(Topic ID: 191446)
RBION sink hole switch not registering the pinball
By lspin
1 year ago
  • 5 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by TheLaw
#1 1 year ago
Need some advice on where to start troubleshooting an issue with the sink hole not registering the ball. Once the ball goes into the sink hole the game will have to look for the missing ball and then the VUK works fine and puts the ball back into play. I know there is a fork looking pressure switch which has to register that the ball is in the sink hole. Any advice where to start would be appreciated.
#2 1 year ago
Switch tests in the menu. See if the switch works. If not, work backwards. Switch physically intact, soldering, wire...etc.
#3 1 year ago
I just had this issue myself. Even though the switch worked by hand in test, it did not trigger from a ball. The peak of the switch arm's curve had to be bent higher than I anticipated.
#4 1 year ago
If the same fork switch as LOTR, keep several in stock. Always have solder on hand and the soldering iron warm.
#5 1 year ago
Quoted from bpeed99:
Ha too true. This and the scoop switches are the only real issues I've had with my RBION. They need some attention from time to time for sure.
$ 16.50
5,500 (OBO)
Highland Park, IL
PinSound
5,100 (OBO)
Sale Pending!
Richmond, IN
