Hi everyone,
I'm trying to make perfect my RBION.
With your help in other threads, I've successfully repaired other things. There are only two other things I would like to correct.
1) There is a scoop which sometimes is sending the ball not so strong, and so the coil has to fire multiple times before the ball go out from the scoop.
I've seen in this video on YouTube:
That the balls always goes out perfectly straight and strong.
In my pinball, it's not so precise. Here's a little video from my pinball:
https://streamable.com/53d8f
How can I solve this?
2) Sometimes the ball get stuck in the upper right part of the playfield, as you can see in the image attached. Should I replace the rubber ring? To do that, is it necessary to remove all the plastics near this rubber?
Thank you
