion or mix your LEDs with more traditional incandescent bulbs?
The main reason that I am thinking of putting in LEDs is to try and do everything I can to protect the machine and, since LEDs output far less heat than incandescent bulbs I thought this might be a good idea. Plus, I like the look of LEDs and since I was considering adding the Bill Ung saucer kit (with green LEDs to help balance so much red on the table) I thought an LED might go well.
Finally, if you did install LEDs where did you buy them? Then only kit I see is from cointaker.com...
Thank you all for your input!
