Club RBION: The Strange, the unusual, the bizarre!
(Topic ID: 90719)
By chadderack
  • 758 posts
  • 106 Pinsiders participating
  • Latest reply 9 days ago by ababapanos
  • Topic is favorited by 48 Pinsiders
There have been 131 images uploaded to this topic. (View topic image gallery).
There are 758 posts in this topic. You are on page 16 of 16.
#751 18 days ago
Quoted from ababapanos:
Hello
I would like to ask you if I can delete the factory high scores and save only my high scores.
The same thing I would like to do to the other my pinball of williams and bally
In the standard adjustments menu just set the default high scores to 0 and then reset the high scores in the reset menu.
#752 18 days ago
Hello
You can not totally delete the factory high scores. You CAN set the default factory high scores to be very very low. That way you just play a few games, and bingo, your scores are the new high scores
#753 18 days ago
And the same can be done in williams and bally pinballs?
#754 18 days ago
Quoted from jonesjb:
I’d buy one, but with my limited collection (3 pin max). I’m not sure it would work well with my Shadow... given they have very similar locks.
Ripley’s and The Shadow do both utilize a magnet located top/center of playfield that grab the ball and throw it backward up the playfield. Only seen that on 3 games, these and Dialed In! Otherwise, I agree, very different games. To me, Ripley’s is a slightly simpler version of Dialed In, with a dash of TZ. Even the code is similar. Visit continents, hit shots, collect letters to spell Ripley’s. Or, hit cell phone, start disaster, hit shots, collect letters to spell Dialed In! DI is a polished, modern version of Ripley’s. In my opinion. I owned them both and had them next to each other. They are definitely cousins.
I’m not sure why this pin is so underrated. Theme, most likely. Callouts can be a bit goofy too. But as for pure shots, it’s one of the best.
#755 18 days ago
I'm not certain as I do not own any bally/William's games. I would assume so, but that's just a guess
#756 16 days ago
RBION before and after Pinstadium LED light kit install. Man, what a difference!! My Ripleys was so dark before. Check out the lighting down the sides and in the left pop bumper area. Man oh man...
#757 11 days ago
Hi, I’m new to the club. My new Ripley’s volume is very loud. I have the master volume on 2 and adjustment 37 on 15 but it’s still very loud. Probably equivalent to 13-15 or more on a bally/Williams game. Any idea what might be causing this or how I might fix it?
#758 9 days ago
Hello.
Every time I connect the autoplunger , the fuse burns (f21).
I changed the coil (23-800) , I put and new cable from the coil to the board and then again the fuse burned. What shall I do?
PinSound
4,200
Sale Pending!
Brighton, CO
Sparky Pinball
$ 50.00
